Re: Soniq E40S12A-AU Stuck In Standby
resistor need high watt ,1K 10 watt and up, bulb are better. as it can handle all kind of currents / watt with out any effect on the other parts in circuit
which wire ? the photo i added to you.. its any table lamp with filament bulb will have only 2 wire only which take AC from wall socket... this 2 wire one you connected with the wirw which you need to slide it out from the BL socket and the next of the bulb go to the socket at pin3
sockets on power boards PIn3 -------- table lamp ------- the wire go to backlightLeave a comment:
How about a resistor or something?Leave a comment:
if you dont have at home... dont go to buy LOL
we just want to add it to this pin 3 line to increase resistances in hope the circuit remain on so you can use the TV.Leave a comment:
I'm struggling to grasp where the wires come from?Leave a comment:
where are the bulb ??
man its just table lamp... what do you call it in yours country ??? take a lookAttached Filesif you find these attachements useful please consider making a small donation to the site
If I'm understanding you correctly, I may have something suitable; please see the attached photo & let me know if I'm on the right track?
It is basically a switch that plugs into the wall, with the two bare wires available at the other end.....Attached Filesif you find these attachements useful please consider making a small donation to the site
normal bulbs used in table lamp etc which u used to plug it in wall socket AC ... dont beak it to take out the filament LOL.... just use it as it. so if it installed in table lamp example the socket of the table lamp where you pülug it in wall take the wire out and put them end to end between the mentioned pins. ( dont forget if you use any table lamp or other device with this bulbs be sure if there switch need to be ON LOLLeave a comment:
Or do you mean connect a wire to each of a bulb's nodes?Leave a comment:
Do you mean the filament from inside a light globe?
Like, smash the globe to rip out the filament?Leave a comment:
let us add resistances to this line to trick the circuit keep on in case need.
if you have "table lamp" with filament Lamp from the sockets take out the 2 wire of it and connect them between pin3 ( after you slide it out from sockets ) and the sockets pin3 , just try will not harm the BL or the circuit.
if you dont have then you must take out the screen.Leave a comment:
Hello again, sorry to let the issue go a bit stale.....
With black probe on chassis ground and red probe on each pin, here are the measurements:
VCC 1 (Pin 1) = 74V Powering On & 5.2V Post Boot
LED 1 (Pin 2) = 11V Powering On & 11V Post Boot
LED 2 (Pin 3) = 11V Powering On & 0.6V Post Boot
VCC 2 (Pin 5) = 74V Powering On & 5.2V Post Boot
LED 3 (Pin 6) = 11V Powering On & 11V Post Boot
LED 4 (Pin 7) = 11V Powering On & 11V Post Boot
LED 2 (Pin 3) being the odd one out; hopefully this helps us progress?Leave a comment:
Thanks man, I will do that & report back tomorrow sometime...!Leave a comment:
you are not in stuck position at all.... we know the fault at LED backlight. and the screen must took apart to reach them for replace.
but i just keep writing to you on aim if we can use the TV with out take the screen out. to avoid panel broken or another cost of leds.
so do this test put the all pins in place and the black probe of yours meter on chassis and the red on all other pins one by one to read voltage at start ( when you plug the tv in wall ) remark the meter at start will go high then low then down when screen goes black. the reason i want to know exactly which line effected to consider way to trick it.Leave a comment:
Sorry, I meant to say Pin 3, not Pin 6; I tried 2, 3 & 7.....Leave a comment:
I just tried my luck with Pin 2 removed, but to no avail.
I put Pin 2 back in the plug, & tried again with Pin 6, & then Pin 7 but nothing made any difference.....
I am now completely stuck again; any suggestions?Leave a comment:
you can try not only pin 2 but also 3 and 7, the idea on remove. because we dont see the led strips to test leds direct. so if one get shorted this move could... could help depend on which surprise we have behind the screen.
all those move pin test will never harm the set or backlight.Leave a comment:
As I came to suspect yes, but I don't see how the 75V reading means the VCC Pin 1 & LED1/2 group is at fault?
Should I try to power on the TV with Pin 2 removed?Leave a comment:
so at first group VCC pin 1 and Led-1 or led-2 are fault. mean yours early measurements on pin6 not correct
att any way you have led backlight one at most LED are open.Last edited by Diah; 04-17-2021, 09:51 AM.Leave a comment:
Thanks Diah,
VCC (Pin 1) Rose To 75V & Then Fell To 5.2V Where It Stayed.
VCC (Pin 5) Rose To 80V & Then Fell To 5.2V Where It Stayed.
Hopefully this tells you something?Leave a comment:
by LoagzHi, I'm hoping someone can point me in the right direction....
I have a S55V14B TV and it suffered a board failure. Main board part number: 222-655036003-30. I couldn't find a board with the exact part number so I've used what looks to be the same board however the part number is slightly different. 222-655036002-30.
After installing the main board the stanby light came back on, however it wont turn on. I spoke to Soniq Australia and managed to get a copy of the firmware but no service manual. They don't have one. I asked about the different part numbers but they... -
by nubiePlease help me ID the blown chip and point me where the short might be.
I have a L1085DG that is getting really hot and a blown up standby regulator (I assume, one leg is ground, one leg is 5v standby, the other has 180 Ohms to ground.
The L1085DG is in the front corner of the board. With no standby power I am using a jumper to get the PSU powered on.
Anything I should check first for a short?
Edit: I can look again but I don't think the USB are shorted, on back or the headers. The USB2.0 are powering up my portable monitor, so I don't think... -
by samsonnI've got a 55" Soniq LED TV which is stuck in standby mode (initiator LED on, but no picture/sound/backlight). It will intermittently start working again for a few days or weeks, but it has been months since the last time it turned on. I've seen a lot of similar issues with Soniq TVs that were fixed by updating the firmware, but I need to turn it on to update the firmware so no luck there.
I've taken the back off and visually inspected it but everything looks fine. No exploded capacitors or signs of overheating etc. All of the 1117 regulators on the main board were outputting... -
by lego1234567Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
What could be the problem ? Thanks...2 Photos01-21-2024, 03:39 AM -
by StuntHi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
screen that's it and stuck there. I left it until the following day and i still...09-02-2025, 01:51 PM - Loading...
