Samsung un50nu7090 standby light blinks once
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4316
    • Italy - Milan
    Re: Samsung un50nu7090 standby light blinks once
    so if neither turn on the tcon then the software doesn't start, it is possible that it's faulty the standby software that is inside a spi flash i think (ic503), less probably the main software, but which voltage do you find on other come coils?
    • liquidzorch
      • Oct 2016
      • 134
      • mexico
      Here is the same photo, with squares indicating the voltages on each coil. Please note that the coils on the right side that seem to be tcon, and speakers, none have voltage, they get powered from the two mosfets I marked with an arrow, and these mosfets never get an ON signal. The rest of the voltages are present.
      https://photos.app.goo.gl/xSdC1ubn8Rwmwp128
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4316
        • Italy - Milan
        Power section is good, remain software or cpu desoldering..
        • liquidzorch
          • Oct 2016
          • 134
          • mexico
          My money is on software issue, I have heated the cpu to see if there was any difference while hot, and nothing. The only problem is I can not find any information on programming or where to find the firmware. I have found a firmware update on the webpage, but I am guessing that is not the main firmware, and if it was, I have no idea how to flash the nand. I have epeirence in computer bios programming, so maybe I could flash the eeprom, but I cant find any files or info on this board at all.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4316
            • Italy - Milan
            have you access to ****************? if yes one attempt is to search for the spi flash firmware.
            • liquidzorch
              • Oct 2016
              • 134
              • mexico
              #26
              What ever you said seems to have been censored. I have searched all week for firmware files, but have not found any.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4316
                • Italy - Milan
                #27
                have you got acccess to main Russian sites?
                • liquidzorch
                  • Oct 2016
                  • 134
                  • mexico
                  #28
                  No. I have no idea what site that would be. I normally don't fix tv's, just laptops and video game consoles. But anyway, the client called me today saying that she would prefer to just pick it up as is and sell as junk, so now I have to remove the LEDs and give up I guess.
                  • ChristianBr01
                    LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                    by ChristianBr01
                    I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                    The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                    What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                    04-23-2025, 01:48 AM
                  • Elecfronicsssss
                    DA0NJJMBAG0 charging light blinks
                    by Elecfronicsssss
                    Laptop motherboard DA0NJJMBAG0
                    PROBLEM-WHEN I PLUG THE CHARGER WITHOUT BATTERY THE CHARGING LIGHT BLINKS AND WHEN I PRESS POWER BUTTON THE CHARGING LIGHT STOPS BLINKING AND STAYS ON BUT THE POWER LIGHT DOESNT TURN ON AND LAPTOP ALSO DOESNT TURN ON NO FAN SPINS NO KEYBOARD LIGHT.
                    CHECKED- ON S5 STATE TGE LAPTOP HAS 5V ON USB 3.3V BUT I DIDNT GET 1.8VOLTS ON BIOS PIN NO 8 WHILE PLUGGED IN AND EVEN ON S5 STATE.
                    GUIDE ME WITH THE PROBLEM..
                    SUMMARY-
                    1.NO 1.8VOLTS ON BIOS PIN NO 8.
                    2.S5 STATE ((PRESSING POWER BUTTON)))VOLTAGES ARE PRESENT...
                    05-12-2025, 02:32 AM
                  • Jackching
                    Samsung UN46EH5000F wont turn on. Blinks red standby light continuously
                    by Jackching
                    I know for sure it has a bad cap and one cold solder joint. Just wondering before i order the Caps if anyone has any experience with this model? Just making sure there isnt a common component that goes bad besides the caps....
                    04-15-2024, 05:14 PM
                  • billg123
                    NEC E464 no picture/backlight, standby light blinks on 10s interval
                    by billg123
                    Hoping you might be able to help me with an odd issue. I have a bank of 4 NEC E464 commercial screens that have been running on an ~8hr cycle for maybe 5 years. I unplugged them during some electrical work, and when I plugged them back in, one refused to come back up. It doesn't respond to the hard buttons or the remote at all. The main "clue" I have to work with is that the standby light blinks twice on a 10-second interval. I can't find a technical manual for these screens to see what that indicates. I've already tried many of the easy internet suggestions (plug...
                    04-23-2022, 06:03 PM
                  • AleMonti
                    LG 55EG910V - no power and no standby light
                    by AleMonti
                    I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                    I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                    The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                    After checking the basics I did the following:
                    • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                    11-04-2024, 05:02 PM
