Olevia Syntax Brillian 537-B11 tuning itself off + image going blank
  • mob809k
    • Apr 2010
    • 7
    I have an Olevia 537 B11 that has 2 problems.
    at first it started turning itself off by itself. i double checked if there was any kind of sleep timer but sadly found out on the internet that it was a common issue.
    i am not sure wich is the part that i have to change for that. i took the power supply to a technician and he told me that it looker ok. ut i understand that the looks of things do not mean much. i figured that i was going to keep using the TV that way. sometimes i went for days and weeks working good then, the ghost in the machine came and turn it of in different intervals of time. sometimes minutes, hours.
    But recently a new issue came to my attention a saw your comment on a thread. Now, when i turn the tv on the image blinks, then it stabilizes then after 15 minutes or so goes blank. i still have sound but no image.
    i am hoping you tel what parts can be affected so i can get them and fix my own tv.
    The fact is that i live in the dominican republic and is very hard to find a decent technician here.
    Thank you.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Olevia Syntax Brillian 537-B11 tuning itself off + image going blank
    Thank you.
    I understand how you feel. I live in the USA, and it is hard to find a decent technician here too!!!
    The next time the TV goes blank (but still has sound), try to see if you have anything on the screen. Sometimes shining a flashlight on the screen in a dark room will help. If you can see a faint image, there is an inverter problem. That may be fixable.
    PlainBill
    • mob809k
      • Apr 2010
      • 7
      Finally. After several days it did it again. I checked for ghosts in the screen. nothing there, all blank. The screen appears to be off.
      before it goes blank the screen starts to blink. it goes dark and bright then it goes off.
      when i turn the tv on it does blink but after a few seconds it becomes stable.
      Any ideas?
      • PlainBill
        • Feb 2009
        • 7034
        Any ideas?
        Yeah, it's probably not the backlight system.
        PlainBill
        • iKitsune
          • May 2010
          • 61
          Check the power supply - my Syntax Olevia 42" LCD had bad caps in the power supply section, and the 537-B11 (yours) and the 542-B11 (mine) share a power supply design.
          • mob809k
            • Apr 2010
            • 7
            What was your tv doing?
            • mob809k
              • Apr 2010
              • 7
              Plain bill if it is the backlight system what do I have to do?
              • PlainBill
                • Feb 2009
                • 7034
                IF it is the backlight system you have to fix it. But first you should determine if the backlights were switched off by the mainboard, or were shut off by the inverter controller because of a fault. Hint: Take a look at the cable connecting the inverter to the main board. Is there a label there indicating the function of the pins?
                PlainBill
                • iKitsune
                  • May 2010
                  • 61
                  Pretty much exactly what you described until one of the caps said "Pop!" and it stopped powering on at all.
                  • mob809k
                    • Apr 2010
                    • 7
                    any recommendation on what to do first?.....
                    should i change the caps of the power supply then try the other cards?
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Any obviously bad components should be replaced, especially bulging caps in the power supply. If the TV still isn't working, THEN start looking for other problems.
                      PlainBill
                      • iKitsune
                        • May 2010
                        • 61
                        Replacing the 10 caps on the power supply secondary side brought my unit back to perfect operation.
                        I didn't actually measure the voltages, but I imagine with the caps in the shape they were in they weren't in spec, and the rest of the set couldn't operate properly with the voltages all jacked up.
                        • tmwalsh
                          • Jan 2009
                          • 119
                          What has not been mentioned is the 'type' of capacitors you used for replacement. Generally speaking, you want 105C heat rating & "Low ESR" for replacements in SMPS, which is what most sets will have.
                          If you used generic RadioShack capacitors, they might not last as long as you would wish.
                          tom
                          • mob809k
                            • Apr 2010
                            • 7
                            Thanks. Very usefull!
                            • skytribe
                              • May 2011
                              I've got a 537H and experienced the same problem - have a new power board to replace.
                              Any hints/tips on getting opening up the TV to get to the power box. I'd searched for a service manual with details of where all the screws are but to no avail.
                              • Village Electronics
                                OldPro
                                • 118
                                PlainBill
                                There are hundreds of highly qualified TV service people in the United States. Locating them is easy. You can search via the manufacturer's website. Zipcode will find the closest authorized service center. Those centers are already familiar with the product and have a working relationship with the producer of the product. You can search via NESDA.
                                http://www.nesda.com/
                                and there are other trade groups that have search-able zipcode locators.
                                • daimoku
                                  • Feb 2011
                                  • 85
                                  I have an Olevia 237-S11 which uses the same power supply AEP016-37.
                                  The power supply uses a combination of United Chemicon (UC) KY series and Elite caps. Found several high ESR, out of spec Elite caps so I replaced all the Elite caps. Left the UC caps.
                                  Unfortunately, I believe I found the source of my intermittent problem too. In my case, the tv would sometimes run for a day or two and other times just a couple of hours. When it stopped running, it would power off (no sound, no video, no dim screen), but I could turn it back on immediately. Through experimentation, I determined the problem is heat sensitive. Last night, I found a lifted trace at C33 when I was replacing the Elite brand capacitors. I should have addressed it then instead of proceeding with replacing the cap at that location; I exacerbated it when I desoldered and soldered the new cap (see the attached image).
                                  I haven't had a chance to repair it yet, but hopefully that will take care of it. I'll report back when I get a chance to repair and test the results.
                                  • PlainBill
                                    • Feb 2009
                                    • 7034
                                    I tried that with my Mitsubishi DLP TV. The phone numbers listed were no longer in service.
                                    Someone else tried that with an LG Plasma TV. The shop charged him $50 to diagnose the problem as the Y-Sustain and Y Buffers at a repair cost of over $500. The owner sold the TV to me. When I opened it up I saw no sign it had been previously serviced - no marks on the screws, no dust disturbed inside. The problem was the Z-Sustain.
                                    Yes, there are plenty of good, honest technicians. The problem is finding them.
                                    PlainBill
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      Are you going to resolder or run a jumper wire? I would love to see a picture of whatever repair you decide to do.
                                      --- begin sig file ---
                                      --- end sig file ---
                                      • mob809k
                                        • Apr 2010
                                        • 7
                                        SkyTribe, i actually solved my problem. i first changed the power supply but didn't fix the problem so i had tu buy the other 2 cards. unfortunately i had a technician come in that dropped a bare cable on the power supply and fried my tv so i had to change the main board also.
                                        i found all the parts on ebay for around 200 dollars.
                                        i should have bought a new TV for 100 more, but life is life.
                                        good luck with your repair.
                                        Mario
                                        • hasel17
                                          CH341a can erase and read but can't write and blank check
                                          by hasel17
                                          So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
                                          Code:
                                          Checking for blank...
                                          (Press
                                          10-26-2023, 06:20 AM
                                        • kotel studios
                                          Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
                                          by kotel studios
                                          Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
                                          State I got it in:
                                          Squealing from the PSU
                                          After logo I get a blank screen
                                          After 10 seconds of having a blank display w/ backlight the TV dies
                                          Give it 7-10ish seconds again and it starts to bootloop.
                                          What I did so far:
                                          Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
                                          Checked all voltage rails:
                                          5VSB - 4.8V
                                          AMP+13V - 14.4V
                                          13V - 12.98V (in manual 12V)...
                                          09-21-2025, 02:00 AM
                                        • RetroComputingGrotto
                                          Hanns.G Hi221 Monitor - Works For A Second & Then Blank Display
                                          by RetroComputingGrotto
                                          I've got a Hanns.G Hi221 Monitor that works for a moment and then the display goes off but the power LED indicator remains on. If you power it off and back on again it does the same thing, it comes on and then the display goes blank. From a cold start it takes 10 seconds or so before the display goes blank but if you turn it off and then back on again after it already being on it goes blank a lot quicker so I'm assuming something is getting hot which is causing the display to go off.
                                          I've uploaded a video of it happening on YouTube:
                                          I've taken the monitor...
                                          01-11-2024, 05:37 AM
                                        • Chrissygizmo
                                          Panasonic TX-48CX350B backlights but white screen , blank screen
                                          by Chrissygizmo
                                          Hi all, I’ve got a problem I hope someone can help me fixi.
                                          I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                                          01-11-2025, 03:18 PM
                                        • Spoonicks
                                          ASUS VH238T blank screen with backlight
                                          by Spoonicks
                                          I am having a problem with a ASUS VH238T.
                                          The monitor started by just going blank, but the integrated speakers, and the backlight worked. The OSD didn't pop up, neither did the messages of DVI No Signal, nor the Asus logo.
                                          Turning off the monitor, and turning it back on made no difference. But leaving the monitor off for a few hours returned the monitor back to normal. The problem will eventually return after a couple of hours.
                                          Today, it started exhibiting another symptom: the display started showing a white image, that didn't take the whole screen....
                                          07-04-2023, 01:29 PM
