Samsung UN48H6350AF Black Screen, No Sound
  • mlemon
    • Feb 2021
    • 34
    Issue with my TV:
    1. The standby red LED continuously flashing red with dark screen. Pressing the power button manually or from the remote has no effect
    2. When and if all the cables are connected, the display is dark, nothing appears on the screen.
    3. The flash light test of the LCD display does not produce any images that is because there is no power reaching the LCD from the Tcon board.
    4. The Tcon board gets no power at all on pins 47 to 51 (according to the legend) of flex cable from the MB, expected 12 to 13V. The fuse on the Tcon is NOT open, I verified. And there are 3 LEDs on the Tcon board, none is lit, supposedly blue. Again, the Tcon board does not get power from the MB board therefore, I do not expect these blue LEDs to light up.
    5. The Main logic board gets the 13VDC from the PS. I am very confident the PS has no issue given I verified all the voltages with and without load (cable to backlight LEDs and cable to to MB).
    6. If I disconnect the flex cable from MB to the Tcon board, the backlight LEDs start flickering at the same frequency as the flashing red light, appears that way anyway.
    7. If I disconnect the power cable from PS to the MB, the backlight LEDs will light up and say lit with Blue screen while the standby red light still flashing
    8. Disconnecting the speaker and power board/IR board from the PS has no effect.
    9. Here are the voltage readings on the PS plug to the MB:
    Again, pressing power button has no effect but the PS to MB makes a bit of a difference on some readings, the Even pins [2,4,6]:
    Connector CNM803 - PS <---> MB. All measured Voltages:
    (Even Pin#)
    All Cables connected PS <---> MB Disconnected
    2 OD/UD 0.1 - 2.47V 2.29V
    4 BLU ON/OFF 0.0 - 0.15V 3.3V
    6 PS ON/OFF 0.0 - 3.30V 4.46V
    8 GND 0.0 0.0
    10 GND 0.0 0.0
    (Odd Pin#) - same values when all cables connected and disconnected.
    1 A13V 12.12 - 12.77V
    3 A13V 12.1 - 12.77V
    5 A13 12.1 - 12.72
    7 A13V 12.1 - 12.72
    9 GND 0V
    My observation is that the CP or BGA on the MB keeps resetting probably on Pin 6 (PS ON/OFF). I did back trace pin 6 and 4 with some measurements on the MB but could not find anything shorted or open, at least nothing obvious. And nothing charred or burnt on any of the boards.
    Also, I heated the BGA with hot air gun for 3min and did not make any difference.
    All indications point to the MB but I am more interested in figuring out which component (s) is faulty. Replacing a whole board takes the fun out of it and frankly not worth the cost given how expensive they are. So any help or pointers much appreciated. Thanks
  • mlemon
    • Feb 2021
    • 34
    Re: Samsung UN48H6350AF Black Screen, No Sound
    PS: Plz ignore the "blue" LED on the Tcon. This is not my board. Ones on my board (3 LEDs), none light up due to NO power getting to the Tcon board. However, 2 out of the 3 LEDs do light up when I checked by Multimeter, the 3rd looks burnt out which should not effect the function of the board as it is just an indication LED.
    • neilc6
      • Nov 2015
      • 1550
      Tcon voltage typically comes from a power supply and is switched through a FET with a control signal from the processor on the main board. Either the control signal is not going high or the FET is bad. Usually a few pins on the outer side of the LVDS cable carries the voltage.
      • mlemon
        • Feb 2021
        • 34
        Yes, the outer lines 47 to 51 on the LVDS suppose to carry that voltage from the MB to the Tcon but re not present. I will reinvestigate around those lines on the MB side for FET control signal or faulty one. Thanks for the reply
        • mlemon
          • Feb 2021
          • 34
          However, the Tcon in my situation is probably secondary issue if any. The reason is that when the Tcon LVDS is completely disconnected, the TV still behaves the same; continuous flashing red and backlight LEDs flickering. Again pointing to the MB. Thanks
          • mlemon
            • Feb 2021
            • 34
            Here is the LVDS image. Highlighted in yellow the power lines to the Tcon from MB.
            • mlemon
              • Feb 2021
              • 34
              I would like some help on identifying the specs on this component on the MB next to the LVDS; Q201_NHSP (DFPA15 written on it). It's a 6pin that looks like an IC but am suspecting it is a dual MOSFET. See attached image with red arrow showing location.
              I can't find any info on it online as I would like to replace it. I appreciate all the help.
              • mlemon
                • Feb 2021
                • 34
                Re: Samsung UN48H6350AF, Standby Red Light Continuously Flashing, No Pic or Sound
                Originally posted by mlemon
                Issue with my TV:
                (Even Pin#)
                8 GND 0.0 0.0
                10 GND 0.0 0.0
                5 A13 12.1 - 12.72
                7 A13V 12.1 - 12.72
                9 GND 0V
                All indications point to the MB resetting but I am more interested in figuring out which component (s) is faulty. Replacing a whole board takes the fun out of it and frankly not worth the cost given how expensive they are. So any help or pointers much appreciated. Thanks
                The tv looks its continously restting.
                • mlemon
                  • Feb 2021
                  • 34
                  Finally fixed by replacing the MB as I could not source a major component that I am confident is the culprit, the CPU.
                  All the MB voltages read correctly however they kept resetting which after further investigation pointed to the CPU. I did try reflow the CPU using my Hot air station for nearly 8 min at 480C but did not help. I would have liked to replace the CPU but I could not find online.
                  So I ended up buying a brand new MB not exactly the same but it worked. This MB is same PCB layout but missing one USB and HDMI and couple of supporting components which I am thinking to source from the original defect MB. And at a cost of $35 compared to the original one which is very hard to find for $100 or more.
                  Additionally, the Tcon had bad LED2 which I managed to buy from surplus Excess Solution in San Jose, CA and fixed that.
                  Here is the MB I bought in eBay but picked up in person, very close to me so was great:
                  https://www.ebay.com/itm/28286238088...Cclp%3A2334524
                  • mlemon
                    • Feb 2021
                    • 34
                    Tcon tiny green LED is one I replaced. Original was blue I assume based on other two & from a pic I see elsewhere
                    • mlemon
                      • Feb 2021
                      • 34
                      And with new MB
                      • mlemon
                        • Feb 2021
                        • 34
                        Update: I was able to find a CPU but too late now
                        • m1ch43lzm
                          by m1ch43lzm
                          05-12-2025, 08:37 PM
                        • howardc64
                          by howardc64
                          Problem
                          08-04-2024, 10:36 PM
                        • advant
                          by advant
                          02-03-2020, 12:25 AM
                        • maxim2511
                          LG 55EC930V OLED - swich on swich of no screen
                          by maxim2511
                          My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                          Then I get an idea to take it apart and clean boards from dust.
                          In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                          Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                          05-14-2021, 02:21 AM
                        • TheDando
                          MSI GS66 Stealth 11ue-007us Board Number MS-16V41 VER.1 Screen Connector
                          by TheDando
                          Hey guys I've got a MSI GS66 Stealth 11ue-007us Board Number MS-16V41 VER.1 with a broken screen connector on the motherboard.I was wondering how I would go about finding a exact replacement for it.I can't seem to find any schematics that would help me so I'm kinda stumped.I did buy a screen connector that I thought was close enough but it doesn't really invoke much confidence in me that it works perfectly as plugging the screen into sometimes does output a "glitchy" image for just a few seconds.So now I'm kinda in a cross road where I'm pretty sure it could be a faulty screen but I...
                          10-28-2024, 06:59 PM
