LG 60LB5200 No power , completely dead
  • Anooc7
    • Jun 2021
    • 26
    Re: LG 60LB5200 No power , completely dead
    I jumped r33 but still issues remains the same. Before ordering a psb this was the only experiment remaining, I doubt the purchased IC’s quality at this moment, but not taking chances anymore.
    Thanks all for your time.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4462
      • Italy - Milan
      If the output tensions were lower on standby this should be indicated in the silkscreen table. Usually when low outputs are present i suggest to change the feedback optocoupler and the shunt reference, that here are U3,U6, because the spike when mosfet is off runs through the IC and after that trespasses the opto and hits the shunt regulator, but this has nothing to do with the r33 burning i think..
      • R_J
        • 9588
        • Anooc7
          • Jun 2021
          • 26
          That is a good input , but
          I have already closed the unit and decided to order a replacement psb, when it comes I will do a side to side analysis and will post the findings.
          Regards
          • Unspun01
            • Jun 2011
            • 349
            Regards
            Hi:
            I also have same TV 60LB5200. My power supply had low 12V and 24V. They measured 8V and 16V respectively.
            I replaced the main IC TEA1755T, but there was no difference. Low 12V and low 24V is not due to the main IC.
            The solution is simple. Replace surface mount NPN transistor marking 2X at position Q13. 2X marking is a MMBT4401 NPN BJT transistor 40V 600mA.
            This transistor was not shorted in my power supply and i thought it was ok and overlooked it. But nearby resistances did not measure correctly in circuit.
            Measure resistance of highlighted components in-circuit: R79 [102] = 1kohm, R84 [102] =1kohm, R87 [222] =2.2kohm. If in-circuit resistance of any of these do not appear to match their stated value, remove Q13 and re-measure the resistances.
            In my TV, the in-circuit resistances were way off. With Q13 removed, these resistances matched their stated values exactly. When I replaced Q13, the power supply correctly output 12V and 24V once again.
            None of the resistances needed to be replaced or removed. I only highlight them to assist anyone in determining if Q13 is bad.
            This does not preclude the other nearby transistor (Q12) or 431A IC (U3) from being bad, but they were not the issue in my TV.
            Please try my tests, and my solution and reply with your findings.
            • max-power
              Dell E6540 laptop completely dead after dssasembly
              by max-power
              Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
              that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
              After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
              03-24-2025, 08:49 AM
            • wangbreeze
              T480s random shutoff and then completely dead
              by wangbreeze
              Hello Gurus,
              I got a ThinkPad T480s. It was running fine but suddenly started random shut down. When it turned off, I had to push the reset pin to bring it back to life. But it got aggressively worse and became completely dead. No charging light, no life.
              I did some initial diagnostics with just the board (no battery, nothing attached, and no CMOS battery as well)
              Initial testing of the coil resistance seems to indicate no dead short. The only low resistance I measured was at PL701. It reads 38 ohms.
              charger gave - 20V - ok
              U101B
              02-03-2024, 04:57 PM
            • pavski
              Completely dead MSI z490 tomahawk
              by pavski
              Trying to troubleshoot MSI z490 tomahawk board and would appreciate your help. The board is completely dead and shows no activity when the power button is pressed.
              I have tried to look at the Superio, the PSIN signal seems to be correct (goes from 3.3V to 0 on button press) but the voltage on PSOUT pin is quite low. I
              t is only 0.8V which seems to be incorrect but goes to 0 when the button is pressed.
              Can you please let me know if this is indeed incorrect and what else should I look at next?
              Thanks!
              06-02-2024, 02:42 PM
            • jinu_j
              by jinu_j
              Hi
              05-03-2025, 10:51 PM
            • Andreasbest
              Lenovo Thinkpad T14s completely dead.
              by Andreasbest
              Hello.
              I received a T14s Gen1 ( NM-C891 motherboard ) that is completely dead, no indication of life at all.
              I tried hard reset without RTC battery and short both pins of it for 1 minute but no luck.
              Since it's type C connector i have no idea what to measure or where to inject voltage, so any advice are welcomed
              Thank you in advance!
              Schematic & boardview -> https://www.badcaps.net/forum/troubl...cfc-nm-c891-sc...
              03-19-2024, 03:18 AM
