Panasonic tx-55cx802b stuck on panel test mode
  • gigigi
    • Apr 2021
    • 5
    Panasonic tx-55cx802b stuck on panel test mode.
    It was working normally but few days ago some of the LED reflectors fall off.
    I've opened it up carefully, re-glued, while it was open switched it on to test LEDs.
    Then carefully assembled back.
    After plugging in to power remote does not work.
    Using power button on the TV it turns on but gets itself into a panel testing mode: white, gradient, red, gradient, blue, gradient, green and so on switching between colours.
    Anyone knows how to get out of this panel testing mode?
    I've tried so far:
    Switching off via remote or using power button on the TV, switching back on via remote or power button on the TV. Removing power for seconds while pressing power on button on the TV.
    No difference so far.
    Help would be highly appreciated.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Panasonic tx-55cx802b stuck on panel test mode
    It's probably that the ribbon cables are not re-inserted correctly. Did you lift the flap on the connector to remove / re-insert the ribbons.
    Also check that all the connectors are back in place especially the one that goes off to the IR sensor.
    Post some photos of the circuit boards.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4544
      • Italy - Milan
      Same problem here with a different model after panel and tcon fixing attempt... lvds cables-connectors always handled with care, i will try continuity A.S.A.P.
      • gigigi
        • Apr 2021
        • 5
        Opened TV. Tried to remove and re-insert all connectors.
        Problem solved.
        • Ancient1
          I'm stuck . Panasonic TH-L32U20M panel's boards issue
          by Ancient1
          Hi
          The TV seem to start ( blinking green) but goes into blinking red. No display and or backlight. Full view photo.
          Actions :
          1. Disconnected Panel's Right, 2nd, board : TV comes ON (steady green , no blinking red )
          1a. You can see in two photos the B/W screen , fading blue "HDMI12" , and the wierd sides of the image, like an old CRT.
          Obviously the fault is from or on the Right, secondary board
          2. I taped the Flex tracks, ~2 tracks at a time- see Photo. The issue seems to be on the V lines (Assuming Data...
          09-03-2023, 03:51 AM
        • learnmore
          How to perform panel test on Samsung UE70TU7020K
          by learnmore
          Hello Community,
          As part of an ongoing learning project, I'm trying to perfrom a panel test (where, according to some, you jump 12v to the (Tcon) then jump 3.3V to panel test pin on the FPC connector). For the model I'm testing with, I'm unsure of where the test pin is located (providing there is one). So, I'm after some help to locate it. Here are some shots of the board (note mainboard, Tcon combo board)....
          03-16-2024, 10:41 AM
        • nono34
          Hisense stuck in Colors cycle like test pattern.
          by nono34
          I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
          I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
          10-24-2024, 04:31 PM
        • howardc64
          LG 49UJ6500 LCD panel lighter band that goes away
          by howardc64
          49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
          Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
          02-19-2023, 12:13 AM
        • Stunt
          Hp Laptop Stuck on Hp protected by hp sure start screen
          by Stunt
          Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
          I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
          I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
          Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
          screen that's it and stuck there. I left it until the following day and i still...
          09-02-2025, 01:51 PM
