Samsung ue49mu6120
This topic is closed.
  • edisarca
    • May 2018
    • mexico
    #121
    Samsung UN55MU6400FXZX
    Hello, could you help me with my file please. Thank you.
    • edisarca
      • May 2018
      • mexico
      #122
      Re: Samsung ue49mu6120
      Originally posted by lotas
      Yes, maybe I wrote about this modding somewhere here on the forum, try this one.
      • lotas
        • Jan 2016
        • 4649
        • Russia
        #123
        Re: Samsung UN55MU6400FXZX
        Try.
        • edisarca
          • May 2018
          • mexico
          #124
          Try.
          It works correctly, I want to buy you a coffee, send me a private message for more details, thank you very much.
          • lotas
            • Jan 2016
            • 4649
            • Russia
            #125
            Thank you! I live far away, I'm glad it worked out.
            • Damian.bak
              • Nov 2022
              • Poland
              #126
              Here, how lucky the T-con settings and the panels are stored in 25q80 (it can be enough to transfer this flash to a new motherboard, and if you look for your panel, you need to call BN94-xxxxxx.
              I have tried "new" motherboard and it works without replacing flash You mentioned. Thanks for help.
              • Yakubusta
                • Nov 2022
                • 19
                • Türkiye
                #127
                hi i bought a new motherboard and it also has a software error. Can you help me fix this?
                BN41-2568A
                • lotas
                  • Jan 2016
                  • 4649
                  • Russia
                  #128
                  Try.
                  • Yakubusta
                    • Nov 2022
                    • 19
                    • Türkiye
                    #129
                    thank you
                    • fanaticgames
                      • May 2017
                      • 138
                      • italy
                      #130
                      Hi, my TV has the correct voltages on the power supply but not from the red LED and it doesn't turn on, I dumped the winbond W25Q80 chip, same problem?
                      • fanaticgames
                        • May 2017
                        • 138
                        • italy
                        #131
                        I attach the dump
                        • fanaticgames
                          • May 2017
                          • 138
                          • italy
                          #132
                          I attach the dump
                          sorry for my confusion, this is the correct IC1604 dump of my BN94-12570V UE55MU6125KXZT board is full of F at the beginning
                          • lotas
                            • Jan 2016
                            • 4649
                            • Russia
                            #133
                            Try.
                            • fanaticgames
                              • May 2017
                              • 138
                              • italy
                              #134
                              Try.
                              nothing, it doesn't work, no red standby led or power, I also checked writing eeprom and set register 0x88 0x42
                              but I have to do the complete deletion of the eeprom first?? Or do I just write the bin file?
                              because I wrote it without doing complete deletion
                              • lotas
                                • Jan 2016
                                • 4649
                                • Russia
                                #135
                                Most likely, your firmware has crashed again when you turn on the TV (you can check your dump again, the header in the dump will be erased, some FF ..., you need to set and write the status register 0x88 and 0x42 after writing the corrected dump, read this thread above, I described there.
                                It is necessary to read and write with the flash soldered, otherwise there may be errors when reading and writing.
                                • fanaticgames
                                  • May 2017
                                  • 138
                                  • italy
                                  #136
                                  yes, I set the registry correctly after writing your dump, I don't think it is altered, I try to unsolder it and read it again and I tell you
                                  I don't use clips, but solder directly on the adapter pcb which I then insert into the programmer
                                  • lotas
                                    • Jan 2016
                                    • 4649
                                    • Russia
                                    #137
                                    Does it pass the test after recording without errors? To avoid errors, you need to program outside the board.
                                    • fanaticgames
                                      • May 2017
                                      • 138
                                      • italy
                                      #138
                                      The bin file is written correctly, I just unsoldered and read to verify
                                      UPDATE:
                                      I compared the read file with the one you sent me and there were slight differences, I completely erased the chip and rewrote it, so is the register correct??
                                      • lotas
                                        • Jan 2016
                                        • 4649
                                        • Russia
                                        #139
                                        Yes, the correct register.
                                        • lotas
                                          • Jan 2016
                                          • 4649
                                          • Russia
                                          #140
                                          What did you do with dump on 25q80, it has nothing to do with "Standbay" (it's related to T-con and panel).
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
