Samsung ue49mu6120
This topic is closed.
  • lotas
    • Jan 2016
    • 4711
    • Russia
    #241
    Re: Samsung ue40mu6400uxzt
    Originally posted by son_goku1976
    caricando il file allegato cambia stato rimane con lo standby a ma non si accende sai dirmi perche' ?
    Was it his native dump, or after recording another dump that you found on the Internet, did you install and write status register 0x88, 0x42 after recording?
      • 21473
      buonasera ..
      Post in english or you will receive an infraction and your posts deleted !!!!!
        • 21473
        Originally posted by lotas
        Try.
        Lotas, please do not reply to members who do not post in english. Thanks
        • son_goku1976
          • May 2023
          • 17
          • Italia
          #244
          okay sorry
          • lotas
            • Jan 2016
            • 4711
            • Russia
            #245
            SMDFlea Ok.
            • son_goku1976
              • May 2023
              • 17
              • Italia
              #246
              ue40mu6400uxzt
              let's say Lotas the original file was the one nicknamed "dump" and it's the one you modified for me .... instead the second is a file that a user from my country sent me which returns the stanby led
              • lotas
                • Jan 2016
                • 4711
                • Russia
                #247
                Re: ue40mu6400uxzt
                If it was his native dump, then I fixed it for you and everything should work, if you messed up something with dumps and the software version does not match the eMMC software version, then the standby mode will appear, and the TV itself will not turn on, you installed after recording and wrote status register 0x88, 0x42?
                • son_goku1976
                  • May 2023
                  • 17
                  • Italia
                  #248
                  Re: ue40mu6400uxzt
                  sorry for my ignorance I don't know how to write the status register...... is it possible that every TV, even the same model, has different dumps? in the event that the 25q40 breaks and the original dump cannot be recovered, how to do it?
                  • lotas
                    • Jan 2016
                    • 4711
                    • Russia
                    #249
                    Re: Samsung ue49mu6120
                    In these models of the "MU" series, it does not matter what diagonal, what model number, the software version is important here and it must match for SPI Flash and eMMC!
                    The Status Register must be installed and written after writing the dump, there are a lot of topics where I explained everything how to do it correctly, what program do you use when writing the dump?
                    • son_goku1976
                      • May 2023
                      • 17
                      • Italia
                      #250
                      neoprogrammer
                      • son_goku1976
                        • May 2023
                        • 17
                        • Italia
                        #251
                        In which section do I find your posts?
                        • lotas
                          • Jan 2016
                          • 4711
                          • Russia
                          #252
                          Yes, you can in this topic from the first page, download AsProgrammer_2.1.0.13_fix, this topic also has it.
                          • son_goku1976
                            • May 2023
                            • 17
                            • Italia
                            #253
                            hello lotas i can't write to the memory anymore ... it doesn't even work erase why ? it says "unprotect ? " but then it doesn't unlock it
                            • lotas
                              • Jan 2016
                              • 4711
                              • Russia
                              #254
                              Programming instructions with the AsProgrammer program.
                              In the program:
                              1. Click "Detect Chip" and select W25Q40CL and "Select IC".
                              2. Click "Unprotect".
                              3. Click "Clear IC" and "Yes".
                              4. Click "Open File" and select your corrected dump.
                              5. Press "Program IC" and "Yes".
                              6. Click "Verify IC".
                              7. Press the down arrow to the right of "Unprotect" and select "SREG Edit", put a check mark on SRP0, BP1, CMP, QE and press "Write" and "Yes"
                              7. Close the program. Ready.
                              • son_goku1976
                                • May 2023
                                • 17
                                • Italia
                                #255
                                thanks for the guide ....... I don't know why but I can only read and do nothing else ........ before it stopped working it didn't let me tick "QE"....
                                • son_goku1976
                                  • May 2023
                                  • 17
                                  • Italia
                                  #256
                                  Samsung ue40mu6400
                                  hello..... could the 25x40 replace the 25q40 ....? I recovered this chip from another card waiting for the new chip
                                  • son_goku1976
                                    • May 2023
                                    • 17
                                    • Italia
                                    #257
                                    hello lotas .... would you be so kind to try to correct this dump of my tv? I doubt that what I posted and you kindly corrected me is not the right one ... I attach another file to try to correct ... thanks in advance ..
                                    • son_goku1976
                                      • May 2023
                                      • 17
                                      • Italia
                                      #258
                                      thanks ..... solved with the first dump where I followed the programming step by step edited the file fi register except the QE which did not make me tick .... so I only ticked SRP0, BP1, CMP, ... .. and it worked...... thanks thanks thanks ....... you are number one !!!!
                                      • son_goku1976
                                        • May 2023
                                        • 17
                                        • Italia
                                        #259
                                        however in the end I left the 25x40 chip instead of the 25q40......
                                        • lotas
                                          • Jan 2016
                                          • 4711
                                          • Russia
                                          #260
                                          25"Q"40 - has QE (Interface: Quad SPI)
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
