LG 42LN5100 no backlights
  • provider10
    • Mar 2016
    • 52
    • South Africa
    Hi
    I have this LG with no backlights using the backlight tester seems the LEDs are OK
    Theproblem seems to be the FET that pulls the LEDS to ground has anybody had tis FET(Q802) fail
    James
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: LG 42LN5100 no backlights
    Are you sure it's the mosfet. There's plenty of Youtube videos showing how to test them. Have you checked if the mosfet is being driven?
    Do the backlights flash momentarily as you switch on?
    Have you checked if the "DRV_ON" signal is present. Connector P701 pin 2
    https://www.electronica-pt.com/esque...s-lb35b-34067/
    • chrismurphy
      • May 2014
      • 251
      • australia
      these are notorious for failed backlights
      Not worth repairing
      • provider10
        • Mar 2016
        • 52
        • South Africa
        Hi thanks for the reply. I don't think its the LED strips as I have bought a tester and the panel lights up ok .
        The positive voltage is on one end of the strips but there is an FET that i think switches the other end of the strips to earth. I was wondering if anybody has had this fet go faulty or if the circuit driving the IC gives problems
        I do not get a momentary flash and yes when switched on I get a voltage on the DRV ON pin
        James
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          The mosfet is driven by the led driver IC so if that is not driving the moseft then the led current will not flow to ground.
          Have you any voltage from CS_LED to chassis?
          What voltage do you have on pin 16 of U103
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            My mistake. Please ignore CS_Led and U103 voltages. I was looking at the wrong diagram.
            What is the part number of your power supply?
            • provider10
              • Mar 2016
              • 52
              • South Africa
              Hi
              The number on the power supply is 3PCR00275B
              James
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                The power supply should have a number should be something like "LGP42 13PL1 EAX64905301"
                What voltage do you have at the led connector on pin 7 (P801) when you first power up. Does the voltage peak sharply and drop just as quickly.
                What voltage do you have on P802 again when you first power up.
                Have a read through https://www.badcaps.net/forum/showth...hlight=17ips20
                • provider10
                  • Mar 2016
                  • 52
                  • South Africa
                  The number is LGP421-13PL1 (PLDF-l205B)
                  There is a very short flash from the LEDs at switch on.
                  When i measure on the lead to the LEDs on one side I get a varying voltage of around 120 v and on the other side a varying voltage of about 230v. Yet if I measure across the socket I get 0 volts
                  • provider10
                    • Mar 2016
                    • 52
                    • South Africa
                    across c214-204 I have a stable 115volts. On switch on this voltage goes unstable varying from 103 to 113 volts
                    • neilc6
                      • Nov 2015
                      • 1550
                      Flash of backlights is a symptom of bad backlights. https://techhometravel.com/lg-ln-ser...ed-backlights/
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        The led voltage for that model is 157.5V so it would appear as neilc6 has just said that you have a led(s) or led strip connection problem.
                        • angelos
                          • Dec 2012
                          • 571
                          • South Africa
                          Just a quick question. these LN model backlights are those with the concave lenses, right? They are so expensive here in my country that they cost about 35% the price of a new tv. Has anybody come up with a cheaper way to repair or replace them? This would really help me out.
                          And... yeah, i agree with what was said. LG's are notorious for having their backlight fail anything from 1.5 years from purchase and onwards.
                          • angelos
                            • Dec 2012
                            • 571
                            • South Africa
                            Another note! Don't think if your backlight tester drives your LED's that they are 100% ok.
                            One symptom is a drive voltage on the tester that is bouncing around. In other words it goes 57.4V then 63V then 52V. That indicates a faulty LED strip. The other thing is that even if the LED tester drives the backlights steady you don't know for sure if that is correct because the tester drives it at a reduced current and not at 100% of full current like the TV set does.
                            You will have to open up the panel and observe what happens. Are there dead led's etc
                            • neilc6
                              • Nov 2015
                              • 1550
                              LB/LF series uses the large concave lens. Also 55" LN series as well. Lots of vendors of strips on Aliexpress that ship worldwide.
                              • angelos
                                • Dec 2012
                                • 571
                                • South Africa
                                Yes, aliexpress has but what they don't have is a reliable shipping method to this dump of a country of ours so there is no cheap shipping method.
                                For example. A 55" LG TV's backlights cost $22, lovely. Then comes our favorite rip offs DHL charging $123 and on top of it once the package has arrived at their customs then thy want an importer license etc. So now they want to ship it to my area, a remote outlying area so they want more money. At this rate let me do the conversion, R2175 at an exchange rate of 15:1. Hey guess what, i can buy them from the LG agents at the same price. Aliexpress has completely failed us here in South Africa because our local postal service has collapsed.
                                Anyone heard of www.bangggod.com, they are a online sales platform somewhere in the orient and they have circumvented this shipping nighmare.
                                They have their own customs (China) divizion called Buffalo logistics and they send your parcel via a chain of clothing suppliers (PEP Stores) right to my town i a matter of 18 days. There the shipping is $6, bloody excellent. Problem is banggood do not do much electronic spares. pity though.
                                Just thought i would vent my frustration here, sorry.
                                • angelos
                                  • Dec 2012
                                  • 571
                                  • South Africa
                                  Oh yes and if you find a suppler that is willing to send it via free shipping method you wait 4 months to maybe receive it. Again, collapsed postal service.
                                  • nomoresonys
                                    • 12206
                                    • U.S.
                                    Yes, if you mean Banggood they are ok, probably ships even faster than aliexpress, maybe recheck your spelling.
                                    • angelos
                                      • Dec 2012
                                      • 571
                                      • South Africa
                                      yes, like i said 18 days from payment to delivery. Currently wit alibullcrap i wait 4 months on average for a parcel to arrive. A huge difference hear. I am trying to convince aliexpress to change their shipping method but all i get to speak to is a bot.
                                      • provider10
                                        • Mar 2016
                                        • 52
                                        • South Africa
                                        Thanks to everybody that replied to my post.
                                        75 and still learning.
                                        I don't get much work as I am semi retired but I bought an LED tester from Banggood.
                                        And as the lights seemed to light up OK. I looked for other faults anyway opened it up and found 3 LEDs SC
                                        So once again for the help and patience
                                        I will know in future
                                        Regards
                                        James
                                        • Pipolups
                                          Corsair K70 LUX RGB dying LEDs
                                          by Pipolups
                                          Hi there !
                                          I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                          Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                          10-08-2024, 11:58 AM
                                        • max789
                                          Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                                          by max789
                                          Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                                          I made the following tests:
                                          1. Disconnected the main board from Power Board = backlight works.
                                          2. Connected the main board and disconnected the T-Con = backlights does not work.
                                          So I ordered a main board from Ebay also BN41-02156A but from...
                                          01-18-2024, 06:56 AM
                                        • bpcannan
                                          VIZIO M557-G0: Backlights or ???
                                          by bpcannan
                                          'Morning,
                                          I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
                                          Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
                                          I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
                                          I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
                                          10-29-2023, 06:36 AM
                                        • THE GTC
                                          Insignia NS-37D20SNA14 intermittent LEDs
                                          by THE GTC
                                          So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
                                          When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
                                          11-03-2020, 02:40 AM
                                        • AJ847.63e
                                          A2338 Screen replacement - Clarification needed. What do you actually loose when replacing the screen with OEM Pulls?
                                          by AJ847.63e
                                          Hi All,
                                          Just wanted to get some clarification on replacing screens on M series machines (M1,M2,M3,M1pro,M2pro,M3pro) as there is so much conflicting information out there. Some say even when using OEM pulls you lose True Tone and only that, others say you lose that and webcam, others say you lose those two and also the lid sensor will not work, others say you lose nothing as long as you use OEM pulls.
                                          So, which one is it actually? Using original OEM pulls. That seems to be what has caused the confusion, people using cheap aftermarket than being surprised when it does not work...
                                          03-06-2024, 06:44 PM
