Sony Trinitron
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    Sony Trinitron
    I was given a Sony Trinitron TV the other day. Its a 32 or 36 inch model made in 2004. When my friend had a power outage at his house everything in the entertainment center except the TV came back online when the power was restored. I don't mess around inside of TV's or monitors for any reason but I did look into this one a little. By the dust inside of it I can tell I was the very first to take the back off the thing. The little glass fuse tested fine. None of the jumper wires on the PCB look to be burned. The TV is just dead in the water...The first time I plugged it up and hit the power button I think I herd that usual high voltage click but after that it did nothing. Do you all think it would be worth it to take this unit to a TV repair shop?
    "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
    Mark Twain
    "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
    John Paul Jones
    There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
    Rod Serling
  • Krankshaft
    • Jan 2007
    • 2328
    Re: Sony Trinitron
    So you heard the click of the relay did the set then shut down by disengaging the relay another click?
    Aside for the obvious check for any cracked solder joints especially in the HOT, Driver transistor, and flyback areas.
    If it was a chassis shutdown it could be the HOT or bad flyback problem. The high voltage circuits are most likely to be responsible for chassis shutdown.
    It could be a low voltage supply problem too newer sets tend to rely more on an onboard switcher for powering the ICs which comes out of standby mode when the high voltage comes comes up. Older TVs relied heavily on the flyback for secondary voltage sources.
    Without a multimeter and troubleshooting it's just speculation though. Any of the above problems are easily rectified if you can find someone who isn't a module swapper.
    • Junk Parts
      Court Jester
      • Jun 2006
      • 8953
      Re: Sony Trinitron
      More details...The set is a Sony KV-27S15. I was wrong on the year it was made. The correct date would be sept 1994. I also checked for power where cord connects to the PCB and I did get 115 vac. I plugged in the set again and hit the power button but I didn't hear the unit make any noises at all this time. The noise the first time could have been the plastic front creaking or my imagination. If it would atleast come up I did read that the LED's on the front just might blink out a trouble code for me. This would atleast point me to the right area. I think the Power supply just may have a problem. I'm going to do a closer inspection of the underside of the PCB in this area. It just may have a fried trace.
      Mark Twain
      John Paul Jones
      Rod Serling
      • Wizard
        • Mar 2008
        • 2296
        Re: Sony Trinitron
        I'm expert on these Sony consumer type. When you turn on, the red LED kept blinking and blinking and blinking for long time? No whine from flyback, no orange glow from the heaters in the gun assembly?
        Fuse is not best way to assess fault finding. Most particularly Sony CRT TVs.
        1. In these models, flyback transformers is extremely RARE to fail. I have not had one come in bad and I have fixed MANY (more than 35).
        2. Sony CRT stuff is heavy on bad solder joints especially around the horizontal circuit and some in vertical circuit.
        Always unplugged, pull the circuit board up, unplug speaker plug on the manboard and unplug the plug for the power supply sub board. Withdraw the big board and prop up.
        Ok, first thing use your multimeter. Go directly to the horizontal transistor (I bet this is 2SC5148). If it is shorted, it is solder joints that hammered the horizontal transistor especially in the base drive circruit and to be direct, that's on the base drive transformer (grey box with 4 or 5 pins, you will find bad joints there, use magifying lens).
        Oh yes, as unfortune effect, shorted horizontal transistor shot the power supply too. You'll need: pair of transistors, 1W .47 fusible resistor and possible need VDR replaced if one is found shorted (use your meter, but I have not found one that is bad).
        Cheers, Wizard
        • Junk Parts
          Court Jester
          • Jun 2006
          • 8953
          Re: Sony Trinitron
          Wizard are you anyplace close to Baltimore??? I have GREAT FEAR of the insides of a TV set... From what I've been told ZAP just might be the last thing that you will hear forever! I would love for you to have a look at it because you know how not to get ZAPPED! Could it just be a bad solder joint with no dead parts? I didn't get around to looking inside of it today because I spent my day on the Escort. I can tell you this will be the last car that I mess with that has set outside, and not moved in five years. If its something special, yes, but not for a Ford Escort Turd type car!
          Mark Twain
          John Paul Jones
          Rod Serling
          • Wizard
            • Mar 2008
            • 2296
            Re: Sony Trinitron
            Sony that still alive iwth bad joints is rare. And sorry, I'm not near, I'm farrrrrr away. (Far away long ago... heheh)
            Cheers, Wizard
              • 31269
              Re: Sony Trinitron
              it's not the 25Kv that kill's you, it's the thing you bang your head on when you go flying backwards.
              kitchen work surfaces hurt like hell - trust me!
              • smason
                • 1652
                Re: Sony Trinitron
                Been there, done that, and also the cuts from the sheet metal chassis and circuit boards as you involuntarily extract your hand from inside at warp speed....
                • LITEZONER
                  GO BOLTS!
                  • Mar 2010
                  • 223
                  Re: Sony Trinitron
                  You all are crazy, However, we had a set with almost the exact same problem and it turned out to be the power supply, The shop we used ended up replacing it three times and the fourth we said forget about it and bought a new set. we moved right around the same time. never told us why they kept failing, in retrospect i would have to say there must have been something wrong with the line voltage in the apartment, Good luck with it, The color and picture on those sony's is pretty hard to beat in my opinion.
                  39 Soldering Iron burns And Counting
                  • weirdlookinguy
                    • Sep 2007
                    • 1638
                    Re: Sony Trinitron
                    Did someone say TRINITRON ?
                    I second what litezoner said - a Trinitron in good shape bangs out one hell of a picture.
                    • Junk Parts
                      Court Jester
                      • Jun 2006
                      • 8953
                      Re: Sony Trinitron
                      My wife uses a big old Dell Trinitron monitor and the picture is great. I on the other hand I use and old Gateway VX900. Its not bad but its getting tired. Night sceens in DVD's are too dark now. To see things right I have to go play with the gamma settings and over drive the monitor. I get around this by playing movies on the Laptop which is connected to the flat screen which sits right next to the Gateway VX900.
                      Mark Twain
                      John Paul Jones
                      Rod Serling
                      • Junk Parts
                        Court Jester
                        • Jun 2006
                        • 8953
                        Re: Sony Trinitron
                        Now as far as the 25Kv goes, you guys are MENTAL! I take it that the 25Kv is in the bright red=dead wire going to the tube. I don't even care for taking a hit from a spark plug wire which can be 45,000 volts but at almost no amps.
                        Mark Twain
                        John Paul Jones
                        Rod Serling
                        • Wizard
                          • Mar 2008
                          • 2296
                          Re: Sony Trinitron
                          That 25KV is only fraction of a mA. Just hurt like OUCH and a jerk. NOTE I did not say unplug that red cable! Pay attention!! It is left in place and you can pull the board and prop up against TV with 2 wires or three wires unplugged (power supply, degaussing coil plug, speaker plug usually.)
                          And handle board by the edges and plastic bits.
                          Cheers, Wizard
                            • 31269
                            Re: Sony Trinitron
                            it dont hurt - your whole fucking arm goes numb and tingles and feels like it's vibrating for a minute or 3!!!!
                            • Krankshaft
                              • Jan 2007
                              • 2328
                              Re: Sony Trinitron
                              Yup I've been bitten too I got muscle spasms in my ass for a minute or two .
                              I discharge it with my HV probe before I remove it now.
                              There is no need to remove it though most sets leave enough slack to stand the board up for servicing. You may have to pull the CRT neck board off the tube though.
                              • Junk Parts
                                Court Jester
                                • Jun 2006
                                • 8953
                                Re: Sony Trinitron
                                Why don't I just take it to the old TV repair guy up the road. Even if I get it apart without getting zapped it still won't get fix because I don't know what the hell I'm doing....LOL HV probe..No plastic screwdrivers...no Knowledge... NO! Multimeter...yes soldering Iron...yes...solder...yes...soldering paist...yes. As you can see, I should just leave it alone. My Son would take it apart. He says a TV can't bite you...LOL His day is coming.
                                Mark Twain
                                John Paul Jones
                                Rod Serling
                                • Wizard
                                  • Mar 2008
                                  • 2296
                                  Re: Sony Trinitron
                                  Junk Parts, I thought you are on very severe budget which was the whole point?
                                  Cheers, Wizard
                                  • Junk Parts
                                    Court Jester
                                    • Jun 2006
                                    • 8953
                                    Re: Sony Trinitron
                                    True I am. I'll take a wack at it one day soon.
                                    Mark Twain
                                    John Paul Jones
                                    Rod Serling
                                    • kc8adu
                                      • Nov 2003
                                      • 8832
                                      • U.S.A!
                                      Re: Sony Trinitron
                                      ROFLOL!
                                      BZZZT! THUD!
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        Re: Sony Trinitron
                                        Seriously, the chances of getting hurt from high voltage on this set is pretty remote if you take some simple precautions. The obvious one is to pull the power cord before opening it. A second would be to measure the voltage on the large power supply cap before you start poking at any other parts.
                                        After that, follow the leads given by others. Bad solder joints, especially on the vertical and horizontal drivers is the first place to look.
                                        I'm a lot less enthusiastic about putting any significant amount of money into it. Locally, the 32" and 36" Sony Trinitrons are selling - or I should say , NOT selling for $50-$75 on Craigslist. On the average, one or two are listed in the Free section as 'Working'.
                                        In your area, things look as bad. A Sony KV-27FV17 has been listed at $25 since Feb 20th.
                                        PlainBill
                                        • motorahead
                                          Sony Trinitron (KV-20FV12) Vertical Deflection Stopped
                                          by motorahead
                                          Hi everyone, I've been troubleshooting my 20" Sony Trinitron (KV-20FV12) CRT after it failed to show a picture. The standby LED is blinking 4 times, which according to the service manual is a failed vertical deflection via the self-diagnostic check during power up.
                                          After getting the TV checked out by a technician and doing research on my own. The most obvious first step was to replace the IC502. I've done so with an exact NOS replacement with no luck. I've read a few suggestions to make sure the 12V supply to pin 2, but that voltage check would seem misleading? It seems if the...
                                          10-21-2023, 03:50 PM
                                        • ptcriserx3
                                          Sony trinitron crt bowed and side color issues
                                          by ptcriserx3
                                          Hi
                                          Ive got a vintage 2001 sony trinitron flat tube tv
                                          The image is slightly bowed and the left and right sides about 1-2in has fluctuating discoloration that comes and goes if i move or hit tv on sides
                                          See many images attached...
                                          Just windering if this is not fixable or something i can correct without getting too invloved
                                          Im trying to sell the tv
                                          06-17-2023, 07:27 PM
                                        • Flaku_34
                                          Acer Nitro XV273 and Predator XB273, look inside and disassembly guide.
                                          by Flaku_34
                                          Introduction:
                                          Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...
                                          04-18-2024, 12:47 PM
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                        • sickboy
                                          Strange CRT Fault (Sony Trinitron M1410U)
                                          by sickboy
                                          This is a CRT I sold a few months ago and it's came back with this weird issue. It's intermittent, but not a thermal fault, or tap sensitive - just completely random. The right side of the picture completely blanks out (picture is not shifted). The on screen display is unaffected though, so not a fault in the line section. Anyone seen anything like before in a CRT?
                                          11-10-2024, 05:02 AM
