Sony KDL-46EX500 2 blinks, then 6 blinks
  • chrisl32
    • Feb 2021
    • 39
    • france
    Re: Sony KDL-46EX500 2 blinks, then 6 blinks
    The TV has is 7 years old. I checked the capacitors with a Fluke 115 after desoldering them. I also have a small component tester (Multi-function tester T7), that I did not use ... my bad :-(
    I also just want to remind that the issue on this TV came after a lightning surge...
    The buzzing is a "physical" buzzing coming from the T6801 transformer.
    Just to know, before changing all capacitors, can you give an internal impedance value telling the capacitor has dried ?
    It will help in the future for other cases ...
    And for now, I'll check the capacitors again with the multi-function tester and report.
    Thanks again
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Lightning surges tend to take out semiconductor components, IC's and the like which are easily damaged by high static charge or voltage spikes.
      • chrisl32
        • Feb 2021
        • 39
        • france
        Yes, that's what I thought...
        • chrisl32
          • Feb 2021
          • 39
          • france
          I just tested the 270 microFarad 450V :
          238 uF __Vloss=0.7% __ ESR=0.34 Ohm with the T7 tester
          243 uF with the Fluke
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Have you lifted the panel to check if any one of the CCFL tubes are dimmer than the rest?
            What is the part number of U1 on the inverter board.
            There are a few 0 ohm resistors around it I would check out.
              • 12274
              • U.S.
              #26
              Maybe test all the components on the inverter board, found this, not seeing a lot of them, maybe you can find one locally, might be worth a shot?:
              https://www.ebay.com/itm/Sony-KDL-46....c101195.m1851
                • 12274
                • U.S.
                #27
                Another there for less: https://www.ebay.com/itm/Sony-46-KDL....c101195.m1851
                • chrisl32
                  • Feb 2021
                  • 39
                  • france
                  #28
                  No, being able to reach the tubes seems very difficult for me...
                  • chrisl32
                    • Feb 2021
                    • 39
                    • france
                    #29
                    what is the part number of u1 on the inverter board.
                    2903
                    pfsg
                    • chrisl32
                      • Feb 2021
                      • 39
                      • france
                      #30
                      If you mean JR1, JR2, JR3, JR4 on the inverter board, they are OK.
                      I also checked the others ones on this board...
                      • chrisl32
                        • Feb 2021
                        • 39
                        • france
                        #31
                        I think I tested all components on inverter board... except U1, as I don't really know how to test it.
                        Thanks very much for your ebay links. But shipping cost to France is too high.
                        I'll see if I can can find one more locally, and not too expensive, because this tv does not belong to me but to a neighbour, and I would like to minimize the cost... And also, be sure that I can repair it in the end (which is not absolutly obvious ...
                        • chrisl32
                          • Feb 2021
                          • 39
                          • france
                          #32
                          budm gave the link to his redlined power supply schematic in this post :
                          https://www.badcaps.net/forum/showth...607#post372607
                          and wrote :
                          "OK, this is how the board functions. I can explain in details as needed."
                          In his redlined power supply schematic, he writes in yellow squares :
                          LD = 11-12V = OK
                          and FB 0V = BAD
                          As my measures are :
                          LD = 12.10V and 12.09V during buzz
                          FB = 0,04V AC during buzz
                          Do you think my measures are OK ?
                          • chrisl32
                            • Feb 2021
                            • 39
                            • france
                            #33
                            I am sorry, I forgot to attach photos in my first post.
                            • chrisl32
                              • Feb 2021
                              • 39
                              • france
                              #34
                              This photo shows the reality well concerning the very weak intensity of the SONY logo during its very brief appearence (less than 1 second during the transformer buzz).
                              • chrisl32
                                • Feb 2021
                                • 39
                                • france
                                #35
                                Does anybody have any idea where to find the inverter board ssb460 schematics ?
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  #36
                                  Check C6618. If it's faulty then it may be responsible for reducing the drive signal to T6801 giving way to a lower HV1 & HV2 voltage
                                  • chrisl32
                                    • Feb 2021
                                    • 39
                                    • france
                                    #37
                                    Thank you dick_barton
                                    i checked C6618 :
                                    with T7 tester :
                                    C=976 nF __ Vloss=0.1 % __ ESR=0.23 ohm
                                    with Fluke :
                                    C= 980 nF
                                    I really have no luck ... all my tests show good components !
                                    I'd like to test HV1 and HV2, but the tension is of course too high for my testers.
                                    Maybe is it a faulty IC ?
                                    If I could have a schematic with planned tensions ...
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      #38
                                      I think the IC on the inverter board may be an LM2903. Low-power dual voltage comparator. Check the voltage between pins 4 and 8 to see if it has a supply voltage.
                                      • chrisl32
                                        • Feb 2021
                                        • 39
                                        • france
                                        #39
                                        Good idea.
                                        But I get 12 V
                                        • chrisl32
                                          • Feb 2021
                                          • 39
                                          • france
                                          #40
                                          I checked the other pins :
                                          1, 2 3 and 4 are connected to ground
                                          8___12V
                                          7___0.08V
                                          6___6.24V
                                          5___0.22V
                                          These values are NOT changing wether T6801 buzzes or not.
                                          Is this normal ?
                                          I'll try to follow the tracks around the LM2903 to see what is going on ...
                                          https://www.badcaps.net/forum/attach...1&d=1617965463
                                          • matwan
                                            Sony XR-55X90J 5 blinks
                                            by matwan
                                            I have problem with SONY 55X90J. After several check status is as below;
                                            1. Running power board as stand alone:
                                            TCON_12V =~ 12.6V
                                            EVDD V On Max 24V= 19V.
                                            2.
                                            Running power board with TCON as stand alone:
                                            Effect as below, attched.
                                            3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
                                            "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
                                            Best regards....
                                            09-28-2025, 04:26 AM
                                          • GoodCapDude
                                            Sony XBR-75X940E intermittent 6 blinks error code
                                            by GoodCapDude
                                            Hi everyone. First post on Badcaps!
                                            I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                                            09-20-2025, 06:07 AM
                                          • AK_777
                                            Sony KD-65A1 Repair – 4 Red Blinks Error
                                            by AK_777
                                            Hi everyone!
                                            I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                            Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                            02-20-2025, 04:15 PM
                                          • jchon
                                            Sony A1e 5-blinks help
                                            by jchon
                                            Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                                            I found the service manual, which was critical to know where to probe.
                                            https://www.manualslib.com/manual/20...1e-Series.html
                                            With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                                            Unfortunately the 5-blinks...
                                            06-28-2023, 11:52 AM
                                          • Nicktronic
                                            Sony XBR-65X850D 2 Red Blinks
                                            by Nicktronic
                                            I have the subject TV and it will work normally sometimes but suddenly go black and give the 2 red blinks blink code. When this happens, I check the power supply board voltages and all I have is the Standby 3.3V and BL_ERR 2.2V. When it's working normally, all power supply board voltages look normal and stable. I've checked the backlights with a tester and they all test good. I've also read that the 2 red blinks is a faulty power supply board, so could it be throwing up an erroneous BL_ERR?
                                            Any Sony experts out there that can help??...
                                            11-19-2023, 06:51 AM
