Hey guys,
I was given an LG 50PK550 plasma that tries to turn on then turns off right away. The guy before me bought a new power supply board which did not fix it so he included the spare board with the TV.
When I power up the TV, the relays click, then there is a quick flash of grey on the screen and at the same time I can hear the panel prime but then the panel goes out. The TV stays powered up for a short time, during which I can hear a faint ticking from one of the transformers on the power supply board. After a few more seconds the relays click and the TV shuts down. Pressing the power button again repeats the cycle.
I tested Vs, Va, and 5V going to the Y-SUS, all of which are good until the TV shuts down fully. I checked the 5W ceramic resistors on the power supply board and they are all good. I also checked all of the other large resistors on the power supply and Y-sus board.
Disconnecting the Y-sus from the power supply causes the TV to stay powered up until the power button is pressed. I reconnected the Y-sus board and removed both of the buffer boards. The TV shuts down right away again. Problem must be on the Y-sus.
I hooked the scope up to the Vs rail to be sure the voltage wasn't dropping out and it was solid. I then checked Va. Va is solid while the panel tries to prime but then has downward spikes corresponding to the ticking from the power supply board. I assume this is due to there being no real load on the rail and it is just having trouble regulating. This cannot be the issue anyways since the Y-sus does not use the Va rail.
I scoped VSC on the Y-sus and captured a waveform. The blue trace is VSC and the yellow trace is Va. You can see VSC come up to the rated 150V but die out, spike back up, and die completely. VSC dropping out corresponds to the panel going dark after the initial flash. You can also see the downwards spikes on Va, but they happen after the problem with VSC has already occurred so I do not think they are relevant.
Does anyone know what could cause VSC to drop out? Or any other ideas what to check?
Thanks!
Thanks!
