Sony KD65X85005C, no boot, hdmi IC suspected
  • Formaster
    • Jul 2021
    • 68
    • Switzerland
    #41
    Re: Sony KD65X85005C, no boot, hdmi IC suspected
    Just this found with 14 pins.
    • Formaster
      • Jul 2021
      • 68
      • Switzerland
      #42
      I got an info, of Sony TV's default disabled UART log. There is only way to check the emmc via JTAG or expensive bga emmc reader.
      Is there any possibility to do a JTAG via ch341a adaptor? Points show below.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4462
        • Italy - Milan
        #43
        you need RT809H or ohers
        • justin35
          Sony bravia kdl-43w755c - boot loop
          by justin35
          i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
          from what i read online it looks to be an emmc issue…
          i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
          i took out the board and say an samsung 16gb emmc
          i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
          i could try to put one instead of the 16gb one, but will it work?
          where do i get the software from?
          any help will be much appreciated!...
          03-06-2024, 12:26 PM
        • lilo2400
          Sony PS5 EDM-020 MIssing voltages near HDMI encoder
          by lilo2400
          Hey guys..I have an EDM-020 and I'm missing these standby voltages marked with blue...I have already replaced the HDMI encoder IC but is still the same I have all the rest of 3v and 5v ...where does this voltage comes from does, anybody knows.
          Thanks in advance
          09-02-2025, 03:58 AM
        • privato89
          Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
          by privato89
          I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
          Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
          Let's begin:
          Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
          03-26-2024, 06:37 AM
        • Ihandyrepair
          4 red flash led 65X950G boot Sony and android logo but then black
          by Ihandyrepair
          HI guys
          I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
          here is the issue
          I have Sony and android logo. but then 4 led red flash lights front of the tv
          I have 3.3v ref. 12v reg then T con 12v when I press the power on button
          but then I get black screen and 4 red flash light at the front LED
          but I get 3 led flash on the LED driver board.
          I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
          so I tried...
          07-11-2024, 01:45 AM
        • BubbaW
          Sony KDL 55HX800 Lightning-HDMI's bad
          by BubbaW
          Last week our home was hit hard by lightning, so much so that 4 transformers on our street were blown out.
          Items lost....DirecTV box, Cable TV box and initially Sony 55"....all inputs hooked up via HDMI. We have since purchased new set but wanted to at least try and see if this TV can be fixed.
          Initially while T/S, found all inputs fine except T-Con_ON = 0VDC
          but front panel had 3 red blinks. Yesterday took Pwr Supply and Main Board out to check for any noticeable failures. Coincident or not, after replacing both boards the TV started working fine...
          08-21-2022, 08:14 AM
