Try our *UPDATED* boardview, bios, & schematic search. Over 2.3 million files for download!
PHILIPS 42PFL7404 no back-light
  • biogon
    replied
    Re: PHILIPS 42PFL7404 no back-light
    Originally posted by biogon
    But, when the back-light goes off all the other systems work; audio, tuner, IR remote, led signaling...And the error shown is: (Error code:17) -> back-light problem.
    That cap is in the main line input rectifier.
  • biogon
    replied
    Originally posted by re-atari
    This PSU is used on the 8404 series (42" and larger models) as well. There's an electrolytic cap underneath the tunnelshaped cooling plate, which is known to go bad.
    Not the best place to put an electrolytic cap...
    re-atari
  • re-atari
    replied
    re-atari
  • biogon
    replied
    Thanks for your answer. I have already checked those 4 HV capacitors and both appearance and value seem correct. These 4 caps according to the scheme are used in the out volt-current-arcs inverter supervision sub-circuits. I have seen PS with caps problems and the look of those capacitors was very bad, but...
  • William1967
    replied
    Check the 4 capacitors between the transformer and the backlight output cables.
  • biogon
    started a topic PHILIPS 42PFL7404 no back-light
    I have a problem with the back-light on a 12-years-old PHILIPS 42PFL7404 TV with DELTA DPS-298 power supply. Screen time is 11000h. A month ago the image started to flicker slightly and after a minute it turned off, but keeping the audio. It was necessary to disconnect from the line to turn it on again, with the same symptoms (Error code:17). The PSU seems to have all the components and welds fine. For a while I ran it without the back cover and it held up well without shutting down. With a heat fan I looked for the susceptible area and found it in the return circuit and supervision of the power supply (everything related to the zener IC953 and the opto PC901); when warming in for 5 " at 100ºC the same phenomenon occurred and it turned off.
    If anyone has had this problem or experience with this power supply I would appreciate an answer.
    Premium supporters get full download access and other benefits.
  • ohren
    Trying to control Philips backlight manually with PWM — brightness increases with frequency...?
    by ohren
    I raised the question of whether PWM on the power board "dim" pin would be a reasonable assumption for controlling the backlight of a Philips TV (55put6101/12): https://www.badcaps.net/forum/troubl...d-tv-backlight. I didn't receive any insights there so I went ahead and tried it.
    The setup is basically:
    Rpi3 hardware PWM → 220 Ohm → NPN transistor → dim pin
    Transistor is switching the 3.5 V supply on the power board....
    12-05-2024, 11:10 AM
  • domix
    Philips 58PUS7555/12 backlight only
    by domix
    Hello, after a storm i notice tv is not working. Only backlight when i turn it on. If i press button on the back fot menu, backlight change. So tv menu and fuctionality is working i guess.
    what to check?...
    08-02-2026, 05:00 AM
  • chestercc
    Philips TV Backlight Repair
    by chestercc
    So i'm trying to replace the LED's in a Philips TV. It's 42" with a 715g7262-p01-000-0010 backlight driver board based around an O2 Micro OZ9902CGN.
    My issue is when I replace all the LED's on one board with the new 3V 300ma ones they immediately burn out when the set is powered again. I previously tried the same thing with 6V LED's and the backlight flickered for a bit but wouldn't start.
    The original LED's which I removed which are still working start to melt and burn when given more than 3V on DCPS so I know they shouldn't be higher voltage ones.
    11-18-2022, 01:15 PM
  • Patrick501
    Philips 55PUS6704 no picture, backlight ok
    by Patrick501
    I'd like to repair a Philips 55PUS6704.
    It turns on and you can see the backlight, hear the sound but no picture.
    When I disconnect one of the T-con cables, half of the screen turns white.
    right cable disconnected= right side white
    left cable disconnected= left side white
    When I tape like 6 or 7 pins of one cable it looks like the picture attached. I already tried another T-con board without success.
    There are no shorts on the the mainbaord and the two lcd panel boards...at leat I couldn't find any.
    Also you can notice one single...
    11-12-2025, 08:46 AM
  • ovrax
    Philips 55PUS6804/12 turn on & off (probably backlight issue)
    by ovrax
    First of all, please excuse me as I'm quite new to this field.
    I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
    I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
    The Ambilight works perfectly and stays on.
    No sounds.
    Thanks in advance.
    08-25-2024, 04:33 AM
