Samsung LE37R88BDX/XEU BN44-00157A Turns off after 10 minutes
  • Ukdigger
    • May 2020
    • 121
    • England
    TV works normally for about 10 minutes then the picture freezes and then the TV goes into a restarting loop. All the voltages seem ok and all the caps on the power board look ok and test ok with ESR meter. Inverter board to power board lead has burn marks at the power board end as shown in pictures. No signs of burning on the inverter board and caps test ok. Not sure if this is a problem but Diode DM804 (schematic D2) on the power board reads as shorted in circuit but disconnecting one leg it reads normal. Disconnecting the inverter board makes the TV stay on permanently with all voltages testing as in diagram. Any help would be greatly appreciated.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung LE37R88BDX/XEU BN44-00157A Turns off after 10 minutes
    On the surface those reading look ok except you have 24V on CNM803 pin 10 which I suspect is in error.
    You could try a can of freezer spray ( or inverted can of air duster spray) to cool down the EEPROM or BGA IC's on the mainboard and see if that helps.
    DM804 is in parallel with a 0.2 ohm resistor so would read short when still connected to the board.
    • Ukdigger
      • May 2020
      • 121
      • England
      Yes I made a mistake on the voltages it should have been a ground on CNM803 pin 10.
      There's a big heat shield covering the chips so I put a computer case fan on top and powered it up and it doesn't shut down anymore. So something is getting too hot.
      • Ukdigger
        • May 2020
        • 121
        • England
        Found a main board on ebay for £23 with all the numbers matching the old board. Everything seems to be ok now with the bonus of having a UK tuner, the old one was locked on Hong Kong region with no other options so the clock was always a few hours out on the guide which was very annoying.
        • dskall
          • Oct 2016
          • 2905
          • usa
          Hope you took care of the connector problem.
          • Ukdigger
            • May 2020
            • 121
            • England
            I made a mistake, the main board on ebay for £23 was for a 40 inch Tv in one of my other posts.
            I removed the big heat shield covering the chips and noticed heat colour distortion and brown circular marks where the two capacitors had been touching it. I put a PC heat sink on the graphics chip and the TV worked with no problems. I drilled extra holes it the heat shield cover so that the capacitors didn't touch it anymore and the TV has been working with no problems now for 2 weeks.
              • 12200
              • U.S.
              Nice fix.
              • cheeky2
                • Dec 2012
                • 337
                Just go into the service menu and change the screen details then the board will work with your TV. Compare the details with your existing main board (take pictures is easiest) and modify the 40inch one to your existing faulty one. Press info menu mute and power button on remote control quickly to access service menu. Turn power to standby to implement changes after you have modified settings and exit the service menu. Don't change any settings besides screen types.
                • Ukdigger
                  • May 2020
                  • 121
                  • England
                  The problem came back again so I removed heat shield and tested the 2 caps with mustimeter in diode mode, one was reading 440 and the other was reading 118. I replaced the low reading one with a new 1000uf 16v normal cap and replaced the heat shield and it seems to be working normally again. I will update if anything goes wrong.
                  • ohren
                    by ohren
                    09-08-2023, 05:24 PM
                  • C152Heavy
                    by C152Heavy
                    Summary for TL-DR readers:
                    • VCC pin (18) of PFC...
                    01-11-2023, 02:53 PM
                    09-07-2024, 05:50 AM
                  • Nicktronic
                    Samsung Power Supply Board BN44-00874F
                    by Nicktronic
                    Hey everyone,
                    This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                    Anybody...
                    03-17-2025, 06:20 AM
