TNPA5608 panasonic PSU dead
  • disorder
    • Sep 2015
    • 156
    • france
    hello,
    make new thread to discuss about psu issue
    on same tv panasonic 42E5 series, that take storm lightning and motherboard fried
    the PSU not works, got 325 on big cap primary section
    no other stable voltage, on primary mosfet i have got 325V on drain, 0V on source and gate
    the voltage near ic 730 are unstable too
    not find shorted cap
    the only thing i find strange on this is only 130 on diode mode on d7211 in both ways (the diode is ok desoldered)
    burnt area near primary mosfet , replace it but no fix
    what can i chekc now please ?
    thank you
  • Diah
    • Feb 2013
    • 6599
    Re: TNPA5608 panasonic PSU dead
    the critical points at Panasonic TNPA5608 are the PFC Control IC if i remember correct ic7201 with 8 pins
    • disorder
      • Sep 2015
      • 156
      • france
      ok thank you i'll check that
      • Jane
        How do you test MOSFET in laptops ?
        by Jane
        I tried to use this method:
        Testing an N-channel MOSFET:
        Step 1: Discharge the Gate (turn off the MOSFET)
        Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
        Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
        Step 2: Charge the Gate (turn on the MOSFET)
        Now, place the red probe on the Gate (G) and the black probe on the
        09-27-2024, 03:31 AM
      • Wolf1977
        general question when a mosfet on primary of transformer is burned
        by Wolf1977
        hi
        in a welding machine i had a mosfet and four components wich connect with it burned
        i ordered all the damaged components and replace it but when i put the device on the plug all the components burned again i had tested before and i had not shunts
        i dont understand whats happen wrong
        more particular on the schematic q11p01 mosfet q11p02 tranzistor
        three paralel resistors had burned q11p07 zener shunt q11p08 open
        when i changed all these shunts q11po7 mosfet and tranzistors
        maby the transformer has problem on your opinion or something on...
        08-19-2023, 01:27 PM
      • roxboy1984
        Dell E5530 completely dead and MOSFET getting HOT! Please help.
        by roxboy1984
        So I'm trying to fix the above mentioned dell laptop. It has no signs of life at all when plugged in. If I connect the AC I noticed the MOSFET PQ5 gets very hot. So I'm assuming there is a short somewhere. I'm still learning so please could someone assist me. Thanks for any help given.
        I did try swopping the Mosfet which is a AO4423 with one from a donor board being a SI4483ADY as they both have the same VDS @ 30V. once I swopped the Mosfet when I plugged in the charger it would just switch off so I swopped the MOSFET back....
        11-02-2022, 12:28 PM
      • Nooy
        VGA MOSfet permanently shorted and loss of MOSfet pad
        by Nooy
        Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
        I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
        02-14-2024, 02:26 AM
      • BigPete
        Panasonic Heatpump Dryer Repair
        by BigPete
        I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
        The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
        In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
        Unfortunately the whole machine has to come apart to fix it.
        I have...
        11-01-2025, 06:40 PM
