LG 42LN5100 no backlights
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: LG 42LN5100 no backlights
    If you replace the led strip remember to turn down the backlight since the leds are often overdriven at 100% which drastically reduces their life span.
    • angelos
      • Dec 2012
      • 573
      • South Africa
      What i m in the process of doing is every tv whose panel i open up to work on i take notes of the LED strips (Stripe model number) and LED size and bias voltage. I also write down the bias voltage for entire LED string. Then if i pick up a problem i already know what the led bias voltage should be without having to open up the panel to find shorted LED's> This saves time on the long run. Also when quoting on a tv whose backlights are faulty i don't have to open up to get an idea of the led strip type. I can quote directly.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        That could be a useful sticky.
        • Pipolups
          Corsair K70 LUX RGB dying LEDs
          by Pipolups
          Hi there !
          I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
          Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
          10-08-2024, 11:58 AM
        • max789
          Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
          by max789
          Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
          I made the following tests:
          1. Disconnected the main board from Power Board = backlight works.
          2. Connected the main board and disconnected the T-Con = backlights does not work.
          So I ordered a main board from Ebay also BN41-02156A but from...
          01-18-2024, 06:56 AM
        • bpcannan
          VIZIO M557-G0: Backlights or ???
          by bpcannan
          'Morning,
          I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
          Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
          I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
          I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
          10-29-2023, 06:36 AM
        • THE GTC
          Insignia NS-37D20SNA14 intermittent LEDs
          by THE GTC
          So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
          When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
          11-03-2020, 02:40 AM
        • pni
          Backlight panel diffuser melt by backlight leds broken
          by pni
          Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
          10-12-2025, 12:08 AM
