Samsung UN48H5500AF - no standby, no video, no sound, backlights on when plugged in
  • fixitjunkie
    • Feb 2014
    • 39
    Hello All,
    Picked this up at a recycle center with hopes of a simple fix.
    When plugged in, the backlights come on, two blue LEDs on the T-con board illuminate then one goes out. Cycling the on-off switch has no effect.
    On the power supply board there are four test points labeled +, sine wave, sine wave and -. There is 120VAC across the sine waves and 113VDC across
    + and -. All the caps look good.
    I'm not sure where to check for the standby voltage output?
    Shop Jimmy's has plenty of PS boards, Main boards and T-con boards. All three would cost about $70, but if possible I'd like to narrow down any potential fix.
    Any feedback is much appreciated. Thanks!!
  • neilc6
    • Nov 2015
    • 1550
    Re: Samsung UN48H5500AF - no standby, no video, no sound, backlights on when plugged
    Sounds like a bad panel. Disconnect one side of the tcon at a time to see if one side displays half an image. If it does, you can try the tape cutoff method on the bad side. https://techhometravel.com/repair-of...lines-on-a-tv/
    • fixitjunkie
      • Feb 2014
      • 39
      Thanks Neil. I found the test points for DC voltage signals. They all measured 12.6V. Tried the T-con disconnect method one side at a time and no change. Looks like this one is toast. Thanks again for the help.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4456
        • Italy - Milan
        The problem is much probably a small cap or diode on the panel distribution boards.. do this test get a 12v p. supply or make a flying link cable from psu to supply directly the tcon, detach tcon from mainboard, now touch repeatedly fast the tcon fuse with the wire, after some tens of seconds start to feel if some heat reach a component in dist. boards, but detach one board at time, usually there are two, found the warm one desolder it and test tv normally.
        • fixitjunkie
          • Feb 2014
          • 39
          Thanks for the feedback Davi.p. This is going well beyond my capabilities. I'll put this one back in the grave and dig up something else.
          • neilc6
            • Nov 2015
            • 1550
            If no pic from either side, I would try replacing the tcon.
            • dskall
              • Oct 2016
              • 2905
              • usa
              Sounds like bad t-con.
              • handsworth
                • Oct 2015
                • 174
                I have had this problem on similar Samsung tvs. Turned out to be shorted panel board. Disconnect both tcon tabs and look for the blue lights on the tcon when tv is turned on. They should be lit and not go off. Try the tape method on the tabs and see if you get any kind of image. Thats a start.
                  09-07-2024, 05:50 AM
                • nathan425
                  Samsung UN50EH5300 - No Standby LED, Backlights ON, No Power
                  by nathan425
                  Hello, I have a Samsung UN50EH5300 in my possession that I'm looking to bring back to life.
                  Symptoms:
                  • - no power
                  • - no standby LED
                  What I've done so far:
                  - confirmed power supply is OK
                  -- CN201 #4 showing 5.3V
                  -- BD207 showing 5.3V
                  -- removing the cable between the main board and the power board turns on the backlight.
                  Pushing the power button on results in no change to any of the pins connecting the two boards.
                  - function assembly appears to be NO GOOD
                  -- there is no voltage showing on any of...
                  11-01-2023, 06:34 PM
                • ChristianBr01
                  LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                  by ChristianBr01
                  I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                  The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                  What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                  04-23-2025, 01:48 AM
                • Cookybaby
                  Samsung UN60ES6500FXZA Power Supply Issue
                  by Cookybaby
                  Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                  I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                  Make: Samsung
                  Model: UN60ES6500FXZA
                  Power Supply P/N: BN44-00525A
                  Symptoms: The TV was...
                  08-20-2023, 12:26 PM
                  09-06-2024, 11:40 PM
