Sony KDL-70W850B T-CON problem
  • anmol
    • Mar 2012
    • 73
    • India
    #41
    Re: Sony KDL-70W850B T-CON problem
    format pen drive and put software in it, follow instruction. wait until tv start normal.
    https://www.sony.com/electronics/sup...loads/W0011108
    • hmendez86
      • Jun 2015
      • 344
      • united states
      #42
      I change the LD LED DRIVER and new power and still no ligths
      • Diah
        • Feb 2013
        • 6397
        from start you always follow only yours mind. make me feel its useless to write again..
        did you try what i advised you at post#34
        how about if you have open led at the back light????
        • hmendez86
          • Jun 2015
          • 344
          • united states
          #44
          I did try the thread #34 of back ligth to lower depending on how high it was i lower it ar 1/3 first try then did 50% and nothing i try evrything else i read and nothing happend...so friend of mine had power and led driver only so i give a shot with new power/led driver and nothing
          • hmendez86
            • Jun 2015
            • 344
            • united states
            #45
            I did open the all tv....removed the screen all plastic. I check leds with led tester and all they work fine....so no led problem.....
            • hmendez86
              • Jun 2015
              • 344
              • united states
              #46
              So what i think the main is not giving the pow_led or bl_on
              Backlight_on...but i dont know what the voltages should be present in order to backligth to work..
              • nomoresonys
                • 12206
                • U.S.
                #47
                This is where most testing should start: Start with testing the voltages at the connector on the powerboard CN6401, see the legend/map right there by the 16 volt caps, with EVERYTHING hooked up, you measure them with your mutimeter, set meter to 20 vdc then report them, put neg probe on chassis metal ground, pos probe on pin of connector, measure in standby take note, leave probes where they are then power on tv and again take note of voltages, report them here, example pin 1-ps-on-0 volts standby-power on-3.3 volts. Look closely the pins are numbered, see where 1,2,27 and 28 are labeled? you may need skinny end probes to get the readings on the bottom, I usually use a stripped bread tie or small paper clip to make connection if necessary.
                • hmendez86
                  • Jun 2015
                  • 344
                  • united states
                  #48
                  • hmendez86
                    • Jun 2015
                    • 344
                    • united states
                    #49
                    Took out the screen... with led tester work great every single line work on both sides... and the picture above is with the tv on and thats how they look very low dim but just only on the seccion on the top and on the bottom the nothing and both sides
                    • Diah
                      • Feb 2013
                      • 6397
                      flip it so you can see correctly after you turn it on.. you can record it with camera to see the off side did they blinks once shortly at turn on.
                      • hmendez86
                        • Jun 2015
                        • 344
                        • united states
                        #51
                        I did turn up side down the tv to see if it blinks, but nothing happend. I just see very low dim like vearly see the dim..i test them again with other advance led test and evrything work well...so my theory should be on the main...or etheir the the service menu i think there should be a backligth switch on and off maybe.
                        • Diah
                          • Feb 2013
                          • 6397
                          forget the LED tester.. spend time to test each LED with yours digital meter.. if yours DM 9V batteries then with Diode mode the working LED should light on Dim and if you reverse the probe it should read zinner diode 0.75 to 0.58 ( depend on the LED Type) if no reading mean its defect open. or with beep ton to see if it had shorted zinner.
                          • hmendez86
                            • Jun 2015
                            • 344
                            • united states
                            #53
                            Hello....All led ligth up with the fluke 9v and tested the other way of testing as diode were at .77
                            • Diah
                              • Feb 2013
                              • 6397
                              you are lost either we are.
                              as you are sure tested all LED and they are fine.. just be sure of the sockets soldering on the strings and the wiring from end to end with LED inverter out.
                              when you are sure all fine and the led can light on when you feed them DC as separated group from LED inverter sockets wiring .. put back yours old mainboards & T-con let see what you have.
                              • chrismurphy
                                • May 2014
                                • 251
                                • australia
                                #55
                                sorry to say you have faulty leds
                                • hmendez86
                                  • Jun 2015
                                  • 344
                                  • united states
                                  #56
                                  I tested with older board and still have no backligth i install the original board back an nothing...i order a full kit power supply led driver mainboard and tcon and still no backligth....i install the kit which i buy it from shopjimmy and backligth turn on when i started installing the update firmware both side turn on so when tv reset off the on whe this happen there wer no backligth just image....
                                  • Chrissygizmo
                                    Sony KD-55XG9505 lines on screen problem
                                    by Chrissygizmo
                                    Hello again everyone,
                                    This is my latest mission, to try getting this Sony tv back to normal working order…
                                    I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                    02-19-2025, 11:31 AM
                                  • thelankanguy
                                    Sony KD-55X9000F TCON Issue
                                    by thelankanguy
                                    The TV shows a black screen with no image.
                                    TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                    Later both ribbons were disconnected and TCON voltages were tested.
                                    12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                    There is also a short to ground in this circled inductor.
                                    Is this a TCON issue or something else ?...
                                    12-13-2024, 12:27 AM
                                  • crackedprint
                                    Sony HCD-HX80R Amplifier Volume Control Problem
                                    by crackedprint
                                    I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                                    I have tried a Cold Reset as per the service manual.
                                    I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                                    I have looked all the way through the service manual and tried many online...
                                    01-21-2025, 12:18 PM
                                  • retrorepair
                                    SONY KDL-40P3600 Picture Problem
                                    by retrorepair
                                    Hello gurus, hope you can assist me...
                                    I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
                                    I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
                                    Thanks in advance.
                                    10-11-2024, 05:12 PM
                                  • guruji
                                    Sony mbx-266 problem
                                    by guruji
                                    Hello
                                    I this Sony mbx-266 it powers
                                    on all the voltages are normal the strange part iOS the caps key num key works which shows the machine has booted but no video at all internal dp and the ext vga or hdmi.I have changed the bios but same issue. What do I check ??
                                    07-25-2025, 08:10 AM
