Samsung ue49mu6120
This topic is closed.
  • toptib
    • Apr 2012
    • 18
    • ita
    #421
    I'll definitely try.
    Thank you
    • Donny2derby
      • Apr 2023
      • 228
      • Uk
      #422
      Lotas. The Godfather of eeprom! They will build statues of the great man outside the office of Badcaps!
      If I ever need your help I will be sure to buy you some vodka! Stolinchaya!
      • vendak
        • Jan 2023
        • 12
        • Česko
        #423
        Hi Lotas
        Please upgrade this file for UE55MU6172
        Thank you very much Vendak
        • lotas
          • Jan 2016
          • 4711
          • Russia
          #424
          Originally posted by vendak
          Hi Lotas
          Your dump is working.
          • vendak
            • Jan 2023
            • 12
            • Česko
            #425
            Thank you .
            MB is bad.
            • toptib
              • Apr 2012
              • 18
              • ita
              #426
              Originally posted by lotas
              Replace the chip (25Q40) with a new one.
              New, reprogrammed EPROM, same result. LED on, accepts commands from the remote control but black screen and no backlight.
              MB is faulty.
              Do you know if I can mount other MB on that tv ?
              Thanks anyway for everything.​
              • lotas
                • Jan 2016
                • 4711
                • Russia
                #427
                If the panel is 100% working, then you can install another motherboard (and hope that the motherboard will also work).
                • toptib
                  • Apr 2012
                  • 18
                  • ita
                  #428
                  Thank you for your time​
                  • Sparkitecht
                    • Apr 2024
                    • 5
                    Hi Iotas
                    I wonder if you could help me with a Samsung UE49MU6400U that I think has corrupted the firmware (attached - looks to have lost data at the start of the dump). Symptoms are that the set has no standby light but the PSU is in standby.
                    Your kind help would be gratefully appreciated.
                    Thank you.
                    • lotas
                      • Jan 2016
                      • 4711
                      • Russia
                      #430
                      Originally posted by Sparkitecht
                      Hi Iotas
                      Thank you.
                      Try.
                      • Sparkitecht
                        • Apr 2024
                        • 5
                        Thank you so much Iotas - it worked. I am very grateful for your help with this.
                        I was unable to set the QE bit via AsProgrammer with a CH341 Pro that I bought today. Thankfully I had an older programmer but had to read the IC datasheet to work out the BPx protection areas as it used a different terminology (upper 1/4). I power cycled the TV a few times and it still works!
                        Thanks again - you have saved a TV from thrown out.
                        • lotas
                          • Jan 2016
                          • 4711
                          • Russia
                          #432
                          Ok. I should have tried it with the "NeoProgrammer" program for CH341A.​
                          • Sparkitecht
                            • Apr 2024
                            • 5
                            I will give NeoProgrammer a try should I need to do this again.
                            I noticed that pins 3 and 7 (WP and /HOLD) are tied directly to 3.3V on my CH341 Pro which is not recommended according to the extract from the datasheet below.
                            Thanks again for your kind help!​
                            • lotas
                              • Jan 2016
                              • 4711
                              • Russia
                              #434
                              Yes, this programmer needs improvement, if it is black, then two improvements.
                              • Sparkitecht
                                • Apr 2024
                                • 5
                                Thanks Iotas. It seems I have a CH341 β€œpro” with a CH341B IC that looks the same as the normal black programmer but with a different board layout from yours. It too is putting out 5V on the data lines. I’m surprised that this has not been designed out in newer programmers. I’ll need to remove the ZIF socket to see where the traces go on mine as they are very different.
                                • lotas
                                  • Jan 2016
                                  • 4711
                                  • Russia
                                  #436
                                  Mod 3.3V
                                  • Sparkitecht
                                    • Apr 2024
                                    • 5
                                    Mod 3.3V
                                    Thank you Iotas. I will make that mod. The CH341 datasheet says to connect pin 9 to VCC (3V) when it’s set to 3volts so I will give that a go. Thanks again for your kind assistance.
                                    • Salvocchio
                                      • Mar 2024
                                      • 12
                                      • Cagliari
                                      #438
                                      Hi Lotas. Thank you for the valuable support you provide.
                                      I have the same problem with my Samsung UE40MU6400UXTZ.
                                      Unfortunately, I lost the original DUMP.
                                      I purchased a new W25Q40CL, can you help me in any way?
                                      My programmer is CH341A.​
                                      • lotas
                                        • Jan 2016
                                        • 4711
                                        • Russia
                                        #439
                                        Hi, well, without the original dump, how can I help you, the only option is to select one for your software version, in this thread I posted a lot of corrected dumps, select one (make some kind of adapter, so as not to unsolder and solder each time to check)
                                        Let me add that the diagonal is not important here, it can be any number, and any four-digit number will also work, that is, look for any dump Ux xxMUxxxx.
                                        • Salvocchio
                                          • Mar 2024
                                          • 12
                                          • Cagliari
                                          #440
                                          Thank you. i'll try
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
