Samsung smart tv bad power board BN44-0503A
    replied
    Re: Samsung smart tv bad power board BN44-0503A
    so what are your symptoms live.com?
  • iamosmoses@live.com
    replied
    where can i get a schematic diagram for bn44-00503a samsung power board??
  • xfox
    replied
    ok, so with pull up resistor voltage is 12.75 13.3 and 13.4
  • R_J
    replied
    Originally posted by xfox
    Voltage on picture, so it's switching from one to another, looks like main board is trying to reset itself
    This why we disconnect the main board, the power supply should turn ON with the main board disconnected, this will eliminate the main board as the cause of the problem.
    with the main board disconnected, the PS_ON line will be taken high to A5V by the pull up resistor, this will turn on QQ852 which also turns on PC902S, the output of PC802s will turn on QS801 and supply a constant (14v) to the pfc icp801s.
    If the PFC circuit is indeed working you will get around 385VDC across CP814s
  • xfox
    replied
  • R_J
    replied
    Oh, sorry... So voltage is 13.25V without main board connected and switching from 13.25 to 19v with main board
    I only see one voltage reported, last time I looked these transistors have 3 pins, Emitter, Base & Collector
  • xfox
    replied
  • R_J
    replied
    Marked ground on attached photo with blue
    You used the correct hot ground but you are checking the wrong transistor, Check QS801 NOT QP801
  • xfox
    replied
  • R_J
    replied
    Tried disconnecting, same measurements
    What are you using for ground when making these measurements ? 163v on QS801 is impossible. If this is the case ICP801S would be completely blown off the board! because the ic can only handle about 20v on it's vcc pin
  • xfox
    replied
  • R_J
    replied
    CP814S - 163v
    CS805 - switching from 14v to around 19.5v
    QS801 - same as CP814 163v
    163v across the main cap indicates the board is either not turned ON or the pfc circuit is not working. Is the main board connected? if it is, disconnecting it should force the power supply ON.
    CS805 should be on the collector of QS801, this should be a small smd transistor. The base of qs805 is controlled by the optocoupler PC802S It turns on QS802s which acts like a switch and a regulator, it supplies about 16 volts on its emitter if it is working (power supply ON)
  • xfox
    replied
    CP814S - 163v
  • DXseekerMO
    replied
    Originally posted by R_J
    If you have "nothing"(no voltage) on the main filter, your main fuse is likely open. But this can not be the case if you have A5V standby voltage.
    Recheck the voltage across the main filter cap CP814S, Then check the voltage across CS805,
    Thanks for jumping in there R_J
  • R_J
    replied
    Nothing on main capacitor, all looks ok
    Recheck the voltage across the main filter cap CP814S, Then check the voltage across CS805, Then check the voltages on QS801 (using hot ground) QS801 supplies the PFC_VCC to ICP801S (around 16 volts)
  • DXseekerMO
    replied
    Wish I could help you more.
  • DXseekerMO
    replied
    The only other item I know of that may be deficient is the PFC IC, but I hasten to suggest you replace it as I think you would be doing so without knowing for sure if it's actually bad. I still don't know how to test them. They survive shorted MOSFETs about 70% of the time. Mine was OK on my 00502A power supply.
    I apologize but we've reached the limit of my knowledge. Can anyone else step in here and take over? Any further suggestions by me would only be guesswork and I'd really like to see this poster get the right answers and get this fixed.
  • xfox
    replied
  • DXseekerMO
    replied
    What voltage do get on the main capacitor when you try to turn on the TV?
    We're reaching the limit of the help I'll be able to give you on this power supply. I'm no ace tech, but since I just repaired a similar board I thought I'd try to at least help with what I learned.
    Check the quality of your solder joints, and check all the solder joints on any item attached to a heat sink. Look for ring cracks in the solder joints upon these items. It sounds to me like the PFC circuit isn't boosting the voltage. If you used flux to solder the items you replaced make sure it's all cleaned off the board.
    I missed some flux/residue on mine and it was causing similar problems, my TV turned off and gave 2 blinks then wouldn't turn on at all until I thoroughly cleaned all the flux off the board. It's been aces ever since.
  • xfox
    replied
    So what I did, I replaced resistors RP810 and RP810 and QP801S, after that board not exploded and LED light started to blink (5 times double blinks), nothing on backlights connector (0V), checked backlight with LED tester, looks good and working
    mainboard connector:
    PIN14 (Power On_off): 3,2V
    PIN12 (A5V): 5V
    CP818 and CP819 - no short
    DP802, DP803, DP808 - no short, reverse ok
    BD801S no short, shows 0.555 one way only (soldered)
    ICP801S - not sure how to check
    PIN6 - PIN7 - 29 Ohm
    PIN5 -PIN7 - 76 Ohm
    PIN5-PIN6 - 47.6 Ohm
    One more thing, had no proper resistors, so used 68Ohms to replace 30Ohm (2x68Ohm parallel connected so got 34 Ohms)
  • ohren
    by ohren
    09-08-2023, 05:24 PM
  • C152Heavy
    by C152Heavy
    Summary for TL-DR readers:
    • VCC pin (18) of PFC...
    01-11-2023, 02:53 PM
  • MacGyver's paperclip
    what to check before replacing hybrid MOSFET/controller IC on SAMSUNG TV power board
    by MacGyver's paperclip
    TLDNR; Have an old SAMSUNG TV with blown hybrid MOSFET/controller IC on power board to be replaced; replaced blown main capacitor on same power board several years ago successfully, and TV has been working fine since until this IC popped all of a sudden. Want to know what if anything to check on board to make sure before replacing and testing with new IC. Have 2 new matching ICs, DIP socket to make removal/replacement easier, a whole other known-good power board with which to compare, if necessary.
    07-01-2023, 12:12 PM
  • valvashon
    Samsung UN65KU6290F PS board blows fuses
    by valvashon
    Samsung UN65KU6290F (May 2017); received from local Buy Nothing group. Was listed as "just went dead" and they wanted it gone. I brought it home, didn't notice anything visually wrong with the power supply board, looked up the cost of a new one and that's about as far as it went. Family was tired of tripping on the foot of the set so I decided to dig in and repair or toss.
    Can't believe that I didn't check it earlier but I found the main 8 amp fuse blown. Jumped across it with a 10 amp blade style fuse and you can see that it literally exploded inside the second I plugged...
    11-27-2023, 01:09 PM
