Samsung ue49mu6120
This topic is closed.
  • mano115
    • Jul 2014
    • 6
    • EEUU
    #321
    Re: Samsung ue49mu6120
    Hi Lotas,
    please fix my dump original tv: not standby led no power
    UN49mu6400FXZX
    bn94-11930C
    bn41-02568A
    • lotas
      • Jan 2016
      • 4608
      • Russia
      #322
      Hi, try.
      • mano115
        • Jul 2014
        • 6
        • EEUU
        #323
        Thanks you Lotas. It's works perfect!
        • lotas
          • Jan 2016
          • 4608
          • Russia
          #324
          Ok!
          • rayden04
            • Feb 2022
            • Cuba
            #325
            Hello Lotas, I have a problem with a Samsung un49mu6290fxza television that does not turn on the standby light or anything, I tried some dumps uploaded by you and now it stays on a red standby LED.
            • lotas
              • Jan 2016
              • 4608
              • Russia
              #326
              Post your own faulty dump here, I will fix it.
              • rayden04
                • Feb 2022
                • Cuba
                #327
                this is
                • lotas
                  • Jan 2016
                  • 4608
                  • Russia
                  #328
                  this is
                  Try.
                  • rayden04
                    • Feb 2022
                    • Cuba
                    #329
                    Try.
                    Perfect, thanks you
                    • lotas
                      • Jan 2016
                      • 4608
                      • Russia
                      #330
                      Perfect, thanks you
                      Ok!
                      • dani.m
                        • Nov 2023
                        • 12
                        • italy
                        #331
                        Hello, I would like to replace the main of a UE55MU6120KXZT with a MAIN of a UE55MU6199UXZG to have the SAT input as well, is it possible?thanks
                        • dani.m
                          • Nov 2023
                          • 12
                          • italy
                          #332
                          If needed, the panel codes are CY-GM055HGHV3H
                          SK09BN9504562AS004JBX0938 JW48
                          2017.11.29 55S6AUVM
                          I already have the CH341A pen and I have already saved the various files
                          • lotas
                            • Jan 2016
                            • 4608
                            • Russia
                            #333
                            If their panels are different, then you will probably have to transfer dump 25Q80 from the original board to the new one.
                            • dani.m
                              • Nov 2023
                              • 12
                              • italy
                              #334
                              grazie per la risposta,ho provato a farlo ma il Tv si comporta allo stesso modo(schermo a righe)forse non ho fatto la procedura giusta nel modificare SREG oppure neoprogrammer mi da nell'elenco la memoria 25q80BV invece di 25q80DV che ho sulla scheda
                              • dani.m
                                • Nov 2023
                                • 12
                                • italy
                                #335
                                thanks for the answer, I tried to do it but the TV behaves in the same way (lined screen) perhaps I didn't follow the right procedure when modifying SREG or neoprogrammer gives me the 25q80BV memory in the list instead of the 25q80DV that I have on the card
                                • lotas
                                  • Jan 2016
                                  • 4608
                                  • Russia
                                  #336
                                  Try changing the panel model to yours in service mode.
                                  • dani.m
                                    • Nov 2023
                                    • 12
                                    • italy
                                    #337
                                    I can't enter service mode, because the screen is unusable with the UE55MU6199 board
                                    the file in the 25q80DV I should have written it in the right way, the only doubt is the list of chips present in neoprogrammer that gives me available a 25q80"BV"and not DV as in my board
                                    • lotas
                                      • Jan 2016
                                      • 4608
                                      • Russia
                                      #338
                                      Download the AsProgrammer program, your flash is there.
                                      • dani.m
                                        • Nov 2023
                                        • 12
                                        • italy
                                        #339
                                        Excuse my ignorance,but I can't find the "detect" button in asprogrammer
                                        • lotas
                                          • Jan 2016
                                          • 4608
                                          • Russia
                                          #340
                                          “detect” what, where? What are you writing about, what button?
                                          1. - IC.
                                          2. - SPI.
                                          3.- WINBOND.
                                          4. - W25Q80DV.
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
