LG 60PN5300 Broken hdmi Exploded part id help!
  • a460guy
    • Oct 2013
    • 59
    • it's
    Picked up this 60" LG today that has a broken hdmi port and and exploded diode? Maybe? Looks like i can fix the port but the other part that got very hot, quick, i dunno.. anyone know what part or parts, im missing ? please advise...
  • mmartell
    • Oct 2013
    • 3189
    Re: LG 60PN5300 Broken hdmi Exploded part id help!
    Check the part number of the board itself on shopjimmy you might get lucky and find a high res pic that will shed some light on the part layout in that area.
    • R_J
      • 9588
      Q604 = ZXMP3F30FHTA Mosfet
      • a460guy
        • Oct 2013
        • 59
        • it's
        Thank you for the part help. well i put the hdmi port back on and replaced the mosfet. Tv came on for a few seconds and then the mosfet burned up again.
        do you think the hdmi port damage is the cause or something else?
        • a460guy
          • Oct 2013
          • 59
          • it's
          Pic of port before i put it back on
          • edugimeno
            Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
            by edugimeno
            Hi There!
            I'm trying to help my friend who owns a restaurant be just bought.
            He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
            It's stuck using, I guess, the 2 sided tape that comes with the strip
            The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
            09-05-2024, 09:34 AM
          • G-Sting
            iPad Pro A1876 SHORT Part Identify Help Needed
            by G-Sting
            So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
            So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
            i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
            SO My main concern is what part should i order what should i search the name for ?
            on Ipad...
            05-15-2025, 09:30 AM
          • aliougm
            Marantz SR4003 AVR HDMI board issue, seeking for help
            by aliougm
            I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
            Connection as below:
            Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
            If I bypassed AVR then HDTV screen color be good.
            I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
            3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
            I replaced all...
            04-30-2022, 12:21 PM
          • Harry2k1
            HP 17-cn0152ng part U201 Q300 broken
            by Harry2k1
            A USB device has caused a short circuit and a component on the mainboard 17N-8L-TGL Was destroyed. The component is labeled U201 Q300. What type of component is this?
            Can I replace it?
            What else could be affected if a USB port and the speakers no longer work?
            04-22-2025, 05:14 AM
          • japlytic
            Certain DisplayPort-HDMI cables can disable HDMI CEC communication
            by japlytic
            With a setup including a TV and AV receiver where HDMI Consumer Electronics Control (CEC) and Audio Return Channel (ARC) functions were working, these two functions stopped working after changing some connections (not the one between the AV receiver and TV), so I believed it was a corrupt setting in the AV receiver or TV, but when I disconnected a passive DisplayPort-HDMI cable (which a Multimode DisplayPort connector supports HDMI with a low cost passive cable or adaptor) connected to a home theatre PC, HDMI CEC and ARC functionality was restored.
            An examination of the HDMI CEC wiring...
            07-10-2022, 09:48 PM
