Sony KDL-70W850B T-CON problem
  • hmendez86
    • Jun 2015
    • 344
    • united states
    I did change the t-con and it goes to protect mode green and orange ligth comes on blinking....i press on power button and plug while holding power button and its start on arrow circle around cycling and stays there for ever...
  • hmendez86
    • Jun 2015
    • 344
    • united states
    Re: Sony KDL-70W850B T-CON problem
    I was looking for firmware..went to sony page downloaded and think am doing something wrong...any anwsers
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Do you have to pair the Tcon to the mainboard. Diah and Neilc6 may have some information on this that could help.
      • zen
        • 511
        Yes , far as i am aware of , T-CON & main need to be paired .
        • hmendez86
          • Jun 2015
          • 344
          • united states
          So how do i need to pair t-con to main..
          • Diah
            • Feb 2013
            • 6614
            T-CON replacement dont need any pair at this sony. the T-CON must be 100% for the same model and screen size.. but if the original are defect and it register 5 blinking error ,, then need to clear the error at self diagnose service menu..pairing and adjustments need only if Main boards or tuner replaced..
            so..
            why you changed the T-CON ??
            put back yours yours original T-CON in place and turn on to let the set running normal again..... and show us clear photo on the boards and the issue you have.
            • hmendez86
              • Jun 2015
              • 344
              • united states
              The problem of the tv with original t-con is that when tv is turn on works great all day once its to be turn off you cant turn it back on it gives green and orange ligth...i need to unplug it and it will turn on good until its turn off....so did change t-con new and does not come on green and orange ligth
              • hmendez86
                • Jun 2015
                • 344
                • united states
                This what happens with new t co....to get to this ...i had to press and hold power button and plug to ac/outlet and gives me the circle just going like buffering..and stays like that...
                • hmendez86
                  • Jun 2015
                  • 344
                  • united states
                  The ligth change to blue..
                  • Diah
                    • Feb 2013
                    • 6614
                    this issue you described had nothings to do with T-CON.
                    firmware start script when the set turned off, there are low RESET at the chips where forced the start script start from beginning. so the set will turn on normal again as last state before it turned off. if this small procedure interrupted because of bad chip ( sector) or there were bad caps which didn't discharged as it need so the chips ( start script i mentioned above ) remain active and didn't reset it self. until the currents drops close to ZERO.
                    i asked you at my post #6 to put back yours original T-CON so we can start diagnose the issue.. but as usual many just they believe on what they have in mind.. on this way i cant share my help.
                    • zen
                      • 511
                      Hi Diah
                      Have a few questions , if you don't mind .
                      Is this one of the earlier Sony models , that use the Linux operating system ?
                      Is it the later Sony sets using the android operating system that are more particular , with regards to pairing ?
                      Thank you in advance , Zen.
                      • nomoresonys
                        • 12332
                        • U.S.
                        Zen, asking questions is great but you need to start your own thread. If someone stops to answer a bunch of questions in the middle of someones thread, it only takes longer and adds confusion and unnecessary length to the thread. I'm pretty sure Diah knows the answers but this particular thread is for the task at hand, trying to fix this tv. Not that I really care what goes on here, it's just a little distracting.
                        • Diah
                          • Feb 2013
                          • 6614
                          THX nomoresonys.
                          its early Linux.. T-CON pairing only will be neccerry on any brand not only sony when the T-CON owned its SPI Flash contained firmware (updateable) to let it match the main firmware.
                          • zen
                            • 511
                            Thanks Diah
                            Also apologies , in future will start new thread , for unrelated content .
                            Regards Zen.
                            • hmendez86
                              • Jun 2015
                              • 344
                              • united states
                              Hi...i change the main and got it to work...i did the upgrade t-con was fine all the time...now the tv stay on the green ligth and shows pic...but now the no backligth with flash ligth it shows the picture...i see the channels and menu.......
                              • hmendez86
                                • Jun 2015
                                • 344
                                • united states
                                But before did the update the backlight were working...first i put the usb with update then i connected to outlet and started alone updating and backligth on with the circle arrow doing his update when it finished turn on and off then back on but with no backligth...but i can see the image with flashligth now it stays green ligth...
                                • hmendez86
                                  • Jun 2015
                                  • 344
                                  • united states
                                  • hmendez86
                                    • Jun 2015
                                    • 344
                                    • united states
                                    Want to know the voltages for.. vled_vcc am gettig 41.5v
                                    • hmendez86
                                      • Jun 2015
                                      • 344
                                      • united states
                                      Ill post later the voltages am getting on all pins to see whats missing.
                                      • nomoresonys
                                        • 12332
                                        • U.S.
                                        Throw your original mainboard in there, see if it works now.
                                        • iglitare
                                          Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                          by iglitare
                                          i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                          Backlight seems to work, Sound (Setup menu after reset) works.
                                          If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                          Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                          With my small knowledge i would think at least the cables are good.
                                          Can this happen because of a bad tcon board?
                                          Or is it always a bad/shorted...
                                          09-04-2025, 07:13 AM
                                        • Chrissygizmo
                                          Sony KD-55XG9505 lines on screen problem
                                          by Chrissygizmo
                                          Hello again everyone,
                                          This is my latest mission, to try getting this Sony tv back to normal working order…
                                          I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                          02-19-2025, 11:31 AM
                                        • kca
                                          by kca
                                          Hello all ~
                                          08-31-2025, 06:38 AM
                                        • rimwall
                                          Sony KD-65x7500D - double image - Tcon or Panel?
                                          by rimwall
                                          This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                          I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                          11-18-2025, 02:09 AM
                                        • thelankanguy
                                          Sony KD-55X9000F TCON Issue
                                          by thelankanguy
                                          The TV shows a black screen with no image.
                                          TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                          Later both ribbons were disconnected and TCON voltages were tested.
                                          12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                          There is also a short to ground in this circled inductor.
                                          Is this a TCON issue or something else ?...
                                          12-13-2024, 12:27 AM
