Vizio D55un-E1, bad Q9100, C9100 & R9111, parts ordering questions
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    Re: Vizio D55un-E1, bad Q9100, C9100 & R9111, parts ordering questions
    Originally posted by R_J
    This schematic is not exact but seems close although the location numbers and values are different, but it might help.
    Thanks for posting the schematic R_J!
    I plugged the PS in to AC voltage. I have 165V on pin 4 and 1.65v on pin 2. All the other pins show no voltage.
    I see no damaged components off the gate of Q9101.
    At this time, and without specific instructions on what to check and how to check it I've reached the top of my pay grade.
    They call me......."threadkiller"
    • R_J
      • 9594
      I would replace the ic (get a couple) It is likely damaged internally so it won't drive the mosfet.
      This type of ic usually has an internal startup cell which takes the voltage on pin4 and supplies a low current voltage to pin 7 vcc, this low current supply charges the external cap on the vcc pin and when it gets above a certain voltage (10~15v) the ic will drive the mosfet. A similar ic which has a datasheet is the SSC1S311A
      • DXseekerMO
        • Feb 2018
        • 1119
        • US
        Originally posted by CloudyOne72
        Followimg as I have the exact same issue and would love to know which resistor i correct
        The resistor I ordered: https://www.mouser.com/ProductDetail...IQ8EgDhXKBc%3D is identical in appearance to the bad resistor I replaced, save for the black band at the end.
        It looks like IC U9101 is bad on my board as well. Replacing the components I ordered did not restore the TV to operation.
        • DXseekerMO
          • Feb 2018
          • 1119
          • US
          R_J, do you have a source you trust for these? I see several from AliExpress but they are coming from Turkey or China. My first immediate concern is counterfeit components and my second is ordering with my credit card and that info getting stolen and/or misused.
          On the other hand there are packs of 10 or more available for these at what seems a decent price and I see a re-sale/profit opportunity for the ones I don't use.
          • CloudyOne72
            • Sep 2021
            • 10
            I haven't checked mine but either way, I'm thinking I need a couple
            • DXseekerMO
              • Feb 2018
              • 1119
              • US
              #26
              Just wondering if you have a source for these you trust?
              • R_J
                • 9594
                I don't have a source, it looks like the only suppliers are from China, maybe someone else has ordered from a supplier that also caries this part.
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  #28
                  I've bought from these in the past. https://www.aliexpress.com/item/4000843488182.html
                  • DXseekerMO
                    • Feb 2018
                    • 1119
                    • US
                    #29
                    Thanks R_J, I appreciate your help and knowledge. Maybe I'll wind up waiting for a good power supply in a busted TV. The busted part should be available, but with a good PS may take a while! Maybe someone knows a good reliable source?
                    • CloudyOne72
                      • Sep 2021
                      • 10
                      So i was bored and went back to looking at this tv when I came across this..
                      • CloudyOne72
                        • Sep 2021
                        • 10
                        @DXseekerMO any chane your looks the same?
                        • DXseekerMO
                          • Feb 2018
                          • 1119
                          • US
                          #32
                          Sorry I didn't reply to your previous message, it's exterior house and porch clean-up time in these parts lol.
                          Here's a pic of mine, it isn't blown out like yours but do note the discoloration in the same area.
                          EDIT/ADD: I didn't mean to add the picture of the antennas but I did design and build them for DTV DXing! lol I've received over-the-air TV to 539 miles with these.
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            #33
                            That looks like the marking commonly seen on the main EEPROM on a PCB, either a dot of varnish or paint is used.
                            Remove it from the board and read it to verify if it is actually blown.
                            • CloudyOne72
                              • Sep 2021
                              • 10
                              Now that you say that, I see it lol Well thatsgood news and bad lol.
                              • SS454
                                vizio e650i-a2 backlight flashes then turns off
                                by SS454
                                vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                panel: au optronics T650HVN05.4
                                72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                08-20-2020, 03:57 PM
                              • mrtek
                                Vizio M65-C1
                                by mrtek
                                Hi.
                                picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                07-14-2025, 07:28 PM
                              • howardc64
                                Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                by howardc64
                                Failure Symptom
                                No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                Where is the short?
                                Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                05-27-2025, 02:56 PM
                              • howardc64
                                Vizio SmartCast TV software bug that looks like hardware
                                by howardc64
                                Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                                It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                                11-16-2024, 05:17 PM
