Sony KD65X85005C, no boot, hdmi IC suspected
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4464
    • Italy - Milan
    Re: Sony KD65X85005C, no boot, hdmi IC suspected
    In your second picture on the right bottom corner there is a 4 pins unpopulated connector, that is almost surely a serial port, make a picture of that area only, but anyway 1 pin is gnd, at the side, the other side is 5v output, if your adapter doesn't need it dont connect it, the center 2 pins are tx , rx, you must probe at tv start which one has a tension, that is tx and must be connected to rx of adapter. Then set the port at 112500 and open terminal in pc, start tv and watch characters come in, if them are readable, speed is ok if not change speed to a lower. Found the log , turn off tv, set the terminal to record the text, start tv again until it stops sending, then close the file , turn off and upload here the txt file.
    • Formaster
      • Jul 2021
      • 68
      • Switzerland
      Did you mean these 4? Just for sure i have that programmer below. Hope its ok.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4464
        • Italy - Milan
        Yes CN8004, pins are 5 but 2 are gnd. The programmer is ok, must be know how to set in serial mode, yellow jumper go to pins 2-3 i think.
        • Formaster
          • Jul 2021
          • 68
          • Switzerland
          yes, 2-3 is TTL serial. Tomorrow will check it... Big reputation, thank you
          • Formaster
            • Jul 2021
            • 68
            • Switzerland
            which one has tension
            On pin X measured 144mV, on pin Y is 157mV. Is it must be correct?
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4464
              • Italy - Milan
              #26
              What is pin X? You have two pins to measure, one is tx from where you can see data sent by the microprocessor, the other is for receive so it must be free from potential i think, unless there is a pullup, anyway this test is not so useful, you can simply swap the wires if you don't see data in.. but keep in mind some brands like Samsung needs the port to be activated for debug but this is enabled via service menu and you don't have access to that..
              • lotas
                • Jan 2016
                • 4753
                • Russia
                #27
                You need to install zero resistances or jumpers.
                • Formaster
                  • Jul 2021
                  • 68
                  • Switzerland
                  #28
                  been unlucky, maybe debugging must be turn on via service menu. Soldered jumpers between, after double checked the curcuits, but no voltage on both.
                  Other way to check the nand is JTAG, while don't want to buy an expensive emmc reader. I just found this tutorial, but on the programmer what i have, it has no CMD, LSP BV and D0 pins. Am i wrong?
                  Here is the JTAG points down below
                  • lotas
                    • Jan 2016
                    • 4753
                    • Russia
                    #29
                    It's not NAND, you have an EMMC.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4464
                      • Italy - Milan
                      #30
                      Can you show us a photo of the jumpers?
                      • Formaster
                        • Jul 2021
                        • 68
                        • Switzerland
                        #31
                        Curcuits ok and pins not shorted.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4464
                          • Italy - Milan
                          #32
                          Forgot to tell that must be connect tx, rx, and gnd .. is it so for you?
                          • Formaster
                            • Jul 2021
                            • 68
                            • Switzerland
                            #33
                            GND tooked from one of the 4 big square pin directly from board. Is it false? (looks like the pins take from there too)
                            • Formaster
                              • Jul 2021
                              • 68
                              • Switzerland
                              #34
                              Guys we are wrong, found a schematics. Thats a blind miniUSB port. Under the link is the schematics from site 184-187 if somebody else need it. I will chech it.
                              link: https://drive.google.com/file/d/1slO...R0EuDrVdQ/view
                              need to be downloaded and you can able to zoom in normal PDF viewers.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4464
                                • Italy - Milan
                                #35
                                Try Cn8301 pins 18,19+gnd
                                • Formaster
                                  • Jul 2021
                                  • 68
                                  • Switzerland
                                  #36
                                  did'nt success... Soldered the MB tx to programmer rx, but no data. Checked few rates also and curcuits are ok. putty correct so?
                                  • Formaster
                                    • Jul 2021
                                    • 68
                                    • Switzerland
                                    #37
                                    18 need it too? I thought MB RX is to receive data's.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4464
                                      • Italy - Milan
                                      #38
                                      seems all correct... try swap 18-19
                                      • Formaster
                                        • Jul 2021
                                        • 68
                                        • Switzerland
                                        #39
                                        swapped, also on the adapter side, did nothing where i'm wrong ...
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4464
                                          • Italy - Milan
                                          #40
                                          Try to find on the main board a chip of approximately 14pins , sometimes it is marked GD75xxx, or MAX2323, or search its datasheet, it can be a level shifter that adapts internal low volt to a standard 12v uart, in this case a pc with RS232 port or an usb adapter is needed.
                                          • justin35
                                            Sony bravia kdl-43w755c - boot loop
                                            by justin35
                                            i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
                                            from what i read online it looks to be an emmc issue…
                                            i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
                                            i took out the board and say an samsung 16gb emmc
                                            i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
                                            i could try to put one instead of the 16gb one, but will it work?
                                            where do i get the software from?
                                            any help will be much appreciated!...
                                            03-06-2024, 12:26 PM
                                          • lilo2400
                                            Sony PS5 EDM-020 MIssing voltages near HDMI encoder
                                            by lilo2400
                                            Hey guys..I have an EDM-020 and I'm missing these standby voltages marked with blue...I have already replaced the HDMI encoder IC but is still the same I have all the rest of 3v and 5v ...where does this voltage comes from does, anybody knows.
                                            Thanks in advance
                                            09-02-2025, 03:58 AM
                                          • privato89
                                            Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                            by privato89
                                            I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                            Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                            Let's begin:
                                            Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                            03-26-2024, 06:37 AM
                                          • Ihandyrepair
                                            4 red flash led 65X950G boot Sony and android logo but then black
                                            by Ihandyrepair
                                            HI guys
                                            I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                                            here is the issue
                                            I have Sony and android logo. but then 4 led red flash lights front of the tv
                                            I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                                            but then I get black screen and 4 red flash light at the front LED
                                            but I get 3 led flash on the LED driver board.
                                            I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                                            so I tried...
                                            07-11-2024, 01:45 AM
                                          • BubbaW
                                            Sony KDL 55HX800 Lightning-HDMI's bad
                                            by BubbaW
                                            Last week our home was hit hard by lightning, so much so that 4 transformers on our street were blown out.
                                            Items lost....DirecTV box, Cable TV box and initially Sony 55"....all inputs hooked up via HDMI. We have since purchased new set but wanted to at least try and see if this TV can be fixed.
                                            Initially while T/S, found all inputs fine except T-Con_ON = 0VDC
                                            but front panel had 3 red blinks. Yesterday took Pwr Supply and Main Board out to check for any noticeable failures. Coincident or not, after replacing both boards the TV started working fine...
                                            08-21-2022, 08:14 AM
