Samsung Power Supply Board BN44-00150A
    There is a diode (DS 805) on the secondary side. Can anyone tell me what are the specs for this diode? It is a shotkey diode as the name tells it. Where to purchase it?
    Thanks.
    Re: Samsung Power Supply Board BN44-00150A
    what is written on the diode ?
      DS805 is likely ok, it is across the relay coil. This is likely not the problem with the power supply. Post the problem you are having with the power supply.
      Post pictures of the board, it is likely bad capacitors in the secondary
        The diode seemed shorted so I tested the diode out of circuit and it was fine. Later I misplaced the little diode and can't find it so I have to get it's replacement. I guess it's a fast switching diode and operating voltage of 200 should be fine. Any comments?
          1n4148 or similar for the snubber diode .
            I suspect the original was a UF4007 based on a similar schematic
              Thanks Petehall347 and R_J for your help.
                Hi Folks, This power supply was making a clicking sound and taking a long time to start. I looked it up and apparently it's a buch of bad capacitors. There are 13 of them, all high temp, 4 of each of 47 mf, 1000 mf at 25v, and 1000 mf at 10v. I don't see any other caps or components suffering from heat. Is there anything else I should check before I start taking them out and replacing them? Thanks in advance for replies.
                  I would recommend replacing all capacitors under 100uf in value because they have a tendency to dry out of electrolyte and cause all kinds of issues and if you have an ESR capacitor tester I would probably check all of the other capacitors on the switching power supply section of the board at a minimum
