Another LCT2662 with badcaps
  • cmj21973
    • 267
    First , my name is Chris and new to thhis site. Hope i'm putting these in the right place if not, i'm sure i'll hear about.
    I was given a LCT2662 that quit working. I came from an investment bank/stock exchange were it was set to the stock exchange. My guess it was on 24/7/365 as the remote still had original batteries with almost full charge.
    Looked here before deciding to keep it or trash it. After looking at the three PCB's (pcb#1 tuner, pcb#2 audio/main, and pcb#3 PSU) I decided to recap it to see if it will work, and yes I play the lottery hoping to win BIG! LOL!
    Question #1
    What's the best place to order caps that are all the same brand, and what is the best brand? I plan to replace all radial caps with high temperature caps, all 110. The hardest ones to locate are two 100uF 450V, slim pickens.
    Question #2
    Does anyone have the service manual for this tv? The one I got from here has a totally different schematic and bill of material. I have included photos.
    Question #3
    In photo #2, there is a component I believe to be a crystal/oscillator that was leaking like a cap. It's mark as H27.000M and is located at Y1, below the heat sink in the middle and to the right of the three clustered caps. I need it's specs to order a new one. If it leaked, replace! Photo #4 is a closeup of said component.
    Question #4
    What to use to clean up cap puke from the PCB's?
    Any and all advice and help would be appreciated.
    P.S. I tried to attach the four photos, but they're too large to upload. E-mail me at cmj21973@yahoo.com and I'll send them to you.
  • cmj21973
    • 267
    Re: Another LCT2662 with badcaps
    Here's the photos thatgo with my original post.
    • PlainBill
      • Feb 2009
      • 7034
      (Everyone) Hi, Chris.
      You did, and you would have.
      Question #1
      I prefer to use Panasonic FM or FC series caps from Digikey (www.digikey.com). Other brands are also good; you can fine a list of preferred brands and series in the "Which Caps Should I Buy" thread in the FAQ. Don't get hung up on using the same brand for all of them.
      Question #2
      Search, and search again. Searching for 'schematic' tends to produce better results, but it's still hit or miss getting what you need.
      Question #3
      That IS a crystal. They don't leak.
      Question #4
      I don't see any evidence of leakage, perhaps a better closeup would help.
      Buy low. Sell high.
      Don't publish your email address in an open forum.
      Wash your hands before you eat.
      Flush.
      Warm cookies and cold milk are good for you.
      When in doubt, ask.
      PlainBill
      • cmj21973
        • 267
        Thanks PlainBill.
        I removed whatever it was around the crystal, to see the Y1 print on the PCB, before I took the photo.
        I'll order my caps and post an update after I recap it.
        • PlainBill
          • Feb 2009
          • 7034
          Thanks PlainBill.
          A couple of other points: The power supply appears to have a Power Factor Correction front end. If I am correct, the two 100uF, 450V caps must be low ESR per Wizard.
          When selecting caps, make sure you have sufficient room for the replacements. From personal experience, a cap of a specific size / voltage can be available in three different physical sizes (regular, short, and long). It's frustrating to have ordered the regular when you needed the short.
          PlainBill
          • cmj21973
            • 267
            Your correct. That's why I mention them being a problem. There are two Al plates I had to remove to access the caps. I have located replacements, EKMQ451VN101MQ25S by UCC ( United Chemi-Con). They're the only two caps that are not Panasonic.
            Another question, has long as the replacement cap's capacitance is the same it's voltage can be higher correct?
            • PlainBill
              • Feb 2009
              • 7034
              Yes, with a warning. A cap with a higher voltage rating may be in a larger package, so make sure it will fit.
              PlainBill
              • cmj21973
                • 267
                I've been side tracked but back on track.
                I'm replacing all caps with Panasonic FC series A type except for two 100uF-450V caps, they're Panasonic HC series TS type. Had to change part supplier. First choice's back order was into late August, final choice's is into middle of May.
                Found a cheap source of thermal compound .798 oz for $4.22 tax included.
                I'll place my order in a couple of days to allow for any replies. Meanwhile, workbench is prepped and waiting.
                • iKitsune
                  • May 2010
                  • 61
                  Omg, I just fixed one of those myself. For a cheap lil' TV, they're not tooooo terrible. Just don't plan on using it with any reasonable VGA resolutions, unless you like the words "Main Not Support!!" I used a mix of EPCOS and United Chemicon caps on mine, and despite being the brutally wrong caps, it's held up for about 5 months now.
                  • cmj21973
                    • 267
                    UPDATE
                    My caps came in and I double checked that they're the right values and quantities. Decapped all three boards with 45watt desoldering iron from the Shack. I'll recap the tuner (pic 1) and main (pic 2) boards tomorrow. As for the power (pic 3 & 4) board, I need fix the area damaged by the leaking electrolytic.
                    I'm think of using Dullcote Lacquer, to cover the exposed copper, before recapping it. I'll try it on a pratice board first.
                    • Scenic
                      o.O
                      • Sep 2007
                      • 2640
                      let's just hope you took notes which caps went where before desoldering all of them
                      • cmj21973
                        • 267
                        I took notes and photos. I also printed B&W 8.5 x 11 of each board, and used double stick photo tape to attach each cap.
                        Can't recall offhand what its called, but I reffer to them as a "Build Board".
                        • cmj21973
                          • 267
                          UPDATE
                          I used the Dullcote lacquer to repair the PSU, and recapped all three boards. Checked solder joints, removed flux residue with hot water,Dawn dishsoap, and toothbrush. Rinsed with water and aired dried, in front of fan, overnight. Rinsed again with 91% alcohol.
                          Applied thermal compound, from local auto parts store, and reinstall AL plates on the PSU.
                          Installed PSU only and powered up, no smoke and no BANG! Only noise is a buzzing sound while on standby. Install MAIN board , only connecting to the PSU, and powered up, no smoke and no BANG! Still buzzing sound. Installed TUNER board, only connecting to the PSU, and powered up, no smoke and no BANG! Still buzzing sound.
                          I reconnect the rest of cables and reassemble the tv set. I connected a tv cable, A/V input source, and turn on the set. Still a buzzing sound while in standby mode, may be normal I don't known, but the buzzing sound does go away when out of standby, ie when watching tv.
                          For $58.16, I now have a working AKAI LCT2662N 26" Wide-Screen LCD TV
                          Thanks again PlainBill for your help and input.
                          • saimom
                            Asus FX507ZC4 DANJLFMBAB0 REV B I need photos
                            by saimom
                            Hello everyone!
                            Please help me determine which microcontroller was in this place.
                            Logically, I guess that this is a ddr4 PWM memory controller and some kind of Richtek, but which one?
                            Thise motherboard came after another service, where they say that water got on the controller and it burned down and they dismantled it.
                            They did not take photos before the intervention
                            The DANJLFMBAB0 REV B board, schematics, boards and photos of the motherboard were not found on the network, but I may have searched badly-((
                            Maybe someone has a photo of this piece,...
                            12-17-2024, 08:51 AM
                          • Davi.p
                            Reduce the size of photos please..
                            by Davi.p
                            Hi all, i'm asking all to reduce photos to a more comfortable resolution before post, the better like around 2000x2000, otherwise many PC / Tablets / phones refuses often to load them or has strong defection... today's digital cameras integrated in phones especially are a mockery because them saves photos at enormous resolutions with much less the real definition, so reducing them is only a good deal.. THANKS!!...
                            05-16-2024, 12:53 AM
                          • cmlewis89
                            LG 47LB5DF blown power supply board
                            by cmlewis89
                            Hi folks,
                            I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                            09-03-2024, 07:50 PM
                          • AJ847.63e
                            Which software do you guys have the best of luck with for recovering corrupt photos?
                            by AJ847.63e
                            Hi All,
                            My WD external drive I used to use for my backups recently decided to go belly up on me so I've been playing around with different bits of software to try see if I can recover it and just wanted to get some advise on which programs you guys have the most success with.
                            Yes I've cloned the drive and no I'm not paying a grand to take it to a professional. If I can get some stuff back great, which I have, but there's still quite a lot I haven't. It's not worth taking to a professional though it's only my programming courses and vacation stuff so it's a nice to...
                            06-26-2023, 06:39 PM
                          • AZZEDGPU
                            Help please to identify ic of RX 6600 eagle Gigabyte (not xt) attached photos.
                            by AZZEDGPU
                            Help please, i need to identify this integrated, i came to the conclusion that it is a 5v output ic.
                            Attached photos, please thank you very much....
                            06-09-2023, 08:39 PM
