Sony XBR-75X940E intermittent 6 blinks error code
  • lotas
    • Jan 2016
    • 4751
    • Russia
    Originally posted by Davi.p
    why don't to try search for a led driver board by second hand? Which is its code? Is it so uncheap?
    1-897-091-11
    https://www.ebay.com/itm/236203861487
    • GoodCapDude
      • Sep 2025
      • 22
      • France
      Originally posted by lotas
      Interesting! Maybe I'll try that if what I'm trying now does not work out... Would it work with a European voltage? Thanks. I'm new to this and wasn't too sure and where to look for that.
      • tiki66
        • Jul 2016
        • 53
        • Croatia
        Originally posted by GoodCapDude
        Hi nomoresonys, thank you for the interest. I was planning to give an update once the story is over but it's still going on!
        So I went to a professional repair shop which is going to test the three boards (forming the power supply) one capacitor and other relevant items at a time (he told me he would desolder them and resolder them). Before that, I tried to ground the BL_ERR and the TV started to blink red four times instead of six times. I was not too sure what to make of that. I hope I did not damage the connector.
        Where and how did you ground BL_ERR?
        Also, I've never seen a bad LD board on Sony...
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4459
          • Italy - Milan
          OK so no BGA IC, then what could go bad temporarily are maybe those 4 electrolytics, but them are top brand, if i would be in you i would buy a very cheap chinese market multi tester with capacimeter/esr meter, and test them all, or give the board to the shop, the replacement of them is not so easy as the ground planes are big, since the set can fail to start so the problem is at cold, like all the bad electrolytics.. the metal cover could crate too heat, especially if the beast was hooked to the wall..
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4459
            • Italy - Milan
            Note: The heat is what usually kills the electrolytics.. need also to check their solder job for factory bad job
            • zomi
              • Nov 2011
              • 509
              #26
              Theres a couple of bl err lines on this looking at the schematic ?
              https://www.youtube.com/watch?v=31V_s17USnU
              its got like 500 plus leds..
              • GoodCapDude
                • Sep 2025
                • 22
                • France
                #27
                I have removed the 3rd pin on the connector between the G75 and the main board on the G75 side. I attached it to a screw hole.
                Not sure which one is the LD Board.
                Thanks!
                • GoodCapDude
                  • Sep 2025
                  • 22
                  • France
                  #28
                  I gave the three boards to a shop that is supposed to test them for 30€. Then they are going to give me a price for a possible repair.
                  The problem is not only "at cold". I mean if it has started, I can keep it working for 30 minutes, turn it off and then on and get the 6 red blinks. Not sure if that counts as "cold".
                  It has been hooked to a wall indeed. Thanks.
                  • GoodCapDude
                    • Sep 2025
                    • 22
                    • France
                    #29
                    Yes there are multiple BL_ERR connectors. I Chose the one between the power supply boards and the bkmp board like I saw a guy doing on a youtube.
                    There are 576 leds! It was good for 2017.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4459
                      • Italy - Milan
                      #30
                      OK so no electrolytics are the culprit, apart their solderings.. can you check this on the led/LD board?
                      • tiki66
                        • Jul 2016
                        • 53
                        • Croatia
                        #31
                        Thanks!
                        You can't do it like that, you have to follow my instructions to turn off BL_ERR
                        They can test shit without a tv.
                        • GoodCapDude
                          • Sep 2025
                          • 22
                          • France
                          #32
                          Ok. When you told me I had not decided to do it and then I forgot about your message. I'll try that then. The result I had with what I did was 4 blinks error. At this point, I can't test anything as the boards are at the shop. I think the idea was that they would check soldering and the relevant components but Davi.p seems to think that since I can get the failure with a "warm circuit", I can rule out the defective component part.
                          I think I'm gonna test it with the parts coming back from the shop. From what you guys are saying, it is unlikely that there will be an improvement. Then I'll try to ground the other BL_ERR like tiki66 is saying and I'll throw the towel if it does not work.
                          Someone I know had this TV, bought a bravia 9 because of the error and I said I would have a go at fixing it although I am not sure of what to do with it as I'm more of a projector guy. I thought it was still a nice piece of equipment and that maybe I could give it to someone but it is really a pain to move from one place to another! I think that when I'm done with the shop and the BL_ERR, I would have gone as far as I reasonably could. Trying to buy boards seems to be a little too much. It can be expensive (the shipping can be $60!) and there is no guarantee of success. Thanks for your help everybody. I will keep you posted on what happens.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4459
                            • Italy - Milan
                            #33
                            What do you mean? All three boards can be connected toghether and turned fully on and tested with test loads..
                            OP: have you checked the el.caps. soldering on the led board? It's 30 seconds test..
                            so to repeat one second, TV set turns on with blinking error both when at cold and at warm?
                            It's a suspicious situation for a real electric fault, i would surely try to update the software.. as soon as possible..
                            otherwise the second suspicion is the main processor with some bad soldering.. i hope you would sell or give for free the set
                            and not trash it, it's a sin..
                            • tiki66
                              • Jul 2016
                              • 53
                              • Croatia
                              #34
                              They can't. Where is the backlight? Even one wonky LED could trigger backlight error.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4459
                                • Italy - Milan
                                #35
                                But no.. i mean, the direct feed for the led is the led driver board, the function of the "brown boards" are only to feed low volts, to the Main-tcon-led board, them are completely testable...
                                • zomi
                                  • Nov 2011
                                  • 509
                                  #36
                                  Maybe best just to strip the lcd and look at the leds if all else fails
                                  Backlight error codes tend to always be backlight issues 99.9 % of the times
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4459
                                    • Italy - Milan
                                    #37
                                    Zomi do not confuse normal back light with local dimming one, the circuits are a lot different..
                                    • zomi
                                      • Nov 2011
                                      • 509
                                      #38
                                      Apologies my mistake, please disregard.
                                      • GoodCapDude
                                        • Sep 2025
                                        • 22
                                        • France
                                        #39
                                        So I got the three boards back from the shop. The guy just charged me the diagnostic fee. He did however some very minor work on the board (some resoldering and he replaced a small component, all on the G75 board). He told me he "found the problem", and pointed out this part of the board:
                                        • GoodCapDude
                                          • Sep 2025
                                          • 22
                                          • France
                                          #40
                                          He was not too specific, told me some contacts were not good. That some capacitors were weak but that it was not worth changing them. He discouraged me from getting a board on ebay and declared the case closed. The TV is not repairable according to him. Yet he told me to send him a message if the minor work that he did improved anything.
                                          It did not. I put the boards back in and the behaviour of the TV seems the exact same as before (either turns on and works normally or goes to 6 red blinks error right after startup).
                                          I have tried to tinker a bit by disconnecting and reconnecting all the ribbons on what I think is the "LED board" (see pic below). To no avail. I'm wondering if I should not ask someone else to change all the capacitors on the boards as a last ditch effort...
                                          • Curtissimo
                                            HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
                                            by Curtissimo
                                            Hi everyone.
                                            I have a HP Elitebook 850 G8.
                                            Serial: 5CG2324XM0
                                            ProdID 6L8D5EC#ABA
                                            It has a Winbond W25Q256JVEN Chip.
                                            I need to remove BIOS Password.
                                            I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
                                            Attached my dump.
                                            I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
                                            I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
                                            What I did:...
                                            08-26-2025, 04:42 AM
                                            LCD LED TV Service Menu Codes
                                            ALL LCD LED TV SERVICE MENU CODES
                                            Service Menu Code with Board Name
                                            China Universal Board / Jumper Board Service Menu Code
                                            Changhong Ruba Service Menu Code
                                            Ecostar LED TV Service Menu Code
                                            Orient LED TV Service Menu Code
                                            Haier LED TV Service Menu Code
                                            TCL LED TV Service Menu Code
                                            Samsung LED TV Service Menu Code
                                            LG LED TV Service Menu Code
                                            Videocon LED TV Service Menu Code
                                            Supra LED TV Service Menu Code
                                            Toshiba LED TV Service Menu Code
                                            Symphony LED TV Service Menu Code
                                            Veste/ LED TV Service Menu Code...
                                            10-31-2024, 03:58 AM
                                          • matwan
                                            Sony XR-55X90J 5 blinks
                                            by matwan
                                            I have problem with SONY 55X90J. After several check status is as below;
                                            1. Running power board as stand alone:
                                            TCON_12V =~ 12.6V
                                            EVDD V On Max 24V= 19V.
                                            2.
                                            Running power board with TCON as stand alone:
                                            Effect as below, attched.
                                            3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
                                            "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
                                            Best regards....
                                            09-28-2025, 04:26 AM
                                          • AK_777
                                            Sony KD-65A1 Repair – 4 Red Blinks Error
                                            by AK_777
                                            Hi everyone!
                                            I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                            Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                            02-20-2025, 04:15 PM
                                          • jchon
                                            Sony A1e 5-blinks help
                                            by jchon
                                            Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                                            I found the service manual, which was critical to know where to probe.
                                            https://www.manualslib.com/manual/20...1e-Series.html
                                            With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                                            Unfortunately the 5-blinks...
                                            06-28-2023, 11:52 AM
