PHILIPS 42PFL7404 no back-light
  • biogon
    • Sep 2021
    • 7
    • España
    I have a problem with the back-light on a 12-years-old PHILIPS 42PFL7404 TV with DELTA DPS-298 power supply. Screen time is 11000h. A month ago the image started to flicker slightly and after a minute it turned off, but keeping the audio. It was necessary to disconnect from the line to turn it on again, with the same symptoms (Error code:17). The PSU seems to have all the components and welds fine. For a while I ran it without the back cover and it held up well without shutting down. With a heat fan I looked for the susceptible area and found it in the return circuit and supervision of the power supply (everything related to the zener IC953 and the opto PC901); when warming in for 5 " at 100ºC the same phenomenon occurred and it turned off.
    If anyone has had this problem or experience with this power supply I would appreciate an answer.
  • William1967
    • Nov 2017
    • 217
    • Netherlands
    Re: PHILIPS 42PFL7404 no back-light
    Check the 4 capacitors between the transformer and the backlight output cables.
    • biogon
      • Sep 2021
      • 7
      • España
      Thanks for your answer. I have already checked those 4 HV capacitors and both appearance and value seem correct. These 4 caps according to the scheme are used in the out volt-current-arcs inverter supervision sub-circuits. I have seen PS with caps problems and the look of those capacitors was very bad, but...
      • re-atari
        • Oct 2010
        • 136
        This PSU is used on the 8404 series (42" and larger models) as well. There's an electrolytic cap underneath the tunnelshaped cooling plate, which is known to go bad.
        Not the best place to put an electrolytic cap...
        re-atari
        • biogon
          • Sep 2021
          • 7
          • España
          re-atari
          But, when the back-light goes off all the other systems work; audio, tuner, IR remote, led signaling...And the error shown is: (Error code:17) -> back-light problem.
          • biogon
            • Sep 2021
            • 7
            • España
            That cap is in the main line input rectifier.
            • chestercc
              Philips TV Backlight Repair
              by chestercc
              So i'm trying to replace the LED's in a Philips TV. It's 42" with a 715g7262-p01-000-0010 backlight driver board based around an O2 Micro OZ9902CGN.
              My issue is when I replace all the LED's on one board with the new 3V 300ma ones they immediately burn out when the set is powered again. I previously tried the same thing with 6V LED's and the backlight flickered for a bit but wouldn't start.
              The original LED's which I removed which are still working start to melt and burn when given more than 3V on DCPS so I know they shouldn't be higher voltage ones.
              11-18-2022, 01:15 PM
            • ohren
              Trying to control Philips backlight manually with PWM — brightness increases with frequency...?
              by ohren
              I raised the question of whether PWM on the power board "dim" pin would be a reasonable assumption for controlling the backlight of a Philips TV (55put6101/12): https://www.badcaps.net/forum/troubl...d-tv-backlight. I didn't receive any insights there so I went ahead and tried it.
              The setup is basically:
              Rpi3 hardware PWM → 220 Ohm → NPN transistor → dim pin
              Transistor is switching the 3.5 V supply on the power board....
              12-05-2024, 11:10 AM
            • ovrax
              Philips 55PUS6804/12 turn on & off (probably backlight issue)
              by ovrax
              First of all, please excuse me as I'm quite new to this field.
              I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
              I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
              The Ambilight works perfectly and stays on.
              No sounds.
              Thanks in advance.
              08-25-2024, 04:33 AM
            • triplefour
              by triplefour
              09-13-2023, 10:43 PM
            • DoOm86
              philips 55pft5500/12 Backlight issue. What am I doing wrong?
              by DoOm86
              TV philips 55'' no backlight (image ok).
              I tested the backlight with my led tester from the unplugged connector cable and it lights up. I had voltages at the motherboard connector, but anyway I order a new psu. Same problem, same voltages. Disassembled the TV and checked every strip with my led tester, they all light up, same voltage for every pair of strip (they go two by two).
              What am I missing?
              And something else I don't understand. I checked and I have 3v Leds, 10 per strips. Why every pair of strip (so 20 Led) take about 32v when powered up with my led tester 🤔
              04-16-2024, 03:47 PM
