LG 65UJ6300 no backlight unless TCON disconnected.
  • BakaMonogatari
    • Oct 2021
    • 6
    Full model of the TV is 65UJ6300-UA.BUSYLOR. TV was given to me by a relative as non-operational so I'm trying to get it working so I have a nice cheap upgrade for my living room. This is my first TV repair so if it sounds a little like I know what I'm talking about, I don't.
    TV turns on and has audio, but backlight doesn't turn on. Getting 230v from LED+ to chassis. Also can't see anything with flashlight test. Another forum suggested I replace the LED strips because that's the most common failure on LG TV's and the flashlight test doesn't always show results.
    Replaced LED strips. Powered TV on with TCON disconnected so I can test to see if the LED's were working before reinstalling panel, and they came on. Reassembled TV. Same problem as before. Disconnected TCON from main board again, backlights come on. Reconnected TCON to main and then tried disconnecting the two cables from TCON to panel. No lights.
    So basically the backlights only come on with the TCON disconnected from the main board.
    So....bad TCON?
    I tried finding a schematic for this TV and came up with nothing. I did find a repair manual for one that uses the same power supply board and did voltage tests according to that and everything seems in spec. Any help would be appreciated.
  • CapLeaker
    Leaking Member
    • 7988
    Re: LG 65UJ6300 no backlight unless TCON disconnected.
    what are the voltages BLon and DIM signals? It does appear a TCon fault. If you can find a cheap Tcon, try it!
    • alfatv
      • Sep 2020
      • 353
      Disconnect cables from Tcon to panel one at the time. And make sure they are connected properly.
      • BakaMonogatari
        • Oct 2021
        • 6
        I don't know where the BLon and DIM signals are. The only thing I was able to find is a repair manual from a different TV that happens to use the same power supply board (image attached). There's only the single 12 pin connection going between the power board and the main board and none of the pins are labeled backlight or dim. Maybe it's the MS level pin on pin 11? Idk. Or more likely PDIM on Pin 12 but I don't know what it's supposed to be. All of those voltages the manual describes at least check out in any case except P801 1-7 which makes sense because the backlight isn't on.
        Also it should be noted that TV who's repair manual I'm using doesn't appear to use a TCON board (must be all built into the main board) so there aren't any helpful diagnostics I can use.
        Tried that already.
        I'm just going to go ahead and order the 3-board set and see what happens. It's cheap enough.
        • diif
          • Feb 2014
          • 6978
          • England
          Originally posted by BakaMonogatari
          Tried that already.
          And the result was? If the driver board is at fault then you're just wasting money buying boards.
          • BakaMonogatari
            • Oct 2021
            • 6
            The result was the same. Left one only disconnected, right one only disconnected, both of them disconnected. Same result. No backlight.
            • alfatv
              • Sep 2020
              • 353
              I just changed backlights on the same TV.
              I also saw no backlights and TV turning off after connecting LCD.
              Besides cables from T-Con, there are 2 other flex cables connecting sections of long boards to LCD.
              Make sure all cables are connected properly, it worked for me.
              • BakaMonogatari
                • Oct 2021
                • 6
                Just figured I'd post the conclusion. It was the TCON. Works perfectly now. Wish I didn't put myself through the trouble of changing the LED's for no reason but that was a $30 and a couple of hour mistake. At the end of the day it cost me less than $100 to fix this TV I got for free so I'm happy.
                • Xechnology
                  • Nov 2021
                  Hey there what was the model number for the T-Con board and where did you get it?
                  • BakaMonogatari
                    • Oct 2021
                    • 6
                    6870C-0689A was the one that was in my TV and I got it from shopjimmy.com. Be aware that the TV can also come with 6870C-0750A which is incompatible. You need to check which number you have and make sure you get the right one.
                    • shelby5041
                      Samsung LCD TV no picture backlight on no 12v at tcon
                      by shelby5041
                      hi
                      i have a samsung lcd tv
                      it powers on with sound and backlight but no picture
                      all voltages from PS are good 12v 3.3v and 5v
                      whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                      i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                      no 12v at the tcon fuse
                      i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                      the odds of having 2...
                      10-08-2021, 08:21 AM
                    • stylishconsultant
                      un60j620dafxza - Samsung No Display Problem
                      by stylishconsultant
                      Hi All,
                      Need help.
                      I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                      So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                      problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                      might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                      09-04-2024, 03:26 AM
                    • x_orange90_x
                      TCL 50S535 bad tcon or panel issue?
                      by x_orange90_x
                      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                      03-29-2025, 11:02 PM
                    • griesemaster
                      Sony XBR-49X900E - is this salvageable?
                      by griesemaster
                      I obtained a Sony XBR-49X900E with the following behavior:
                      -Powers on
                      -No Smart Core led code
                      -Backlight on when TV powered
                      -Display shows breathing/moving green blobs on a black background
                      Using the service manual, I decided to replace the TCON and see any changes. After replacing TCON the following behavior presented itself:
                      -Powers on
                      -Smart Core alternating orange/green pattern infinitely
                      -Display fully black
                      Following some threads I found here, I tested the following options....
                      05-19-2022, 12:16 PM
