le32a436t1d problem with digital channels
  • Xristakis795
    • Mar 2021
    • 162
    • Greece
    hi to all
    I have the above TV and it presents the following problem
    when i tune in and search for terrestrial digital channels he finds them normally
    but I hear only sound I do not see image and I have to see with mpeg4 decoder external device
    what could be wrong?
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: le32a436t1d problem with digital channels
    have you tried a factory reset then re scan for channels using remote Put TV in standby then press Info Menu Mute Power
    • Xristakis795
      • Mar 2021
      • 162
      • Greece
      thank you sir
      if it does not work can I upgrade via flash on this model?
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        do you get any image on the lcd screen use a torch etc see if you can see the no signal screen this maybe a back light issue as older ccfl model
        • Xristakis795
          • Mar 2021
          • 162
          • Greece
          no sir the TV has no problem I use it normally but with an external decoder
          mpeg4
          the problem is that when I tune in and it shows me when the process is over that it has found 50 TV channels for example
          when I go to the channels I only have sound not image
          I did a factory reset was my first thought but the problem was not solved
          so I asked if it needs an upgrade or if the tuner has a problem
          what do you think
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            can you upload a picture of the main board used in your tv
            • Xristakis795
              • Mar 2021
              • 162
              • Greece
              i havent picture sir right now because the TV is a friend of mine and he has it
              but its BN41-00980C
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                This maybe worth a read https://masterelectronicsrepair.blog...amsung_11.html
                • Xristakis795
                  • Mar 2021
                  • 162
                  • Greece
                  (If there is no reception of television channels, but the TV is working properly from external devices, first of all you need to check the voltage of the tuner BN40-00120A and update the software ) from https://masterelectronicsrepair.blog...amsung_11.html
                  according to the above sir it is most likely he wants to upgrade do you know how I can do for this model?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    i have looked on the samsung downlaod page and cant see any firmware downloads for this set maybe un supported now due to the age of the tv the only other option maybe a replacement mainboard from ebay they are really cheap.
                    • Xristakis795
                      • Mar 2021
                      • 162
                      • Greece
                      thanks for the answer
                      • petehall347
                        • Jan 2015
                        • 4442
                        cant lose by asking samsung or whoever made the board .
                        • theone111
                          by theone111
                          3. Problem: TV shuts down
                          07-22-2024, 10:36 AM
                        • Zeonalbasta
                          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                          by Zeonalbasta
                          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                          09-13-2024, 01:17 PM
                        • Gibon378
                          Problem with stopping audio and video for no reason
                          by Gibon378
                          PC Specs:
                          • CPU: Ryzen 5 1600
                          • GPU: GTX 1080 Palit JetStream
                          • MOBO: ASRock ab350 PRO4
                          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                          • PSU: XFX 650W (don't remember what model)
                          • OS SSD: ADATA SP920
                          • OS: Windows 10 21H2
                          Problem description:
                          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                          11-19-2022, 09:41 AM
                        • Xristakis795
                          le32a436t1d samsung problem with gamma ic
                          by Xristakis795
                          hi
                          i have the above model of tv and it has gamma problem distort color
                          Tcon board is v315b1-c01
                          so i used from samsung le32r86bd the tcon board its exactly tha same nd same inches 32'
                          I have the following problem when changing the card
                          the letters of the dialogues are hidden I can not see them
                          I need to move the bottom of the image up and the top of the image down
                          I have a problem with the vertical
                          11-15-2021, 11:15 AM
                        • perzyk23
                          Lenovo T580 - LCD Panel problem - error 0288
                          by perzyk23
                          Good morning,
                          I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                          10-25-2024, 12:42 AM
