Samsung UN70NU6070 TV Issue - HELP!
  • Djgh
    • Jul 2021
    • 14
    • US
    Evening,
    I started experiencing color/brightness issues with my 70” Samsung tv after a year or so from date of purchase. It doesn't seem as bright and the colors are a little off. Is this a backlight issue or something else? I'm pretty hands on, so I don't mind tackling the issue if I can pinpoint what it is.
    Any help would be appreciated.
    Model #: UN70NU6070
    Video comparison:
    https://youtu.be/6dNhwNy_lus
    Last edited by SMDFlea; 07-12-2021, 06:36 AM. Reason: Added UN70NU6070 to thread title
  • alfatv
    • Sep 2020
    • 353
    Re: Samsung UN70NU6070 TV Issue - HELP!
    Yes, it could be backlight. Did you you run it at 100%?
    In the meantime you can change color temperature setting in user menu and tune white balance in service menu. Reduce backlight to minimum possible setting.
    For best results run the test with fully white screen.
    If white is good, you can play with tint setting for colors, but better set it in the middle.
    • Djgh
      • Jul 2021
      • 14
      • US
      Appreciate it the advice. I've played with all the settings, performed a picture and power reset, and even spoke with a Samsung representative. None of those were helpful. I may end up replacing the backlight due to it being inexpensive but was still hoping someone could pinpoint the exact issue.
      • R_J
        • Jun 2012
        • 9579
        It is unlikely to be the backlight, I would first check the source, possible bad hdmi cable? The next thing I would check (reseat) is the LVDS cable between the main board and t-con.
        • ducky29
          • Dec 2015
          • 369
          • Europe
          Change the picture settings to vivid or standard. See if that makes any difference.
          • Djgh
            • Jul 2021
            • 14
            • US
            Ordered a new tcon board so let's see what happens.
            Lol thanks for your Input.
            • mmartell
              • Oct 2013
              • 3189
              Probably a gamma issue on the tcon. Think you're on the right track.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                +1
                It does look as though the black level is washed out.
                • alfatv
                  • Sep 2020
                  • 353
                  Can you go this site and post pictures of gradients white red green blue?
                  https://www.eizo.be/monitor-test/
                  • Djgh
                    • Jul 2021
                    • 14
                    • US
                    Replaced the tcon board. It's definitely better but not perfect, then again I'm comparing it to the picture on my iPhone. It's still a little saturated (maybe that's the word)
                    • Djgh
                      • Jul 2021
                      • 14
                      • US
                      People’s faces look like they have a bad tan
                      • R_J
                        • Jun 2012
                        • 9579
                        Do you have pictures of both t-con boards? it is possible they could be for different models. You can't always go by the BNxx-xxxxxx number you need to use the number on the white sticker. I suspect there is an eeprom on the board and it bight be programmed for a different panel or main board
                        • Djgh
                          • Jul 2021
                          • 14
                          • US
                          Not anymore. Old board is long gone but I purchased the new board based off the sticker on the back.
                          • Djgh
                            • Jul 2021
                            • 14
                            • US
                            Another thing I noticed is that when I first turn the tv on, the colors appear to be perfect but slowly goes back to its original color issue
                            • frannyjunk
                              • Oct 2010
                              • 78
                              Could be the backlights. The phosporous on some of the LEDs may be failing causing a shift towards blue/purple (or pink before it gets to blue/purple).
                              • Djgh
                                • Jul 2021
                                • 14
                                • US
                                The led strips could cause the color discrepancy? Am I wrong to assume the leds only assisted in fixing dark spots on the screen.
                                • ducky29
                                  • Dec 2015
                                  • 369
                                  • Europe
                                  Yes they do but I have never found a samsung with that fault. Mostly vestels and LG. The picture will get blueish but I don't think this is the case.
                                  • petehall347
                                    • Jan 2015
                                    • 4429
                                    turn the red up and see what happens
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4424
                                      • Italy - Milan
                                      Much probably bad backlight, must check power supply output tensions for the leds, must be in the range, if not it can ruin the led phosphors by too much tension. If those are ok so are bad leds.
                                      • angelos
                                        • Dec 2012
                                        • 573
                                        • South Africa
                                        +1
                                        I totally agree with that.
                                        • Kjell
                                          Samsung Series 9 - BIOS issue
                                          by Kjell
                                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                          08-01-2025, 09:15 AM
                                          09-07-2024, 05:50 AM
                                        • Nairolf
                                          Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                          by Nairolf
                                          I have a Samsung DM32D display.
                                          When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                          Here’s what I have tried so far:
                                          1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                          2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                          3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                          From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                          08-24-2025, 03:47 AM
                                        • vincentedel
                                          Samsung SyncMaster 740n Phase Control Issue
                                          by vincentedel
                                          I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                          I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                          04-22-2025, 12:33 AM
                                        • Manucsl
                                          QE65Q800TATXXC Samsung TV Issue
                                          by Manucsl
                                          Hello.
                                          My TV is a QE65Q800TATXXC Samsung TV.
                                          Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                                          Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                                          Any ideas to check would be very appreciated 😊
                                          After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                                          02-19-2025, 07:47 AM
