a320ap20s4lv0.4 appears vertical lines where ever there is text
  • ridaKHI
    • Mar 2021
    • 16
    • Egypt
    I have a problem with my Samsung LCD panel a320ap20s4lv0.4. There appears vertical lines where ever there is text . See my pictures.
    Could this be fixed by cutting some kind of tracks on PCB that drives the LCD panel?
    vgh even vgh odd signal from Shift Register
    and directly connected to panel?
    Thanks for all the help in advance.
    panel: LTI320AP01
    panel PCB a320ap20s4lv0.4
    main board: 090-6M1814-03
  • Diah
    • Feb 2013
    • 6355
    Re: a320ap20s4lv0.4 appears vertical lines where ever there is text
    log in service menu and play the pattern test , see the lines cleared or not.
    also you can play jpg format photos with different pattern to test too
      • 12097
      • U.S.
      Test those caps and resistors you have there on your driver board, test them for shorts/opens, there's a crapload of how to videos on youtube if needed.
      • ridaKHI
        • Mar 2021
        • 16
        • Egypt
        send me the video please
        caps c3,c4 is shorted and i remove it . the short not gone . someone told me the caps is connected wit to ground lines
        • ridaKHI
          • Mar 2021
          • 16
          • Egypt
          it appear also with OSD menu
            • 12097
            • U.S.
            Check the nearby caps, check them all...tv no worky with short.
              • 12097
              • U.S.
              Do the caps read short off the board?
                • 12097
                • U.S.
                One example there, watch it: https://www.youtube.com/watch?v=jLd6QO7Z7m4
                • ridaKHI
                  • Mar 2021
                  • 16
                  • Egypt
                  the caps is so good
                  when i removed it
                  the short is in board between ground and the ferret coil marked 220
                  • ridaKHI
                    • Mar 2021
                    • 16
                    • Egypt
                    i also checked all passive component
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4289
                      • Italy - Milan
                      Hi, there are some videos on how to solve this, start from YT channel "electronica nunez tutoriales" and search the web for the panel's model code, also arabian videos..
                      • ridaKHI
                        • Mar 2021
                        • 16
                        • Egypt
                        I can't find any solving method on web
                        • ridaKHI
                          • Mar 2021
                          • 16
                          • Egypt
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4289
                            • Italy - Milan
                            https://youtu.be/hMTX_nXfAEs start with this..
                            • ridaKHI
                              • Mar 2021
                              • 16
                              • Egypt
                              thank you Mr.Davi.p
                              but i need know the reason of this problem
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4289
                                • Italy - Milan
                                Why?
                                • Stanley1843
                                  by Stanley1843
                                  06-29-2024, 11:54 AM
                                • gpo23
                                  Sony KDL-40V3000 - Vertical lines
                                  by gpo23
                                  i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                  With the new t-con the color are good but there are vertical lines on all the screen :
                                  I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                  Is there a way to fix the vertical lines on the new t-con ?
                                  Thank you for your help
                                  gpo23...
                                  10-04-2023, 09:11 AM
                                • Firentiosi
                                  1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                                  by Firentiosi
                                  Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                                  The issues are as follows: the...
                                  11-27-2024, 12:33 AM
                                • viking509
                                  vizio e65 e3 LED tv color vertical lines center tv only
                                  by viking509
                                  I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
                                  03-21-2023, 12:48 AM
                                • noisykid
                                  Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                  by noisykid
                                  5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                  12-30-2024, 07:15 PM
