Samsung UN65MU8000FXZA Dead NO power NO standby light won't turn on
  • dskall
    • Oct 2016
    • 2905
    • usa
    #41
    Re: Samsung UN65MU8000FXZA Dead NO power NO standby light won't turn on
    Need pictures of whole back of tv and boards.
    • rgla
      • Nov 2021
      • 23
      Here are photos of the TV with the back panel removed
      Close ups of the boards are in POST #8
      • dskall
        • Oct 2016
        • 2905
        • usa
        #43
        Probably has a t-con beneath the stand.
        • rgla
          • Nov 2021
          • 23
          there is a small 1 inch x 3 inch circuit board that the flat ribbon cable goes into at the bottom of the TV. Does this function as the T-con? I think the Tcon is part of the main board on these.
          • dskall
            • Oct 2016
            • 2905
            • usa
            #45
            Without good pictures. I don't know. Your asking about a board that is covered up.
            • rgla
              • Nov 2021
              • 23
              Here are some close up shots of the small circuit boards that the flat cables run into near the bottom of the tv. The flat cables run from the MB to these 2 separate small boards.
              I cleaned the ends of the ribbon cables with alcohol to see if that would get rid of the yellowish vertical lines and the half dark screen.
              • dskall
                • Oct 2016
                • 2905
                • usa
                #47
                This is like a strip show. Just get a little at a time. I suspect that the t-con is built into the 2 strips behind the metal shielding.
                • rgla
                  • Nov 2021
                  • 23
                  I would suspect that those might be T-con but someone else said that T-con is part of the MB on these TVs.
                  Either way, i haven't seen those 2 small circuit boards on any parts list so I'm not sure how to proceed.
                  Could the half and half screen be from the MB, the flat ribbon cables or those 2 tiny boards? There isn't much left beside a panel but all the backlights seem to work fine
                  • lotas
                    • Jan 2016
                    • 4900
                    • Russia
                    #49
                    T-CON is on main, check the cable is not damaged, the contact moldings are not displaced, it is better to look under a magnifying glass, whether the cable itself is well inserted and carefully examine the nearby components near the bottom connector of the capacitors, whether they are knocked down, compare with another board with two parties.
                    • lotas
                      • Jan 2016
                      • 4900
                      • Russia
                      #50
                      And if you are good friends with a soldering iron, then you can carefully solder from a new one to your non-working mainboard spi flash ic 1604, if you do not find a problem in this t-con.
                      • rgla
                        • Nov 2021
                        • 23
                        Thank AGAIN Lotas
                        I'll check it
                        • rgla
                          • Nov 2021
                          • 23
                          I finally got another replacement MB. Problem Solved.
                          So the first MB was DOA. The second powered up but had a bad T-con section on the board. Third time's a charm.
                          I might take the original board in to see what went wrong. But thank you for all your help.
                          • bmontou
                            • Aug 2022
                            • 10
                            Where did you purchase the main board that worked? I have the same exact issue as you.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4543
                              • Italy - Milan
                              #54
                              Sorry, have no time to read carefully all, i think you could have bought wrong main board in the picture of it you posted i see a double code sticker, BN94 is for the Audio-Video board part, BN97 is for the tcon/panel part, so must match both the original, last note, check your meter's batteries or replace meter because 96v doesn't exist also up on the moon...
                              • bmontou
                                • Aug 2022
                                • 10
                                I have the same TV with the same initial issue after a power outage and purchased the same part. When plugged in my tv had no stand by light and the led's did not come on. I changed the main board and now the led's blink on and off, but show no picture. When the ribbons that go into the main board are detached the tv will blink 1 time and then go to a solid dim light on the screen with no picture. The company who sold me the main board is saying that the main board is good and and panel must be out. Please advise
                                  • 12332
                                  • U.S.
                                  #56
                                  thinking if your tv had this same issue with the half dim screen and a GOOD mainboard solved it, then they probably sent you a bad mainboard or it went bad in transport, unless it is a mismatch, check that the numbers on the stickers match.
                                  • tvguy12012012120
                                    by tvguy12012012120
                                    02-07-2025, 05:13 PM
                                  • piposarcade
                                    Samsung UN50KU6300 dead no standby led
                                    by piposarcade
                                    01-04-2024, 01:33 PM
                                    Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it...
                                    05-22-2024, 02:07 PM
                                    09-07-2024, 05:50 AM
                                  • piposarcade
                                    by piposarcade
                                    Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it doesn't turn on.
                                    01-04-2024, 12:03 PM
                                  • ChristianBr01
                                    LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                    by ChristianBr01
                                    I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                    The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                    What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                    04-23-2025, 01:48 AM
