Sony KD-55XE7004 - No image, backlight works, new T-Con didn't help
  • Tempic
    • May 2021
    • 3
    • Deutschland
    I've got 2 broken TVs these are:
    Sony KD-55XE7004
    Sony KD-55XE7005
    The 05 has a broken panel, everything else works fine, you can still see the image and menu through the cracks a bit.
    The 04 displays no image. No Logo, no menu, nothing.
    The backlight works fine, all LEDs are on and voltages on every series strip are the same.
    The LED indicator blinks whenever I press something on the remote, so it does recognize it.
    I was hoping to just swap the broken panel of the 05 with the working one of the 04.
    The difference between these models is that the 05 has an interpolated refresh rate of 200 Hz the 04 only has 100 Hz. Both do only 50 Hz natively.
    My knowledge of this is not that deep, I assumed that the panel would be the same and the mainboard is just a bit different, is that the case?
    I moved all three boards (Mainboard, T-Con, PSU) from the 05 chassis into to 04 chassis so I don't have to handle the 55” panel but that made no difference.
    The TV still turns on fine but still doesn't display anything.
    I also tried different combinations of T-Con, Mainboard and PSU swaps but none worked.
    The wires were also changed to exclude a failure of these.
    I tried the 04 boards with the 05 panel and here they did actually work.
    The T-Con seems to be exactly the same, the Mainboard and PSU are slightly different.
    T-Con:
    04: LMY550FN02 | 17Y_HU11APHTA44L V0.0
    05: LMY550FN02 | 17Y_HU11APHTA44L V0.0
    Mainboard:
    04: 1-981-926-22 | 173657422
    05: 1-981-926-11 | 173657411
    PSU:
    04: APDP-209A2
    05: APDP-209A1
    I have uploaded some high-res images of everything here.
    Imgur Gallery
    Can a panel itself just be defective?
    There are no signs of damage on the flex cables to the actual panel.
    The Tv has just stopped displaying anything from one day to the other.
    Do you have any suggestions on what could cause this fault here or what I could test next?
    Any help is much appreciated!
  • William1967
    • Nov 2017
    • 217
    • Netherlands
    Re: Sony KD-55XE7004 - No image, backlight works, new T-Con didn't help
    The panel can be the culprit but you can easily test that by swapping all parts from the 7005 into the 7004. All parts are interchangeable.
    • Tempic
      • May 2021
      • 3
      • Deutschland
      I already tried that as described above but it did not work.
      What can go bad on a panel itself? There isn't really any electronics on that part.
      • Naushad
        • May 2021
        • India
        dear ,
        please try to update with latest software,
        most of the no picture issue can solve with software update.
        • budwich
          • Jul 2015
          • 3097
          there are small long driver boards along the bottom of the frame of the set. You should check the smd components therein particularly with respect to the capacitors. Of course, it would be a good idea to measure voltages that appear somewhere on the cards (as labelled) to see what's up. Since you can make the set of cards work with the broken panel, you have a basis for the comparison when doing the same measurements with the non-displaying panel. Go from the results.
          • Techforfun
            • Dec 2021
            • Nederland
            Hi Tempic,
            Have you found the problem? I have the same issue
            My regards
            • Storyteller12
              • Jun 2020
              • 625
              The panel are compatible if the tcon boards are the exact same. Sony TVs can’t always just swap boards without updating the software as mentioned by Naushad
              Try updating the software and see what happens.
              It could also be the panel is no good. Try unplugging one side of the lvds cables from the tcon to the panel and see if you get any picture on half the tv
              • Techforfun
                • Dec 2021
                • Nederland
                Originally posted by Storyteller12
                The panel are compatible if the tcon boards are the exact same. Sony TVs can't always just swap boards without updating the software as mentioned by Naushad
                Hi storyteller,
                How can I activate the bootloadet? The stand-by is still white. And isn't blinking green and orange
                • yalcintatar
                  • Mar 2016
                  • türkiye
                  Hello, give me emmc bin for Sony LED TV with model number 1-981-926-22. files are required. Could you please help?​
                  • rimwall
                    Sony KD-65x7500D - double image - Tcon or Panel?
                    by rimwall
                    This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                    I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                    11-18-2025, 02:09 AM
                  • Daren87
                    Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                    by Daren87
                    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                    08-13-2023, 03:25 PM
                  • huzo
                    Dell 5590 no image on LCD,HDMI works ,the board works...
                    by huzo
                    The board is LA-F411P ,DELL 5590 ...
                    The screen polarises,no backlight,no image,only black screen,tried another screen,the same,so there is no backlight,but there should be an image when i shine a lamp behind the screen,but there is none...only dark screen...when screen is connected and i press F8 to turn the image over to the external monitor, the external monitor gets coloured bars ,but when i disconnect the cable from the EDP ,the HDMI picture is good...What could be the problem? I don't have another edp cable, but i measured it with meter and it comes out good...i am baffled......
                    02-16-2025, 03:08 PM
                  • zaurus81
                    Yashi All in one model AY62409 (Quantum S 24'') no image (backlight works)
                    by zaurus81
                    This chinese all in one computer gives an image when connected to an external vga monitor but only the backlight with integrated monitor (no image). Initially I thought it was an edid problem on the eeprom of the screen but then I saw that the monitor works correctly with another identical motherboard (model th410-d4, read by bios). Unfortunately the motherboard is chinese and has no brand or codes on the pcb. The format seems ITX. Nothing can be found online. The official yashi site provides drivers but not the bios. The electrical diagram is obviously unobtainable
                    The board is equipped...
                    01-16-2025, 03:54 AM
                  • bbrain
                    Sony KD-55AG9 TCON?
                    by bbrain
                    I have this problem with my Sony 55' AG9.
                    It flashes 4x.
                    I have found the service manual, and seems it is the TCON.
                    Before I buy a TCON can someone check the vid?
                    Thanks in advance!...
                    09-19-2024, 10:50 AM
