Vizio d50-f1 no bl no image yes sound
  • Afro420ninja
    • Jun 2021
    • 6
    • Usa
    So I get black screen, but has white light on front when turned on that will fade to off. Has no backlight, had sound, and could see menu with flashlight. Have already replaced tcon and power boards. Not sure if it popped when it went out as I had fallen asleep watching it and woke up to it not turning on. After visual inspection of boards can't seem to find any blemishes or bad capacitors to my eyes. Haven't tested any voltages because I'm an amateur when it comes to electronics so far. Cars have been my specialty for repairs until my Xbox and now my TV went out. Fixed the Xbox, now to fix this any help is greatly appreciated.
  • CapLeaker
    Leaking Member
    • 8119
    Re: Vizio d50-f1 no bl no image yes sound
    Measure the voltage on the led strings, see what you get. I am guessing one or more is open (bad LED’s).
    • Afro420ninja
      • Jun 2021
      • 6
      • Usa
      Is that possible without removing the panel?
      • Afro420ninja
        • Jun 2021
        • 6
        • Usa
        Found the labeling on the pa board I apologize. Forgive my ignorance :/
        • CapLeaker
          Leaking Member
          • 8119
          cn5502 on the psu
          • Afro420ninja
            • Jun 2021
            • 6
            • Usa
            All I see is cn8602 if you mean that plug in. I tested it and got 20v with TV powered but not on. Also tested on main board at cable going into the back panel from the main board and got 20v and without that cable plugged
            • Afro420ninja
              • Jun 2021
              • 6
              • Usa
              What SHOULD it be? And that only comes through on 2 pins. The rest are 0
              • R_J
                • 9535
                You need to check the voltage on CN8602 pins (14,13,12, or 10) while turning the tv ON. I suspect you have an open led in the panel, There seem to be 8 led's per string with 4 strings.
                • CapLeaker
                  Leaking Member
                  • 8119
                  My bad, CN8602… couldn’t read it. you need to manage to read the Voltage on each LED string while being connected to the LEDs. LEDs are current controlled, not voltage controlled. With that LED plug disconnected, you should see voltage ramping up fast while turning the TV set on, then ramping down again while then staying at a low voltage like your 20V.
                  • ChaosLegionnaire
                    by ChaosLegionnaire
                    09-13-2022, 09:02 AM
                  • TMTGTR
                    An Xbox One PSU Odyssey
                    by TMTGTR
                    Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
                    =>Background:
                    I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
                    06-17-2022, 05:40 PM
                  • Kartowl
                    philips 47pfl6158k/12 image faded away, sound still coming from TV
                    by Kartowl
                    Hi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
                    04-23-2024, 12:57 AM
                  • wolf1976
                    samsung ue40d6100 has no backlight no sound and image
                    by wolf1976
                    hi to all
                    on the above model of samsung i have the faults i have told already on the title
                    iI have standby i can from remote control open and close the tv and it seems reacts the tv when i press someone button from remote control but and with the help of a torch i cannot see anything image on the tv and no sound
                    any idea from someone what can i measure so i can find the problem ?
                    the power supply is the bn44-00482a i cannot find the service manual so i can test if the leds are ok and maby these are the cause of my problem
                    11-17-2024, 01:02 PM
