Samsung ue49mu6120
This topic is closed.
  • lotas
    • Jan 2016
    • 4711
    • Russia
    #501
    Originally posted by Martin_CZ
    working. Thank You
    Ok! I had no doubt.​
    • Jeffaas
      • Jan 2021
      • 11
      • Nederland
      #502
      hi Lotas, if you have any time. could u please check my dump? Kind regards!!!!
      • lotas
        • Jan 2016
        • 4711
        • Russia
        #503
        Hello, yes there is time, ready, try it.
        • Jeffaas
          • Jan 2021
          • 11
          • Nederland
          #504
          Many many thanks again!!! Works perfectly!!
          • lotas
            • Jan 2016
            • 4711
            • Russia
            #505
            It's good that it works!
            • Muflo58
              • Jul 2024
              • 6
              • Italia
              #506
              i have same problem with:
              UE49MU6120K
              BN41-02568A
              can i use same file?
              in case of not, attached is my file
              • lotas
                • Jan 2016
                • 4711
                • Russia
                #507
                UE49MU6120K
                BN41-02568A
                Try.
                • Muflo58
                  • Jul 2024
                  • 6
                  • Italia
                  #508
                  Thank you,
                  but in my Asprogrammer, the bit QE is not enabled! (see attached)
                  • Muflo58
                    • Jul 2024
                    • 6
                    • Italia
                    #509
                    The version is 2.1.0.13
                    • lotas
                      • Jan 2016
                      • 4711
                      • Russia
                      #510
                      Thank you,
                      You need to install the program "NeoProgrammer V2.2.0.10".
                      • Muflo58
                        • Jul 2024
                        • 6
                        • Italia
                        #511
                        Thank, it works now.
                        The TV power on but there are horizontal lines on display.
                        I'm afraid I broke the glass while opening it.
                        Do you agree?
                        • lotas
                          • Jan 2016
                          • 4711
                          • Russia
                          #512
                          Do you agree?
                          I don't see, I can't say anything, maybe the panel was damaged, you know better.
                          Maybe the thin cables that go to the glass were damaged, when removing the back cover.
                          • Muflo58
                            • Jul 2024
                            • 6
                            • Italia
                            #513
                            No,
                            i see some irregular signs on the glass, it is broken for sure.
                            I think it was already broken when they carried it to me.
                            Thanks for all.
                            • Szymon095
                              • Jul 2024
                              • Poland
                              #514
                              Hi Lotas,
                              Could you help me with my bin file?
                              UE49MU6402U
                              BN41-02568A
                              Thanks, Szymon
                              • lotas
                                • Jan 2016
                                • 4711
                                • Russia
                                #515
                                Originally posted by Szymon095
                                Hi Lotas,
                                UE49MU6402U
                                BN41-02568A
                                Thanks, Szymon
                                Hi, but yours is working, it’s not the problem.
                                • crystalsound
                                  • 15
                                  • italy
                                  #516
                                  Hi, mine is starting, staying some seconds with audio and backlight but no video, then off and reboots. Does this even with panel ribbons disconnected, so I assume it's a firmware issue. Can you fix this for me? I dumped mine and tried some files you posted but i get no standby at all. I flash it with tl866 and minipro, and i am able to set the register stuff, although with a different procedure. Thank you!
                                  • lotas
                                    • Jan 2016
                                    • 4711
                                    • Russia
                                    #517
                                    The TV model must also be indicated and the motherboard number! Some kind of dump you have is strange, or it’s poorly read or strangely damaged (this is the first time I’ve seen something like this), try this...
                                    • crystalsound
                                      • 15
                                      • italy
                                      #518
                                      You're right it's ue49mu6120k, mainboard bn41-02568a bn94-12644a. May the problem be related to my programmer? I've been using it for 10 years so far and never had any problems with it.
                                      • lotas
                                        • Jan 2016
                                        • 4711
                                        • Russia
                                        #519
                                        I can’t say anything about your programmer, maybe there was a bad contact with 25Q40, long wires (if you used it through a clothespin), I don’t know how you read the dump...
                                        • crystalsound
                                          • 15
                                          • italy
                                          #520
                                          Just as i always do, unsolder the chip, put in the socket, i think everybody does like that, or am i wrong?
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
