Philips 55PFL7007H Vertical lines
  • Wiebotje
    • Jan 2021
    • 9
    • Belgium
    Dear Repair friends, this is my first post from the small country Belgium...
    I have a TV, a Philips 55PFL7007H/12 - QFU1.1E-LA Chassis
    It has vertical lines in the image.
    Some of the the lines are deviate very sharp, some have a mild brightness deviation.
    I added pictures to clarify.
    What i already did:
    - Reseated and cleaned all flex connections
    - Checked 12V power to the board = OK
    - Reflowed the main BGA of the TCON Board
    Possible causes of these defects:
    - Panel defective (distortions also noticable at just over the other half of the screen)
    - TCON defective
    - Loose BGA connections at the mainboard Fusion processor. The V-By-One connection to the TCON is located at one of the corners of the main processor where the solder balls break the earliest.
    Next thing to do: Reball the Fusion Processor at the Main board
  • Wiebotje
    • Jan 2021
    • 9
    • Belgium
    Re: Philips 55PFL7007H Vertical lines
    Did not reball the processor. Thinkt it's not possible that this is the main board...
    The distortion is static, it does not move. Pressing the screen at the bottom doesn't change anything. Heating up the TCON same thing, no change. Looking into the close-ups, it's always even or uneven lines that are affected...
    How probable is it that the panel is defective?
    • zen
      • 511
      Hi
      Unfortunately don't have direct experience on this model,but from other sets i work on,would be leaning toward panel or T-CON.
      • Wiebotje
        • Jan 2021
        • 9
        • Belgium
        Thnx for the reply Zen,
        the former owner informed me that these lines suddenly popped up during watching and never dissapeared. This makes me think more like TCON...
        • Beeldbuisje
          • Jul 2020
          • 57
          • Belgium
          Fur sure a defective panel. Equipped with a Samsung panel i guess?
          Samsung 3D panels of that age starts to get this behavior very often. They're also used in Loewe tv's, Samsung itself etc.
          I've seen this issue many, many times. It's begun last year.
          The connections of the banding cables on the glass of the panel become loose. I never was lucky enough to restore this.
          • Wiebotje
            • Jan 2021
            • 9
            • Belgium
            Hmmm, in that case i'm going to demount all the parts and sell them separately.
            Beeldbuisje, got a spare mainboard of a Philips 42PFL6907H by chance?
            • Stanley1843
              by Stanley1843
              06-29-2024, 11:54 AM
            • pni
              LG 49uf695v vertical coloured lines
              by pni
              Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
              11-14-2025, 03:15 AM
            • Daren87
              Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
              by Daren87
              I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
              08-13-2023, 03:25 PM
            • Falki
              Colorful LCD Vertical Lines on Samsung ue55es8090
              by Falki
              Hello there, ive recently found an older 55inch Samsung SmartTV.
              A similar issue has been posted as well but also with no actual response ...
              08-12-2025, 04:19 AM
            • gpo23
              Sony KDL-40V3000 - Vertical lines
              by gpo23
              i order a t-con because i had bad colors on my SONY KDL-40V3000 :
              With the new t-con the color are good but there are vertical lines on all the screen :
              I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
              Is there a way to fix the vertical lines on the new t-con ?
              Thank you for your help
              gpo23...
              10-04-2023, 09:11 AM
