Samsung ue49mu6120
This topic is closed.
  • bohaboha
    • Nov 2012
    • 1017
    • sweden
    #461
    Hi lotas I don't want to interfere in something that I don't understand but I'm being confounded because you saying in post 442 that you have to make a change on CH341A and I've seen on Youtube Sorin (Electronic repair school) prove that you don't need to make any change at all because there is no high ampere that can destroy any component.I would like to understand to learn and i see that you know what you are talking about . explain to me please
    here is the video: https://www.youtube.com/watch?v=J8-Sh7DjiXw&t=27s
    • Diah
      • Feb 2013
      • 6427
      Originally posted by lotas
      Open the datasheet on CH341A and look at 9 pin if you switch to 3v power supply. In the circuit for modification, there is no need to remove the capacitors, but replace them with tantalum of higher capacity.
      https://4pda.to/forum/index.php?show...st&p=125980884
      lotas i know you related to documents when you advice... but what i have no need to change at all.... the early version of this programmer as the diagram you posted yes nut now days no more in the market.... just the new version black one.
      • lotas
        • Jan 2016
        • 4711
        • Russia
        #463
        Originally posted by toptib
        panel CY-KK040HGNV2H
        tv UE40MU6400UXTZ
        There is only a dump for CY-KK040HGNV2V - the difference is in the last letter, try it and lastly try writing down the eeprom IC801 24C512 (UE40MU6400U).
        • lotas
          • Jan 2016
          • 4711
          • Russia
          #464
          Diah yes, I’m not forcing anyone here to remake this “programmer”, let everyone decide for themselves and do it at their own peril and risk, I don’t use it at all, I have more expensive programmers that I trust (UFPI, RT809F,H, Nand ProMan, TL866CS, TL866 II Plus, Xeltek SuperPro 3000U, 611S, Z3x easy jtag...)
          • bohaboha
            • Nov 2012
            • 1017
            • sweden
            #465
            Hi lotas, I'm really sorry if I've hurt you, it was absolutely not my intention and wise, you don't force anyone to change or keep original programs, I just wanted to learn, hope you accept my apology and share your knowledge with us.
            • toptib
              • Apr 2012
              • 18
              • ita
              #466
              Nothing to do, even writing both of them remains the same problem I think it's definitely the processor bad.
              Lotas Thanks anyway
              • lotas
                • Jan 2016
                • 4711
                • Russia
                #467
                Yes, everything is fine!
                • Salvocchio
                  • Mar 2024
                  • 12
                  • Cagliari
                  #468
                  Hi Lotas.
                  do you ultimately recommend that I do the modification or not?
                  I have ordered the tantalum capacitors and the 4.7 Khom resistors.
                  In post n. 455 you refer to a link where however in the schematic I do not see the two 4.7 Khom resistors.
                  Please suggest what to do? I am not able to make up my own mind.
                  I would like to remind you that my problem is that I cannot set the registers.​
                  • lotas
                    • Jan 2016
                    • 4711
                    • Russia
                    #469
                    Originally posted by Salvocchio
                    Hi Lotas.
                    Yes, resistors must be placed in the gap between the tracks.
                    And it is better to use the program "NeoProgrammer V2.2.0.10"
                    And register may not be installed, because there may be protection, first you need to remove the protection, that is, uncheck all the boxes, click “Write”, erase the chip, write dump and then install status register.
                    • Salvocchio
                      • Mar 2024
                      • 12
                      • Cagliari
                      #470
                      Yes, I performed the sequence given in your description
                      but it doesn't work.
                      It does not store 42 in the first register.
                      When I read it back it gives me 40.
                      Do you think it is a programmer's problem and I need to make the change?​
                      • lotas
                        • Jan 2016
                        • 4711
                        • Russia
                        #471
                        Anything is possible, what program do you use?
                        • lotas
                          • Jan 2016
                          • 4711
                          • Russia
                          #472
                          Status register 0x42 should be in the second, that is, 0x88, 0x42.
                          • Salvocchio
                            • Mar 2024
                            • 12
                            • Cagliari
                            #473
                            yes, sorry, the second register.
                            I use ASProgrammer​
                            • lotas
                              • Jan 2016
                              • 4711
                              • Russia
                              #474
                              Use NeoProgrammer V2.2.0.10
                              • Salvocchio
                                • Mar 2024
                                • 12
                                • Cagliari
                                #475
                                ok. Are tantalum capacitors 4.7 uf at 10 volts and 22 uf at 10 volts okay ?
                                Is the voltage at 10 volts okay?​
                                • lotas
                                  • Jan 2016
                                  • 4711
                                  • Russia
                                  #476
                                  Of course, the maximum usb voltage is 5v, just install the capacitors correctly (they have + and - polarities).
                                  • JoeFlash
                                    • Dec 2021
                                    • 17
                                    • Hungary
                                    #477
                                    Hi! I have a TV, Samsung ue49ku6100, no boot, when connect the power cord, the leds are up and down repeated. When i disconnect the MB, the leds are up.
                                    I have an IC programmer: CH341A
                                    MB model: BN41-02528
                                    MB code: BN41-02528A
                                    I found 2 winbound chip, 25q40cl and 25q80dvs. Which IC is need to dump?
                                    edit: on the glued label: BN94-10826K
                                    • alex39t
                                      • Nov 2013
                                      • 50
                                      • greece
                                      #478
                                      iotas my goodfriend i want your help one more time and for xgecu how to put protect mode?
                                      • lotas
                                        • Jan 2016
                                        • 4711
                                        • Russia
                                        #479
                                        This dump is working, and the status register is like in the photo.
                                        • alex39t
                                          • Nov 2013
                                          • 50
                                          • greece
                                          #480
                                          You said that dump i have is good?
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
