a320ap20s4lv0.4 appears vertical lines where ever there is text
  • ridaKHI
    • Mar 2021
    • 16
    • Egypt
    I have a problem with my Samsung LCD panel a320ap20s4lv0.4. There appears vertical lines where ever there is text . See my pictures.
    Could this be fixed by cutting some kind of tracks on PCB that drives the LCD panel?
    vgh even vgh odd signal from Shift Register
    and directly connected to panel?
    Thanks for all the help in advance.
    panel: LTI320AP01
    panel PCB a320ap20s4lv0.4
    main board: 090-6M1814-03
  • Diah
    • Feb 2013
    • 6599
    Re: a320ap20s4lv0.4 appears vertical lines where ever there is text
    log in service menu and play the pattern test , see the lines cleared or not.
    also you can play jpg format photos with different pattern to test too
      • 12331
      • U.S.
      Test those caps and resistors you have there on your driver board, test them for shorts/opens, there's a crapload of how to videos on youtube if needed.
      • ridaKHI
        • Mar 2021
        • 16
        • Egypt
        send me the video please
        caps c3,c4 is shorted and i remove it . the short not gone . someone told me the caps is connected wit to ground lines
        • ridaKHI
          • Mar 2021
          • 16
          • Egypt
          it appear also with OSD menu
            • 12331
            • U.S.
            Check the nearby caps, check them all...tv no worky with short.
              • 12331
              • U.S.
              Do the caps read short off the board?
                • 12331
                • U.S.
                One example there, watch it: https://www.youtube.com/watch?v=jLd6QO7Z7m4
                • ridaKHI
                  • Mar 2021
                  • 16
                  • Egypt
                  the caps is so good
                  when i removed it
                  the short is in board between ground and the ferret coil marked 220
                  • ridaKHI
                    • Mar 2021
                    • 16
                    • Egypt
                    i also checked all passive component
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4542
                      • Italy - Milan
                      Hi, there are some videos on how to solve this, start from YT channel "electronica nunez tutoriales" and search the web for the panel's model code, also arabian videos..
                      • ridaKHI
                        • Mar 2021
                        • 16
                        • Egypt
                        I can't find any solving method on web
                        • ridaKHI
                          • Mar 2021
                          • 16
                          • Egypt
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4542
                            • Italy - Milan
                            https://youtu.be/hMTX_nXfAEs start with this..
                            • ridaKHI
                              • Mar 2021
                              • 16
                              • Egypt
                              thank you Mr.Davi.p
                              but i need know the reason of this problem
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4542
                                • Italy - Milan
                                Why?
                                • Stanley1843
                                  by Stanley1843
                                  06-29-2024, 11:54 AM
                                • pni
                                  LG 49uf695v vertical coloured lines
                                  by pni
                                  Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                                  11-14-2025, 03:15 AM
                                • Falki
                                  Colorful LCD Vertical Lines on Samsung ue55es8090
                                  by Falki
                                  Hello there, ive recently found an older 55inch Samsung SmartTV.
                                  A similar issue has been posted as well but also with no actual response ...
                                  08-12-2025, 04:19 AM
                                • visionbluedemon
                                  Help. Sony kd-65x85dj vertical lines
                                  by visionbluedemon
                                  First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                                  Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                                  tried blocking LC lines too, but same results
                                  is it lcd panel issue or tcon board issue?...
                                  07-25-2025, 04:56 AM
                                • gpo23
                                  Sony KDL-40V3000 - Vertical lines
                                  by gpo23
                                  i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                  With the new t-con the color are good but there are vertical lines on all the screen :
                                  I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                  Is there a way to fix the vertical lines on the new t-con ?
                                  Thank you for your help
                                  gpo23...
                                  10-04-2023, 09:11 AM
