MOSFET SQT7011K equivalent replacement
  • Chrissygizmo
    • Mar 2021
    • 125
    • United Kingdom
    Just a quick question...
    I've removed the 6 pin mosfet from a Samsung psu & I haven't got the same one, could anyone tell me any others that I could replace it with please?
    Tia
  • Chrissygizmo
    • Mar 2021
    • 125
    • United Kingdom
    Re: MOSFET SQT7011K equivalent replacement
    Update
    It's ok, I replaced the board with another board from a similar model .. seems to be working ok but the only thing is when I flicked through the channels the picture on channel 4 was too far to the right, I will upload a photo, it seems to be the only channel that it's happening on ..
    Tia 👍
    • cheeky2
      • Dec 2012
      • 337
      If you had googled it the part is an ic not mosfet! Mosfet normally have three legs you would have found it to be a STR-W6053S
      • issam19dz
        B450 AORUS M Looking for Equivalent Replacement for MOSFET EMF30N02J?
        by issam19dz
        I'm hoping to get some help finding a suitable replacement for the MOSFET EMF30N02J. I'm currently using this component in B450 AORUS M motherboard
        Any information or advice would be greatly appreciated!
        Thanks, [Issam Seb]
        05-01-2024, 04:26 AM
      • DoOm86
        Dual mosfet replacement help
        by DoOm86
        Hello.
        I have a notebook with a shorted mosfet, it's a E6930 GA8125.
        It seems to be a 30V dual asymmetric N-channel AlphaMos.
        Luckily the notebook is working, so I just need to find a good replacement for this mosfet.
        And here is where I need help!
        It's the first time I have to replace this kind of mosfet, I checked on mouse and I found this: (mouser No) = 512-FDPC5030SG.
        I need your help to be sure is a good replacement or there is another with better compatibility, since I can't find the same exact (just from China).
        Thanks!...
        10-31-2023, 12:03 PM
      • jm942
        Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
        by jm942
        My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
        I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
        I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
        I did voltage injection on the cpu with 0.7V and i have a current...
        07-11-2024, 05:11 AM
      • dreico33
        AON7403 Mosfet Equivalent
        by dreico33
        Hellow guys,
        I am trying to replace an AON7403 Mosfet but i dot not have in my stock the same. So i wonder if there is any equivalent to this Mosfet.
        Thank you very much.
        11-16-2024, 09:28 AM
      • Jane
        How do you test MOSFET in laptops ?
        by Jane
        I tried to use this method:
        Testing an N-channel MOSFET:
        Step 1: Discharge the Gate (turn off the MOSFET)
        Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
        Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
        Step 2: Charge the Gate (turn on the MOSFET)
        Now, place the red probe on the Gate (G) and the black probe on the
        09-27-2024, 03:31 AM
