Vizio M60-C3 Image Issues
  • Fredfrederson
    • Feb 2021
    • 4
    I have an Vizio M60-C3 got it originally with a power on light and no picture would flash power light 15-16 times. Power board checks out and got a main logic board for it. It now powers with a bluish image, back light working. This post https://www.badcaps.net/forum/showth...ghlight=m60-c3
    Seems to show that removing the perimeter ribbon cable could fix it. Just want to make sure that's the next step. And a quick description of how if I mess anything up its ruined. Thanks for any help.
    Pic #1: Screen powered and menu lightens/darkens it
    Pic #2: White side is with T-con cable disconnected
  • Fredfrederson
    • Feb 2021
    • 4
    Re: Vizio M60-C3 Image Issues
    No one? Guess I'll just dive in. Worst case a slower track to the bin of electronics.
      • 12272
      • U.S.
      Everything you need to know about the side tab peel off is in this thread, a lot of times the tell tale sign was distortion and or horizontal __, not vertical | line/s:
      https://www.badcaps.net/forum/showthread.php?t=49281.
        • 12272
        • U.S.
        Explanation was for the folks who get horizontal and vertical mixed up, believe it or not it happens quite a bit.
        • frannyjunk
          • Oct 2010
          • 82
          My guess is either bad tcon board or bad panel.
            HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
            This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
            09-12-2024, 02:20 PM
          • Charleyd
            Vizio V585-H11 No Image Puzzle
            by Charleyd
            When plugged in, Vizio V585-H11 powers up, the standby light flashes 18 times, but there is simply no image on the screen. I can see a glow from the backlights, and the sound works. Tearing in to it, all voltages coming out of the Power Supply appear reasonable. I suspect a bad panel, so I disconnect one of the two wide ribbon cables between the T-Con board and the panel. Now the TV starts up fine without the 18 flashes, and with a good image on 1/2 of the screen. If I switch to the other ribbon cable, the TV again starts up fine, but now with a good image on the other 1/2 of the screen. Still...
            04-09-2022, 09:17 PM
          • Jaime Morillo
            Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
            by Jaime Morillo
            Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
            The TV was stuck on the logo and I couldn't access the update menu.
            I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
            The image result was good, but the image is inverted.
            The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
            Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
            08-18-2025, 11:38 AM
          • x_orange90_x
            Vizio V585-J01 dancing lines and image doubling
            by x_orange90_x
            I got this tv yesterday and it shows a screen full of colored vertical bars and horizontal lines that move, change, and dance around. When the set is powered on there is a slight buzz from the tcon. I removed one ribbon at a time and this was the result:
            Right side connected, left side disconnected = half image on right (somewhat distorted, see photo attached) white screen on left. NO buzzing from TCON
            Left side connected, right side disconnected = right side black, left side white with distorted horizontal lines near top of screen. Buzzing from TCON
            I swapped...
            06-12-2024, 07:57 AM
