Sharp aquos lc-40le820e power on problem
  • j120975
    • Aug 2020
    • 6
    • greece
    Good afternoon to all of you. First of all sorrybfor my bad English. I have a sharp aquos tv ,and i m dealing this problem. If i leave the power cord disconnected,then it starts normally for one minute approximately. After that the tv restarts and only the touch panel lights working for about 10 seconds and only 1-2 seconds lights up the led panel. After that loop again. No signal lights in center. I think probably is a power supply problem . I can see 5 v ,13.3v in 4 pins . I m a mobile technician and i can follow your instructions if you yave some suggestions. Thank you in advance.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Sharp aquos lc-40le820e power on problem
    What is the power supply board number. Is it DPS-126CP ????
    If it is then you need to measure the voltages on connector PD pins 9, 10 and 12
    • j120975
      • Aug 2020
      • 6
      • greece
      Pin 9 1,20v at the beginning and 3,0v after 2 seconds .pin10 3,05v ,pin12 0,12v. Board is dps-126cp-1 a
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Pin 12 = 0.12V
        The Panel Power (PNL-POW) signal derived from the mainboard is not present (missing). PNL-POW switches on Q7909 to provide the 12V for the Panel,
        You should be able to press Menu on the remote control and use a bright light shone on the LCD screen at various angles to see the Menu displayed.
          • 12328
          • U.S.
          Maybe check your voltage regulators also, video example there: https://www.youtube.com/watch?v=ocqnqmBxiqY
          • j120975
            • Aug 2020
            • 6
            • greece
            this morning update.After many hours with power cord disconnected ,i plugged this morning and everything works fine for 1 minute.All voltages present.13.3v,5.0v,high voltage capacitors 308volts on stand by and 400+when on.But after one minute ,disaster again.Now high voltage capacitors is 316 volts on stand by ,5,0v present and 13v only for 3 seconds when i press the on button on the remote control.And only 2 quick flashes on central pyramid and 1 longer period led off
              • 12328
              • U.S.
              Check all the diodes on the powerboard, meter in diode mode, should get a reading in one direction then reverse meter probes should read 1 or OL if any read strange de-solder one leg and test out of circuit, keep in mind that other components on the circuit can make it read strange while still in circuit. So if any read off in circuit tell us which one/s, then we can check if there's a reason why it might read off.
              • j120975
                • Aug 2020
                • 6
                • greece
                These diode's are shorted when in circuit.(d7717,d7703) Out of circuit is ok. So ,what component should i check; The strange thing,is that. If i power on the tv today ,after a few days off,is working perfectly for a minute. After that lights on-off.
                  • 12328
                  • U.S.
                  Some testing there, does seem like a mainboard issue, maybe check the voltage regulators on the mainboard as he is in the video: https://www.youtube.com/watch?v=ocqnqmBxiqY
                  • j120975
                    • Aug 2020
                    • 6
                    • greece
                    So , update. I check the mainboard today ,and i found that. These three capacitors are shorted to ground when the are on circuit. I desolder them ,and they are ok. The short-circuit is coming fro this ic3604. This is the M2303ADN. Maybe a suggestion of equivalent ic;
                      • 12328
                      • U.S.
                      See if that's it: https://cdn.badcaps-static.com/pdfs/...4969373d5b.pdf
                      • theone111
                        by theone111
                        3. Problem: TV shuts down
                        07-22-2024, 10:36 AM
                      • Duranitron
                        Asus x512dk rev 2.1 power on problem
                        by Duranitron
                        When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                        Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                        11-26-2024, 10:22 PM
                      • WVUfan
                        PS5 EDM-033 One Beep,No Lights, No Power Troubleshooting Help
                        by WVUfan
                        hello. i've a ps5 edm-033 mobo w/ no power, lights, but one beep when power pressed. i've hooked to uArt and only error code is 80871001 (DDR4 No Power or Short Circuit). i have a donor board, same model, that does power up, fan spins, blue light, and beeps 3 times, then powers off. it has a botched HDMI port replacement job. so w/ the board i'm interested in, with the error 80871001, i was able to research and obtain voltages of the SSD PMIC. i've attached pictures of the provided diagram by DylanBBK (@d62 on Discord) and my voltages and picture of my board. my question is on my picture...
                        08-11-2025, 01:12 PM
                      • berrmich
                        Sharp LC-C4655U Flashing OPC and Power lights.
                        by berrmich
                        I have the above TV. Black screen. Power blinks 2 times. OPC blinks once. Plug in with channeldown/volup. Powers up with solid green power but no light. I removed, cleaned and tightened the screwed on the inverters. I tested plug coming from the power supply to the inverter board when unplugged. INV12V shows 7.4 V DC. INV60V shows 0.1 or something like that. After plugging in the cable I don't get meaningful voltage from either one. (I measured after booting the TV with channeldown/volup.)
                        Is this a bad power supply? Or am I measuring something wrong.
                        -Mike
                        08-19-2023, 11:32 AM
