Polaroid tlu-01541cu s/b light on set dead
  • TEDDIBEAR
    • Oct 2014
    • 45
    • england
    Fault on this set was bad caps as usual which were replaced,on switch on no volts, second fault blown AOD403 p channel mosfet when replaced returned 5V rail and standby led, pressing on button returned 12v rail, I still have no backlight or any responce except plop from speakers, I do not know what voltages I should be getting on these connections BRI,B ON,P ON,or SB or their source, I do not think the backlight oscillator circuit is being switched on as no volts on IC pin 12 vcc,
    Not having a circuit diagram it is difficult to know where to look, any help would be appreciated, I think this chassis is used in Goodmans,Grundig,Alba,and Bush.
    John
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Polaroid tlu-01541cu s/b light on set dead
    Some good clear photo's of your circuit boards is always a good start.
    IC Pin 12? Whatis the part number of that IC
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      IC Pin 12? What is the part number of that IC
      Edit
      Sorry for the duplication
      • TEDDIBEAR
        • Oct 2014
        • 45
        • england
        Pictures uploaded screwdriver indicates relevent items.
        John
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          The first check is test what voltages you have at the connector alongside the legend shown in photo 6 of 7
          • TEDDIBEAR
            • Oct 2014
            • 45
            • england
            Voltages are as follows
            +5v-+5v =5v
            SB -SB = 0v ?
            GND-GND = 0V
            GND-P/ON = 0V ?
            BRI -B/ON = 0V ?
            GND-GND = 0V
            +12V-12V = 12V
            All ? unable to trace source
            John
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              There are 14 pins so are these all 14 or just the 1st row of 7.
              There should be some voltage readings for SB, B/ON and P/ON
              B/ON could be Backlight On
              P/ON could be Panel On
              SB maybe Standby and you say that pressing On button brings up the 12V supply so it may be that SB is High when the set is in standby and 0V when you come out of standby.
              Have you checked the red fuse on the board.
              • TEDDIBEAR
                • Oct 2014
                • 45
                • england
                This is all 14 pins as in picture 6, when mains is applied to power supply panel I only get +5 volt on + 5volt pair when I press sb button on remote I then get +12 volt but nothing on any other of the pins if I then press sb button on remote +12 volt remains until you unplug and start again.
                John
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  There must be some feedback to the power supply to enable the 12V supply to switch on.
                  Have you measured the voltages on the connected before and after you switch it on via the remote.
                    You need to recheck Voltage on the power supply connector, seems to me you have measurement error.
                    https://www.badcaps.net/forum/attach...5&d=1612363588
                    The power supply board only has one power transformer to supply the needed Voltages, it is an always on power supply, the switched +5V and switched +12V are done through switched MOSFET's. The main power supply is working otherwise you will not have any Voltages on the cold side at all.
                    If you look at the bottom side of the power supply, you will see that switched MOSFET Q204 (where you screw driver is pointed to) Drain pin is connected to SB pins (Standby 5V/Always on 5V) pin, the +5 pin is connected Source pin of the switched MOSFET Q204 which supplies the +5V, switched MOSFET Q202 is for switched 12V.
                    Since you do have switched +5V and switched +12V that means P-ON (PS-ON) control Voltage must be present from the main board.
                    B/ON = BL-ON
                    BRI = Backlights dimmer control.
                    BTW, if Q204 was shorted then the switched +5V will always be present. The SB is the always on +5V that is fed to switched MOSFET Q204 for the switched +5V.
                    Also the red rectangular fuse for the backlights inverter circuit is OK, correct?
                    • TEDDIBEAR
                      • Oct 2014
                      • 45
                      • england
                      Thank you for your replies.
                      This is the state of affairs
                      switch on at main switch I have +5 volts on +5 volt terminal pin, I also have +5 volts on the SB standby terminal, no +12v, when I press Standby button on remote I get +5 volt on P/on terminal pin and then +12v on +12v terminal pin,
                      I get nothing on B/on or Bri terminals. hope that makes sence, should I only have +5 volt on SB terninal and zero on +5 terminal on switch on and should the +5 volt only appear when Standby button is activated?.
                      If you then press standby button again board does not go back into standby and all voltages remain.
                      John
                      • TEDDIBEAR
                        • Oct 2014
                        • 45
                        • england
                        Bud
                        After reading your brilliant text on the other thread, I set to work rechecking my work so far I realised I had ordered and fitted the wrong Mosfet looking at the old devise with a microscope as the markings were soo bad the 3 turned out to be a 8, the device I fitted was a AOD403 P fet should have been a AOD408 N fet.fitting a N fet brought the following readings, on switch on, +5 volts on SB terminal, pressing standby button I get +5 volts +12 volts, +3.3 volts on P/ON, +5 BRI, but nothing on B/ON. any ideas?
                        John
                          TV unplugged, then check the resistance between Ground and B/ON pin.
                          The BL-ON is controlled by the main board.
                          • TEDDIBEAR
                            • Oct 2014
                            • 45
                            • england
                            Have checked resistance between B/ON pin and ground = 10k
                            BL-ON is fed from transistor Q209 on main board there appears to be no volts on E-B-C of this transistor, the transistor Q208 does have 5 volts on collector nothing on base or emmiter, but with out a circuit diagram it is hard to find where the switching signal is comming from.
                            If I were to link B/ON to P/ON do you think that would be worth trying?
                            john
                            • TEDDIBEAR
                              • Oct 2014
                              • 45
                              • england
                              john
                              I have gone one step further linked a Ik resistor between B/ON & P/ON still zero volts on B/ON, left resistor in position disconnected B/ON feed from main board now have back light working, so I now have a glowing screen no sound no display so it looks like I have hit the buffers unless you have any suggestions.
                              John
                                • 12323
                                • U.S.
                                Do you have a stand alone tcon board on this tv?
                                • TEDDIBEAR
                                  • Oct 2014
                                  • 45
                                  • england
                                  The Tcon board is part of the LCD screen, attached with film connections.
                                  John
                                  • esqmooo
                                    HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
                                    by esqmooo
                                    Hello everyone.
                                    This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
                                    Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
                                    Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
                                    I tried long pressing on the power button, after several seconds it would go off then when the button is released...
                                    03-11-2025, 03:57 PM
                                  • Patan
                                    Dead LA-H323P (no light) - HP 15-DW
                                    by Patan
                                    Need help here...
                                    I'm new on the forum and I'm not professional in electronics so i ask sorry in advance for eventual errors...
                                    As title says, i have a LA-H323P dead.
                                    Now, little background.
                                    The computer was working fine, just seems that the cable of screen was dying because it had the classic color problem, sometimes green, sometimes violet, sometimes perfect, but anyway working.
                                    When i opened it the battery was so fat that was seriously near to explode.​
                                    So i removed the battery... and turned on the notebook... that was, again, working perfectly fine....
                                    04-28-2024, 03:31 AM
                                  • Rav_tangle
                                    MacBook Pro 2011 turns on with keyboard light , screen dead
                                    by Rav_tangle
                                    Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
                                    I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
                                    Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
                                    is this...
                                    05-31-2024, 04:09 PM
                                  • mecha1166
                                    XR-77A80K Dead set, red light blinks 8 times. Cannot find error code list.
                                    by mecha1166
                                    I have a XR-77A80K here. When plug in & press power, white lindicator light flashes on & off. about 30 seconds later, indicator light flashes 8x red. Checked Sony, Power reset = unplug & plug in. Factory reset involves turning it on, then pressing remote buttons when a picture shows. Well, neither of these "resets" are for a dead set like this. Anyone know what 8 blinks indicates, from the schematic? Thanks!
                                    07-01-2024, 05:47 PM
                                    Laptop computer that went completely dead no boot no power light no hard drive light
                                    by sam_sam_sam
                                    See pictures for type of laptop computer
                                    I checked switching power supply brick 19.2 volts multi meter only
                                    No booting without switching power supply connected
                                    Checked switching power supply with an (28 volt ) incandescent light bulb it lights then hooked up the switching power supply again now the laptop and boots like normal
                                    What the heck is going on here...
                                    04-04-2025, 04:58 AM
