Samsung TV - no backlight, except when mainboard disconnected
    • 12206
    • U.S.
    Re: Samsung TV - no backlight, except when mainboard disconnected
    OF COURSE resistors can fail short: https://www.allaboutcircuits.com/tex...lure-analysis/
    • diif
      • Feb 2014
      • 6978
      • England
      Have a read of this, there's no need for the all caps. https://www.eevblog.com/forum/beginn...-do-they-open/
      They go high resistance or fail open in my experience.
      • lotas
        • Jan 2016
        • 4661
        • Russia
        And there are "they" (resistors) with low resistance and the multimeter will show a short circuit.
          • 12206
          • U.S.
          Originally posted by diif
          have a read of this, there's no need for the all caps. https://www.eevblog.com/forum/beginn...-do-they-open/
          they go high resistance or fail open in my experience.
          i will put all caps wherever i feel it necessary but thanks for sharing your opinion, its definitely worth what i paid for it.
          • Bigfoot
            • Mar 2023
            • 12
            • Usa
            Hi guys
            I'm working on similar Samsung TV UN60J6200AF.
            When I plug in power cord, the red light lights up.
            I measured on the power supply board, and even without pressing the power on button in getting on CNM803 (which goes from Power supply to Main board):
            UD = 2.3V
            PMW_BLU4 = 3.3V
            PS_ON = 4.4V
            A13V = 12.75V
            I looked at the manual and all the voltages are correct.
            When I unplug the main board from the power supply, LED lights are supposed to come on. However, non do come on.
            I then measured at the LED connector CNL802:
            D+ to D - = 419V
            And yes, that's 419VDC lol.
            Is it safe to assume all my LEDs are burnt? Also CNL802 only has one positive and one negative connection. I'm assuming all the LED strips are connected in series.
            Should I try to light up the LEDs with a tester next to verify they work?
            Any other ideas what to try? Why is the DC voltage so high, is that normal?
            This is the first time I have ever opened up a TV, but it's a lot more fun than just junking it.
            All your help is much appreciated.
            • Rajnhl
              • Oct 2018
              • 94
              • India
              #26
              check LEDs with tester. I think they are all burnt. 419 vdc s too high.check for a mosfet on solder side, i think D- is not directly grounded.
              • Bigfoot
                • Mar 2023
                • 12
                • Usa
                #27
                Thank you, I will check LEDs today.
                Correct D- is not grounded. Non of lines on the connector are grounded, which I thought was very strange.
                But why do you think i immediately have fully operational voltage even when on standby mode? Bad main board perhaps?
                • stefanodave
                  • Dec 2019
                  • Italy
                  #28
                  Originally posted by zoidberg123
                  I am troubleshooting a Samsung ue48h6400aw. When plugged normally, trying to turn it on leads to blinking power light 7 times and no backlight. If I press buttons I see the corresponding power light flashing (that it acknowledged the action).
                  If I unplug the mainboard from the power board and plug in the TV, the backlight turns on.
                  Does this mean it's 100% the mainboard and I should replace that? Or it could still be the power board?
                  Would appreciate any input, thanks!
                  -Gil
                  hi, i have same your problem but with another tv samsung UE55H6670SZ
                  you have solve? Thanks
                    • 12206
                    • U.S.
                    #29
                    @stefanodave. Start a new thread since you have a different model, read this: https://www.badcaps.net/forum/showthread.php?t=39740
                    • Henke
                      Samsung TV HG46EB690QB No picture, only backlight when disconnected mainboard
                      by Henke
                      I came across a Samsung tv that does not seem to start up. When i plug it in nothing happens except that the red led turns on. But when i disconnect the mainboard, the backlight turns on and immediately turns back off when i connect the mb again.
                      I have tried to disconnect one, none and both cable(s) from the Tcon to the screen but it makes no differens. The PSU seems to work, but when the mb is connected one of the 5V cycles high and low.
                      Anyone with inputs?...
                      10-27-2022, 01:01 PM
                    • stylishconsultant
                      un60j620dafxza - Samsung No Display Problem
                      by stylishconsultant
                      Hi All,
                      Need help.
                      I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                      So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                      problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                      might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                      09-04-2024, 03:26 AM
                      09-07-2024, 05:50 AM
                    • K212
                      Samsung QE65Q700TATXXC is not starting
                      by K212
                      my Samsung QE65Q700TATXXC has stopped working recently. It worked fine during the morning, and when trying to start it later the same day it just refused to start.
                      The standby LED is working, but nothing happens when pushing the power button, other then the LED blinking once. No picture, no sound, no chime, no relay click. I tried a cold start, and other recommended fixes from Samsung. Nothing worked. Then i even tried to reflash the firmware, but nothing happened, not even flashing of the standby led etc.
                      I contacted Samsung support who said it is most...
                      07-31-2025, 12:45 PM
                    • badboyzzz
                      Samsung UE50AU8072 all time rebooting, backlight ok. Maybe mainboard faulty?
                      by badboyzzz
                      The motherboard initially receives voltage for VGH, but it constantly reboots. When I remove the flex cable at the bottom, I hear normal sound, but there is no image on the screen and it is black on both sides. This time there is no voltage on VGH.
                      03-25-2025, 10:48 AM
