Samsung 32 Inch power supply problem BN44-0260A
  • provider10
    • Mar 2016
    • 52
    • South Africa
    Hi
    This set uses the BN44-0260A Power supply
    It came in with IC UM8015 (ICE3BR0665) Blown
    Replaced IC but now I have a stable 13 Volt but the 5volt rail is pulsing around 2.5 volts. Checked diodes and caps but getting nowhere
    Can anybody Help
    James
    Last edited by SMDFlea; 06-03-2021, 06:56 AM. Reason: added "BN44-0260A" to thread title
  • provider10
    • Mar 2016
    • 52
    • South Africa
    Re: Samsung 32 Inch power supply problem
    Hi looking through the forum I find that the post from Moolink on 07-28-2012, 03:43 AM is basically the same set. But the diodes in my set seem to be OK. The fault occurs with or without the main board connected
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      What voltage do you have on inductor LM851
      If it is pulsing then I would lift one end of LM851 and check the voltage across CM852 and if it is not pulsing then I would check QM853 However if it is still pulsing then I would check DM851.
      I can't find a schematic but I did find this
      https://archive.org/details/Samsung_...0260A/mode/2up
      • R_J
        • Jun 2012
        • 9588
        Check the voltage across CM804 and see if it is steady (around 20~25vdc) CM804 or CM808 could be bad. You should also check the voltage across the main cap CP815, this voltage should be around 385vdc if the pfc circuit is working.
        • provider10
          • Mar 2016
          • 52
          • South Africa
          Hi Guys
          Thanks for the help. I found the voltage across CM804 was only 12v. Changed the caps didn't help . Found Zener diode ZM801 faulty
          Thanks for the assistance
          James
          • cheeky2
            Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
            by cheeky2
            This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
            I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
            Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
            06-15-2025, 05:12 AM
            03-31-2024, 02:12 PM
          • howardc64
            Samsung UN55JU650DF network/streaming problem
            by howardc64
            Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
            This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
            07-09-2025, 12:44 PM
          • Cookybaby
            Samsung UN60ES6500FXZA Power Supply Issue
            by Cookybaby
            Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
            I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
            Make: Samsung
            Model: UN60ES6500FXZA
            Power Supply P/N: BN44-00525A
            Symptoms: The TV was...
            08-20-2023, 12:26 PM
          • sempre
            Samsung T22b300 power supply problem
            by sempre
            Hi I'm trying to repair the Samsung lt22b300 power supply. I replaced the srtw6052 chip that was shorted together with the blown fuse and a blown 222 1kv capacitor.
            Now if I check the output voltages they all seem ok, but as soon as I connect a load, led or mainboard, all the outputs become oscillating (backlight flashes).
            To rule out problems with the LEDs or the main board, I tried to replace the power supply board (PD23A0Q) with a borrowed one from another working TV and everything works regularly.
            I checked all the diodes and non-smd capacitors...
            03-08-2022, 05:51 AM
