Samsung smart tv bad power board BN44-0503A
  • DXseekerMO
    replied
    Re: Samsung smart tv bad power board BN44-0503A
    Remove MOSFET QP801S, then:
    Check all the components off the "gate" of QP801S, replace components as needed.
    The PFC Control IC (ICP801S) may be shorted.
    Check capacitors CP818 and 819 for short
    Check diodes DP802, DP803, DP808 for short, and that they don't reverse bias.
    Check Rectifier Diode BD801S on the DC side for shorts, for a good diode reading on all 4 terminals and that it does not reverse bias. When checking for a good diode reading expect the + and - diode reading to be about .9 instead of .4 to .6.
    Let us know what you find.
    I just repaired a BN44-00502A which is similar to yours
  • xfox
    replied
    Looks like also burned two resistors one RP810 (68 Ohm) and RP809 (30 Ohm)
  • xfox
    started a topic Samsung smart tv bad power board BN44-0503A
    Hello, got Samsung smart tv with bad power board BN44-00503A, diagnosed bad MOSFET F13NM60N (QP801S) and 5A fuse, after replacing both, replaced mosfet burned out immediately, fuse is ok, maybe somebody knows what can be checked prior trying one more?
  • ohren
    by ohren
    09-08-2023, 05:24 PM
  • C152Heavy
    by C152Heavy
    Summary for TL-DR readers:
    • VCC pin (18) of PFC...
    01-11-2023, 02:53 PM
  • MacGyver's paperclip
    what to check before replacing hybrid MOSFET/controller IC on SAMSUNG TV power board
    by MacGyver's paperclip
    TLDNR; Have an old SAMSUNG TV with blown hybrid MOSFET/controller IC on power board to be replaced; replaced blown main capacitor on same power board several years ago successfully, and TV has been working fine since until this IC popped all of a sudden. Want to know what if anything to check on board to make sure before replacing and testing with new IC. Have 2 new matching ICs, DIP socket to make removal/replacement easier, a whole other known-good power board with which to compare, if necessary.
    07-01-2023, 12:12 PM
  • valvashon
    Samsung UN65KU6290F PS board blows fuses
    by valvashon
    Samsung UN65KU6290F (May 2017); received from local Buy Nothing group. Was listed as "just went dead" and they wanted it gone. I brought it home, didn't notice anything visually wrong with the power supply board, looked up the cost of a new one and that's about as far as it went. Family was tired of tripping on the foot of the set so I decided to dig in and repair or toss.
    Can't believe that I didn't check it earlier but I found the main 8 amp fuse blown. Jumped across it with a 10 amp blade style fuse and you can see that it literally exploded inside the second I plugged...
    11-27-2023, 01:09 PM
