Insignia ns-55d420a16. Blinking red light no backlight
  • knoxrebel
    • Oct 2009
    • 168
    Tested power supply output getting 12 volts with no main board. Tested with main board 12 volt output is dipping appears that power supplies restarting. Hooked external load directly to 12 volt and it's doing the same thing. Suggestions?
    • 12276
    • U.S.
    Re: Insignia ns-55d420a16. Blinking red light no backlight
    Try heating the electrolytic capacitors on the powerboard with a hairdryer, see if the voltages stabilize if only for a bit.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      What load did you put on the 12V supply line. It says maximum 3 Amp. Does the 14V supply line also drop in line with the 12V ?
      • knoxrebel
        • Oct 2009
        • 168
        Unfortunately no change. 12v drops to 3v then cycles between 0 and 3v. Remove all but main filter caps and tested esr, they are all low, but i believe .02 is within spec for a 25v 1000Uf low esr cap.
        • knoxrebel
          • Oct 2009
          • 168
          Not sure on the load, but it was dialed all the way down.
          The board silkscreen showed 16v not 14, and its didn't match up with the connector so i assumed it was incorrect. I'm not getting any other voltage other than the 12 with or without the mainboard plugged in.
            • 12276
            • U.S.
            Look the solder joints over on the powerboard real closely, see if you have any bad/cold joints. As always be VERY CAREFUL when dealing with the DEADLY/HOT side of the board.
              • 12276
              • U.S.
              Also check over the diodes and resistors if you haven't already.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                If your power supply matches the schematic then if the 12V is running so should the 14V (16V) because they are both derived from the same transformer T831
                If that supply is missing then you need to double check all the components in that area.
                  • 12276
                  • U.S.
                  maybe also check VD829, VD825 and VD805.
                  • knoxrebel
                    • Oct 2009
                    • 168
                    Thanks for the assistance. Ended up being VD819 (MBR101 50 CTF - E1 434881). Having trouble finding a suitable replacement.
                    Would FCH10A20 suffice?
                      • 12276
                      • U.S.
                      Data sheet FCH10A20: https://www.alldatasheet.com/datashe.../FCH10A20.html
                      Data sheet MBR10150CTF-E1: https://www.alldatasheet.com/datashe...150CTF-E1.html do those match up?
                      • YasaCh
                        Sony kdl 40p5500 red light keeps blinking 3 times
                        by YasaCh
                        Hello...
                        my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                        i opened the back cover no sign of damage on the powery suply or motherboard
                        when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                        another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                        07-07-2025, 11:53 AM
                      • Fergal22
                        Samsung UE40F5300AK blinking red light
                        by Fergal22
                        I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
                        When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
                        I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
                        Any help would be appreciated...
                        02-02-2023, 09:19 AM
                      • cajoeg
                        Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                        by cajoeg
                        Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                        The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                        02-10-2025, 04:01 PM
                      • roy.zhero
                        Sharp LC50LE752E no picture and backlight, indicator light is lit
                        by roy.zhero
                        I acquired a free 50” TV. IT is a Sharp LC50LE752E. It does not show a picture and has no backlight, although the indicator light turns blue meaning it has turned on.
                        When power is plugged in, the indicator light will turn on blue, the backlight stays off and nothing is visible, even with a flashlight. When pressing the touch buttons on the tv nothing happens. When pressing buttons on the remote control the indicator light will blink indicating the IRsignal was received, but nothing happens.
                        When I hold the force-on-combination it will turn on. It then shows a perfect...
                        09-20-2020, 01:57 PM
                      • learnmore
                        Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                        by learnmore
                        Hello Community!
                        CASE DETAILS
                        Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                        13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                        Tried inserting firmware on USB and left it in for a few hours, but no change
                        03-03-2024, 09:49 AM
