Westinghouse 19" with no DTV
  • emilime75
    • Jan 2010
    • 18
    Hello everyone. I recently acquired this LCD DTV as non-functional. The model is an SK-19h210s. It was totally dead so I decided to take it apart and see what I could find. It turns out someone had already been in there as every plug/cable was disconnected and 1 cap had been replaced. While it was apart I found a bad surface mount fuse so I temporarily jumped it and put everything back together. The tv powered on and seems to work, for the most part. However, I am not able to get a picture from my PS3 or from my DVD player using the component connection. I did get a signal from the DVD player using HDMI but I haven't tried it with the PS3. The second problem I have, which really is the main issue since I'd like this to be my kitchen TV, is that I am not able get any digital channels over cable or antenna. It tunes in all the analog channels over my cable connection, but no digital ones. Is there something I could check/replace to make this functional again? I know these and many other LCD's have issues with low quality caps going bad, I was wondering if a complete recap might bring the digital tuner back to life, or is that just plain wishful thinking.
    Thanks.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Westinghouse 19" with no DTV
    Thanks.
    What is the date of manufacturer of the TV? ATSC tuners became mandatory on sets manufactured after March 1, 2007. AFIK, QAM tuners are not mandatory.
    PlainBill
    • delaware74b
      • Apr 2009
      • 628
      emilime75, the digital signals provided by your cable company are not the same as the broadcast digital signals. In my case, with comcast, I don't have access to any of their channels above 98 without their rip-off box that never seems to work right [always pixelating but they can't find anything wrong].
      Stupidity should be a crime, especially for drivers. I have NO patience for them.
      • emilime75
        • Jan 2010
        • 18
        Thank you both for your responses. While what you both have to say is true I don't think it explains my issues. I get a good number of digital channels on my Panasonic plasma, including the local channels in HD and the digital music channels all provided by Comcast without an STB. Also, I tried using an antenna with the Westinghouse in question and it did not pick up any stations that way either. Then there is still the problem of not getting a picture using the component input from 2 different sources.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          http://www.westinghousedigital.com/d...px?itemnum=114
          maybe you have to set the atsc mode in the menu?
          beware that these westinghouse things are the cheapest of the cheap.i have seen several that could not hold a digital signal for shit.unless you were in a strong signal area it was useless.a cheap digitalstream converter box did much better.
          • PlainBill
            • Feb 2009
            • 7034
            I missed the model number; indeed it does have ATSC and QAM tuners. I think kc8adu's point may be valid for the tuner. The fact that the component input also does not work indicates a second problem.
            PlainBill
              MEDION AKOYA S15447 + ext. DVD Player Notebook Specification for Upgrade or Repair
              This specification for the MEDION AKOYA S15447 + ext. DVD Player Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S15447 + ext. DVD Player boardview and S15447 + ext. DVD Player schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
              09-06-2024, 05:30 PM
            • NTVStech
              Digital signage media player GV3288A-V1
              by NTVStech
              After a rather power surge the display is showing Android for a few seconds and then the display remains blank.I tried firmware recovery by using the reset switch on the board but to no avail.Am I
              doing something wrong or is it perhaps that the firmware is corrupted beyond recovery?...
              06-20-2024, 12:44 PM
            • Xristakis795
              le32a436t1d problem with digital channels
              by Xristakis795
              hi to all
              I have the above TV and it presents the following problem
              when i tune in and search for terrestrial digital channels he finds them normally
              but I hear only sound I do not see image and I have to see with mpeg4 decoder external device
              what could be wrong?
              12-31-2021, 05:55 AM
            • kokopelli75
              Victrola multi-player - No audio
              by kokopelli75
              Hello!
              My mother has a Victrola Navigator player that stopped functioning after a storm. I checked out what I could - all player functions appear to work, but there is no audio output in either the speakers or the headphone jack. I suspect (with my limited knowledge) that the amplifier part of the device is toast. Photo of the suspected board is attached. There's separate boards for front display, record player, etc. This board has a section for power regulation and a section for amp. There's a UTC7266 7+7W dual bridge amplifier IC and a CSC2314F sound processor IC on the board. Visually,...
              01-11-2025, 03:51 PM
            • r2digital
              Harmon Kardon AVR340 no sound on 4 channels
              by r2digital
              Hello, i had this amp sitting in the closet knowing that none of the channels were working. After taking it all apart i found 4 bulging main filter caps so i went ahead and replaced those with low ESR kmet caps. However after doing this it only restored sound to Surround L, Surround R, and Center channel. The main speaker fuse on the transformer F905/F906 keeps blowing so i decided to remove all of the transistor's on those 4 channels and measure them. All transistors appear to be in good working order(turned receiver on with none of them installed and fuse still blows). Checked dual emitter resistors...
              03-09-2024, 01:33 PM
